Choosing the Best High-Temperature Glue for Washing Machine Drum Casing Repair
Stanislaw elektryk12 41037 15
What is the best glue or sealant to reassemble a glued washing machine drum/tank after replacing the bearings, and will high-temperature adhesives survive hot washes?
The most reliable repair is to weld the plastic tank halves; adhesive-only repairs are treated as a compromise. If you must glue it, avoid Mamut because one user reported it became too hard and failed after about 20 washes, and others recommended a flexible sealant/adhesive such as Fixall Sudala, Bostik, or Boll car window adhesive with activator [#20436852][#20437018] High-temperature silicone should survive normal wash temperatures, and one reply noted that a silicone rated to +265°C should handle 80°C washing water, but silicone is mainly a sealant rather than the structural bond [#17056951][#20437171] Several replies stress that the halves should be fitted well and screwed together densely, then sealed from the outside; one user also suggested reinforcing the joint with mesh if using glue [#20437018][#20437186] There was also a suggestion to have a plastics specialist weld the tank permanently, which was presented as the best long-term solution [#20436871][#20436936][#20437672]
  • #1 17056793
    As in the title, he asks for advice on choosing the best glue to glue the washing machine drum.
    Well, I decided to change the bearings in my washing machine, of course the drum was glued.
    I got to work, I drilled holes every 8 cm, then I dismantled the drum.
    The replacement of the bearings went smoothly, but there are my concerns about the choice of glue to glue it together.
    I read on the forum that Mamut or high-temperature silicone is good, but do these adhesives not harden after washing at high temperatures?
    Please advice thanks a lot in advance.
  • #2 17056947
    Krzysztof Druś
    Help: 35
    Rate: 85
    You can use silicone, or you can do better at high temperature. Was the drum glued?
  • #3 17056951
    leonov
    Help: 1039
    Rate: 2247
    Stanislaw elektryk12 wrote:
    but don't these adhesives cure after washing at high temperatures?
    Since such a high-temperature one can withstand + 265 ° C, then these 80 will probably not hurt him ;-)
  • #4 20436852
    gregor7891
    The mammoth is not suitable, I glued the drum after replacing the bearings and after about 20 washes it fell apart.
  • #5 20436871
    palmus
    Help: 233
    Rate: 752
    Talk to your local plasticsman. He should weld it for you and it will be permanent.
  • #6 20436879
    ^ToM^
    Help: 495
    Rate: 2939
    I think that two-component polyurethane adhesive will be suitable for this purpose:
    link
    Ask the guys from Atashka, they will surely advise the best glue for this purpose.
  • #7 20436881
    Kenworth 18
    Help: 2442
    Rate: 3749
    @gregor7891 Was the tank screwed on?
  • #8 20436936
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    After many different experiments and applied liniments, the only right technique is the so-called "welding" of plastic.
  • Adhesion and peel tests for tank plastic
    #9 20436965
    Staszek_Staszek
    Help: 116
    Rate: 846
    You need to look at the tank carefully, maybe there is a symbol of this material. Even if there is a symbol, I still do adhesion tests because now they make different copolymers and everyone is a little different.
    A drop of glue on the surface and attaches a polyester tape.
    After curing, I try to tear off the tape and I can see if it sticks or just sticks. Scholars call this the peel test.
    Only I have several types of glue in larger packages and I don't have to buy it.
    Not all plastics can be welded. Also, a test weld should be done if possible.
    Regards.
  • #10 20437018
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    Everything in the tank is not welded together, e.g. a cup with a drain pump. The basis is to fit the halves well, screw them together and seal them with Fixall Sudala or Bostik glue. Mammoth, while it is strong, is too hard after drying. A good option is the Boll car window adhesive with an activator.
  • #11 20437085
    misiek1111
    Level 37  
    Help: 325
    Rate: 1097
    The solution is #8.
