Best Glue for Plastic Lamp Shades: Heat-Resistant Options, Electric Guns, Glass Glue
skaktus 92449 13
What glue should I use to reattach a plastic lampshade so it can withstand heat and, if possible, still be taken apart later?
Use butyl glue/tape if you want a lamp joint that stays secure yet can still be opened later; one reply specifically recommends butyl tape for lamps and avoids silicones because they make later disassembly difficult [#17193177] Hot glue from an electric gun and sanitary silicone are poor choices here because they can come off [#9257185] If you want a stronger bond that is still somewhat reversible, use a polyurethane adhesive/sealant such as 2W, Bolla, or Novol; it can be separated later by heating with a heat gun [#9257855][#9271310] Another option is to re-use the old adhesive by warming the lamp edges with a hair dryer and pressing the parts back together [#9257952], but that method may not seal perfectly [#9258151]
  • #1 9257169
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    I was forced to dismantle the daylight lamps. The lampshade is made of plastic. Glued with glue which softened when heated in boiling water. What glue now replace the one that was at the factory? Is glue sticks suitable for electric guns? Is it better to glue with glass glue (although I'm afraid that if I glue the lamp together, it will be the chapel)? Or maybe you know some better solutions?
  • #2 9257185
    Błażej
    Help: 1923
    Rate: 3627
    The hot glue comes off. The sanitary silicone comes off. Glass glue yes, but it's a one-time action. Although wanting to cut.
  • #4 9257855
    RobertLodz09
    Level 30  
    Help: 123
    Rate: 542
    I glue the reflector glasses using polyurethane adhesive and sealant, e.g. made of 2W or Bolla, Novola (in a squeezing tube). It is "weaker" than glass glue because when heated, for example with a heat gun, the "joined elements" can be separated (with difficulty, but you can). Available for purchase at car paint shops. Greetings!
  • #5 9257952
    i_wiki
    Help: 52
    Rate: 101
    I glued the lamps on the old glue, heating the edges of the lamp with a dryer / sprayer and pressing it firmly
  • #6 9258151
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    I would also stick on the old glue, unfortunately the glue is so little that the lamp is not fully sealed.
  • #7 9259450
    zmstr84
    old glue is usually gray, yes? :) There is gray silicone? There is :)
    I happened to stick up 3 sets of headlights and I glued 2 sets on gray silicone, I glued one set with black ones - all of them have been running so far and have not fallen apart and do not evaporate, so silicone is probably the best solution. Basically I did not try to use other means
  • #8 9261057
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    The problem is that the lamps have a protruding lampshade in relation to the base by almost 5 cm. These are oblique daylight lamps that steamed strongly.
  • #9 9270985
    martinobmw
    Rate: 29
    I stick silicone diffusers to glass - [glass, mirrors] colorless and I have never had a problem with evaporation
  • #10 9271310
    maciejdm1
    Rate: 9
    I used Bolla windscreen glue - no problem, then I heated it and took it apart.
  • #11 9271677
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Here it is not about evaporation, but about the fact that the lampshade can be removed if necessary, but also that the plastic lampshade is firmly glued and does not fall off.
  • #12 9389144
    Roman_5000
    Level 19  
    Help: 26
    Rate: 81
    I need to stick the glass to the aluminum (or aluminum alloy) housing of the halogen lamp.
    I'm not going to take her apart anymore. Will the silicone for glass catch my glass with the metal housing of the halogen lamp?
  • #13 9389221
    RobertLodz09
    Level 30  
    Help: 123
    Rate: 542
    Rather, you won't be able to "disassemble" it later if you use "auto glass adhesive". Greetings!
  • #14 17193177
    lancer78
    Rate: 20
    Only butyl glue in the form of tapes of different width and length. We do not use silicones because if necessary, we will not unfold the lamp
The discussion centers around finding suitable adhesives for plastic lamp shades, particularly those that can withstand heat. Users suggest various options, including polyurethane adhesives, gray and black silicone, and specific brands like Bolla and Technicqll. Concerns are raised about the effectiveness of hot glue and sanitary silicone, which tend to fail under heat. Glass glue is mentioned as a one-time solution, while butyl tape is recommended for applications where disassembly may be needed in the future. The importance of ensuring a strong bond without compromising the ability to remove the lampshade is emphasized.
