Maximum Length and Type of Coaxial Cable for 200m Run to Echostar 717 Receiver
Szelek67 28170 6
  • #1 9343217
    Szelek67
    Hello. I'm new to the subject and I have a problem: what can be the maximum length of the antenna cable (coaxial) between the converter (a twin for two decoders will be used) and the satellite receiver (Echostar 717)? For such a connection I need approximately 200 m of cable. If possible, what cable should I buy and possibly what signal amplifier? Thanks in advance for any advice, suggestions, etc. Regards
    PS Buying a second antenna is not an option.
  • #2 9343260
    matn__
    Help: 7
    From what I recently read in satellite advice, it was written that up to approx. 100m.
  • #3 9343279
  • #4 9343368
    xE5150
    Help: 56
    Rate: 82
    You can always use fiber optic cable and adapt the installations.
    Optical converter + virtual optical converter.
    Regards!
  • #5 9344742
    p3st
    Help: 63
    Rate: 66
    Fiber optic installation has astronomical costs.
    On the other hand, if you want to lay 200 meters of coaxial cable, it must be a high-quality cable (and x 2), which is also quite expensive.
    100 meters of cable is not a "competitive" length, but at 200 meters... Buy a "higher-end" cable and see if it will be able to deliver the signal.
    One more important thing: the best amplifier is a large dish. That is, if you are about 60 - 70 cm. it is necessary to replace it with at least 90 cm.
  • #6 9347236
    pasc
    Level 19  
    Help: 31
    Rate: 35
    Hmm...
    And one more fundamental question, or maybe a few questions?!
    These 200 meters of cable will be "pulled"... in cottages, on poles, on the ground, underground or maybe a mix of everything?! Because honestly, at 100 meters there is a signal and voltage drop like hell... I suspect that at 200 meters the installation and whoever hung it, buried it or whatever else will go to hell...
    Special cable, copper with proper (double, triple insulation), gel-coated, smoked black... simply space technologies :D
    Greetings
    ps: and this equipment for which my "friend" wants to commit financial harakiri... Echostar DSB-717 hehe... you know what you have :D
  • #7 9401028
    Tomasz73
    Rate: 13
    It all depends on the attenuation of the cable and the energy gain of the antenna.
    Recently I had to drag 100mb
    I used the TRIAX TD110 antenna, I chose the Greek VECTOR CU410 TRISHELD cable, the N-Ki cable was connected and the result was a signal strength of 79%, quality of 100% :D
    cable laid in the ground in a special corrugated pipe resistant to bending.
    TOMSPEC
    Anieli Krzywoń 1, Jelenia Góra, 58-506 | Company Website: tomspec.pl
The discussion revolves around the maximum length of coaxial cable for connecting a satellite receiver (Echostar 717) to a converter, with a user seeking advice on using approximately 200 meters of cable. Responses indicate that while 100 meters is generally acceptable for coaxial cable, extending to 200 meters may require high-quality cable and an amplifier due to significant signal loss. Suggestions include using a high-end coaxial cable, considering a larger satellite dish for better signal reception, and exploring fiber optic options, although the latter is noted to be costly. The importance of proper installation and cable type (copper with multiple insulation layers) is emphasized to mitigate signal degradation.