    However, if someone wants to use glue, silicone or a baby from the nose, it is important that, for example, a fine mesh is immersed in the glue polystyrene polyester.
    That is, the equivalent of reinforcement in reinforced concrete.
  • #12 20437143
    Staszek_Staszek
    Help: 116
    Rate: 846
    misiek1111 wrote:
    fine polystyrene mesh.
    First time I hear it, maybe it was polyester?
  • #13 20437171
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    After all, silicone serves primarily as a sealant, the screws are responsible for keeping the halves together. Just like in twisted tanks. Nothing sticks there and stays on. People, think what you write.
  • #14 20437186
    misiek1111
    Level 37  
    Help: 325
    Rate: 1097
    Significant forces are exerted on the screws, especially during spinning. Plus, it's a metal-plastic combination.
    It's better to do it with a reserve and additionally glue the edge from the outside, than to make corrections later.
  • #15 20437200
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    I made Bosch bolted and Electrolux glued. I used glass glue, both work for two years. Screws can be given densely 3.5 × 20, first a 2mm drill, then a screw. And that I screwed 40. I think the factory is dying.
  • Plastic welding preferred over glued tank repair
    #16 20437672
    mrice
    Help: 2213
    Rate: 6951
    The only difference is that in a factory bolted tank, not only the screws transfer the forces. There are also wounds around the seals that absorb a lot of forces, and the screws are much larger and screwed directly into the material.
    When carving a slit tank, there is nothing more than screws to absorb force during work. In addition, a drilled hole will never fit as well as a screw screwed directly into the material. In addition, the screws that can be used in most tank rims are a maximum of four, sometimes even three.
    Gluing and "screwing" will never give a perfect connection, the two halves of the tank against each other will continue to work. Without a strong and at the same time flexible binder, we will quickly have a leak at the joint.
    That's why I stubbornly repeat, although I also started playing with frogs, I've already cured myself of it. Unfortunately, this is a crauter method that has many disadvantages. The only right thing is to weld plastics. If you wish, you can do it at home. Melting the plastic is not that difficult.
The discussion revolves around selecting the best adhesive for repairing a washing machine drum after bearing replacement. Users suggest various options, including high-temperature silicone, two-component polyurethane adhesives, and specific brands like Bostik and Boll car window adhesive. Concerns are raised about the durability of Mamut glue, which reportedly failed after multiple washes. Recommendations include consulting a local plastics expert for welding, performing adhesion tests on the drum material, and ensuring a strong, flexible bond to prevent leaks. The importance of proper fitting and sealing is emphasized, as well as the limitations of using screws alone for structural integrity.
TL;DR: On slit tub rims, you may fit only 3–4 screws, and “the only right thing is to weld plastics.” This FAQ helps DIYers choose a high‑temperature sealing method when rejoining washing‑machine drum casings after bearing replacement. [Elektroda, mrice, post #20437672]
Why it matters: The right joining method prevents leaks, spin‑cycle failures, and repeat tear‑downs after a bearing swap.
What’s the most durable way to reseal a split washing‑machine tub?
Plastic welding is the most reliable method after opening a glued tub. It fuses the plastic so the joint flexes with spin forces. Adhesives or screws alone can let the halves move and eventually seep. As one expert put it, “the only right technique is ‘welding’ of plastic.” Choose welding when you want a long‑term, leak‑free result. [Elektroda, mrice, post #20436936]
Will high‑temperature silicone survive hot wash cycles without hardening or failing?
Yes. Users report high‑temperature silicone rated near +265°C, so normal 60–80°C cycles are far below the limit. As one reply noted, “these 80 will not hurt it.” Use true high‑temp silicone for sealing only, not as the primary structural bond. Confirm cure time before filling the tub with water. [Elektroda, leonov, post #17056951]
Is Mamut adhesive a good choice for drum‑casing seams?
