Washing Machine Valve Leak: Examining Possible Gasket Replacement or Valve Issues
Mundeusz 26943 4
  • #1 9430774
    Mundeusz
    A puddle formed in the vicinity of the washing machine a few months ago. At first, I did not associate it with the water drops collecting in the place marked with the arrow in the attached photo, the more so because after cleaning the filter the problem suddenly disappeared. I figured it was about an overfilled filter. After a month of cleaning and two washes, I suddenly felt a puddle again, I checked the filter - clean, but water appears again at the valve and as it turned out it simply flows down the tube, hence the puddle. The question is whether it is enough to treat it with some external gasket, or is the problem with the valve and will it need to be replaced?
  • #2 9430945
    ROBSON33
    Admin of household appliances group
    Help: 465
    Rate: 1714
    Purchase the correct valve designed for your connection. washing machines and after the problem.
  • #3 9430953
    kranzio
    Help: 91
    Rate: 139
    There are two options. You take and unscrew these two reductions and tuck them, for example with Teflon, or you buy a new valve with an outlet probably for 1/2 inch. By the way, who used such inventions. The cost of the valve with the appropriate outlet for the hose is about PLN 15. Greater certainty of tightness of the connection.
  • #4 9431431
    ROBSON33
    Help: 465
    Rate: 1714
    kranzio wrote:
    you buy a new valve with an outlet I think is 1/2 inch.
    A mistake 3/4 inch or if you prefer ? 20.
  • #5 17298111
    JMZCHDY
    Unfortunately, such valves should be used "in the natural environment" !!! and not in apartments! This is rubbish! Not a valve! Therefore, I am writing that in the natural environment it should possibly be used, because water leaks through this mediocrity !!! Do not buy these cheap valves for the apartment !!! I do not recommend because I had this mediocrity!