No. A user bonded a cut tub seam with Mamut and the joint failed after roughly 20 washes. That is a clear field failure in hot, wet, vibrating service. Choose alternatives designed for flexibility and constant water exposure, or weld the plastic instead. [Elektroda, gregor7891, post #20436852]
Can a plastics shop weld the tub for me, and is it permanent?
Yes. A local plastics technician can weld the halves, restoring a strong, leak‑resistant joint. One experienced member advised, “He should weld it for you and it will be permanent.” This option suits users without welding tools or practice. Bring a clean, dry tub and discuss compatible filler material. [Elektroda, palmus, post #20436871]
Can I weld the tub at home? How do I do it?
Yes, you can. “If you wish, you can do it at home. Melting the plastic is not that difficult.” Try this:
  1. Clean, align, and clamp the halves firmly.
  2. Heat the rim area and base plastic until it softens.
  3. Fuse a continuous bead around the seam; let it cool without stress. Use even heat and avoid overheating the plastic. [Elektroda, mrice, post #20437672]
Should I rely on screws or glue to hold the halves together?
Use screws for clamping strength and silicone as a sealant, not as the primary bond. “Silicone serves primarily as a sealant, the screws are responsible for keeping the halves together.” Place screws evenly and avoid over‑torque that can strip plastic. [Elektroda, Mierzejewski46, post #20437171]
What screw size, pilot drill, and screw count have people used successfully?
A documented approach used 3.5×20 mm screws with a 2 mm pilot hole, about 40 screws around the rim. This setup produced two years of leak‑free service on Bosch and Electrolux tubs when paired with proper sealing. Distribute screws evenly to spread loads. [Elektroda, Mierzejewski46, post #20437200]
Why do glued‑and‑screwed seams still leak over time?
Factory bolted tubs use shaped rims and large screws to share loads. After cutting a glued tub, only your small screws carry forces, and drilled holes never fit as well. Without a strong, flexible binder, “we will quickly have a leak at the joint.” Welding avoids this mismatch. [Elektroda, mrice, post #20437672]
What sealants have worked if I don’t weld the tub?
Users report success sealing with FixAll (Soudal) or Bostik, with the halves screwed tightly. A good option is Boll car‑window adhesive with an activator. One caution: “Mammoth, while it is strong, is too hard after drying.” Flexibility matters under spin loads. [Elektroda, Mierzejewski46, post #20437018]
Are two‑component polyurethane adhesives a good option here?
They can suit plastic bonding and remain flexible. One contributor recommended a two‑component polyurethane adhesive and suggested consulting specialists for an exact match to your tank plastic. Retailers like Ataszek can advise on compatible formulations and primers. Follow cure schedules before water testing. [Elektroda, ^ToM^, post #20436879]
How can I test whether a glue will adhere to my tank plastic?
Do a simple peel test. Put a drop of your adhesive on the plastic and embed a strip of polyester tape. After curing, peel the tape and check if the adhesive truly bonded or only stuck weakly. Adhesion varies by polymer and copolymer, so test before committing. [Elektroda, Staszek_Staszek, post #20436965]
Can all washer‑tub plastics be welded?
No. Some tank materials or blends resist welding. Inspect the tank for a material symbol, then try a small test weld on a noncritical area. If the bead fuses and holds, proceed; if not, choose a compatible adhesive strategy instead. [Elektroda, Staszek_Staszek, post #20436965]
If I choose bolts, what hole spacing has worked when opening a glued tub?
One documented teardown used holes spaced every 8 cm to split the glued drum cleanly. Even spacing helps maintain alignment for reassembly. Deburr holes and seal screw threads during rejoin to prevent capillary leaks. [Elektroda, Stanislaw elektryk12, post #17056793]
Should I reinforce a glued seam with mesh?
Yes, if you must glue, embed a fine polyester mesh into the adhesive layer along the seam. This adds tensile reinforcement “like reinforcement in reinforced concrete.” Keep the mesh fully wetted by the adhesive to avoid voids. [Elektroda, misiek1111, post #20437085]
