Calculating Charging Time for 2x180Ah Batteries Using 90A Alternator and Deutz V8 Engine
arturs75 46317 29
How long does a 90 A alternator need to run to recharge 2×180 Ah batteries after starting a 13-liter Deutz V8 engine?
You cannot calculate a reliable minimum charging time from only the alternator rating and battery capacity, because starter current and cranking demand vary with temperature, engine condition and how long it cranks [#9434691][#9484710] In practice, the thread says 4 minutes of running is probably too short to fully replace what the starter used, and suggests either running the engine for about an hour or charging the batteries externally overnight / every other day [#9434691][#9488404] If you use external charging, contributors recommend a 24 V automatic charger or a 27.4–27.6 V PSU with current limiting; for maintenance charging, about 5 A is enough and the current will taper as the batteries fill [#9484832][#9489975][#9493681]
  • #1 9433796
    arturs75
    Rate: 24
    I have the following problem:
    How much time should the engine run at least for the alternator to charge the batteries as much as the starter took the current from them. Unfortunately, I do not know what power the starter is, I only know that the alternator is 90 amps and the batteries are 2 x 180Ah, the starter is not a small one because it has to start the 13-liter deutz V8 engine.
    The engine works in a construction machine and after about 4 minutes of operation it is turned off, unfortunately it is probably too short time to recharge the power used from the batteries.
  • #2 9434691
    jannaszek
    Help: 394
    Rate: 673
    A warm engine needs 0.5 seconds of the starter operation, the current flowing in the pulse can reach 1000 A, so you can burn it several dozen times, but these 4-minute working times are probably not enough to fully recharge and it is suitable to connect it to the rectifier overnight with some limitation after charging .
    Or let the engine work for about an hour, the on-board ammeter will allow you to assess the state of charge by not leaning to + during operation.
  • #3 9434765
    arturs75
    Rate: 24
    I planned to install the rectifier permanently in the machine because 220v is rather always available on the construction site, but I was wondering how to limit the charging current as the batteries charge (something like the voltage regulator in the alternator limiting the excitation current) and can the rectifier and alternator work together?
  • #4 9435046
    sq9cwd
    Help: 74
    Rate: 143
    A rectifier with automation will help. My guess is the batteries are connected in series so you need a 24V charger. Look around automotive stores, if you have trouble finding, I can give up.
    Greetings.
  • #5 9435283
    arturs75
    Rate: 24
    well, 24v, the rectifier even has a quite powerful "dynamic Telwin 620" (a lot of these on the Allegro) but whether it has "automatics" I do not know. It has an ammeter and during charging the arrow gradually moves less and less, but does it actually get less from the rectifier?
  • #6 9439866
    sq9cwd
    Help: 74
    Rate: 143
    A powerful machine, but it seems to me that the device does not have charging control electronics, as a rule, manufacturers are loudly honking about additional product features, and I have not found such information in any descriptions.
  • #7 9449796
    PCcepuk
    Level 19  
    Help: 18
    Rate: 118
    hmm ...
    what is this machine and what revolutions does it work for these 4 minutes, how many times a day is it burned and with what breaks and how fast the engine starts ... ???
    it may turn out that no rectifier is needed ...
  • #8 9484628
    arturs75
    Rate: 24
    Construction crane, engine like in a truck, alternator 28v 90A, "slow" revolutions about 1000 / m, fires normally, i.e. about 1s. The fired, pulled load and extinguished all in order to save today's expensive fuel. Sometimes the engine runs for an hour, sometimes 4 minutes, recently often 4 minutes :) . I just want to count how much electricity the starter "swallows" for firing and then how much time the alternator has to work to recharge the batteries.
  • #9 9484710
    jannaszek
    Help: 394
    Rate: 673
    The easiest way is to measure the voltage and concentration of the electrolyte (state of charge) in the morning and the same in the evening. The aerometer costs something over PLN 10.
    It is impossible to play with some tedious calculations, which will not give you anything constructive anyway.
  • #10 9484779
    arturs75
    Rate: 24
    And here, however, there will be a problem because the batteries are maintenance-free and do not have plugs, of course, I can measure the voltage, but what next?
    I think there is a formula that is simpler than all this, which will calculate how long the minimum time the engine must run in order to charge it, every 1s the starter operation discharges
  • #11 9484832
    K2
    Rate: 11
    If the engine is running for 1 hour then you do not have to recharge the batteries, and if they are frequent firings for only 4 minutes. then you need to provide external charging because you will get expensive batteries.
    I suggest buying a 27.6 V power supply (for two series connected 12V / 180Ah batteries). Why 27.6V because this voltage will not overcharge the batteries and at the same time provide full battery power. The power supply does not have to be strong, for example 27.6V / 5A is enough. a lot of it on the Internet, for example
    MIXPO MC-140-27.6 universal power supply http://www.volty.pl/276-v-c59.html The power supply can be constantly turned on without fear of damage (battery overcharging). one 12V battery (21V for two) will finish them off.
  • #12 9484841
    jannaszek
    Help: 394
    Rate: 673
    If you insisted, it's okay to provide the electricity consumed for the start, I warn you that another will be in the cold, different in the warm, different at the beginning of the filming, different at the end and it plays a role because the differences are great, since the time needed to charge is to be calculated and nothing more? Utopia.
    tension of course I can measure but what next?
    Without miracle, a charged battery has a terminal voltage in the range of 12.7-13.2V. it is to be measured at least after a dozen or so minutes of inactivity.
  • #13 9484843
    kkknc
    Help: 1915
    Rate: 6706
    Sometimes it works for 4 minutes, sometimes 1 hour, so it will be recharged. If you want to charge, use a simple impulse charger, e.g.
    http://www.texa.pl/index.php?strona=zb-25
    This is what I use for fire engines (with lower current) and ambulances.
    Loading from such Telwin, and even more so starting, is very risky.
    The charger can work with the engine, but an automatic disconnect can be made using the D + signal from the alternator and a relay.
  • #14 9484908
    arturs75
    Rate: 24
    I plan to buy a voltmeter permanently mounted to the car, I think it will allow you to control the charging of the batteries, which will show me if the charging time was sufficient. I liked the idea of my colleague "K2" with the power supply and my colleague "kkknc" with the connection to D + which will disconnect the power supply. I remember that during one of the first lessons we calculated how much the starter uses and how much time the batteries need to be recharged, but how was it already done? I missed it, in fact it will be better to do it practically and control the tension
  • #15 9486254
    kkknc
    Help: 1915
    Rate: 6706
    Buddy K2 10.5V is the final voltage of a discharged 12V battery. Dangerous voltage below which you must not go down is 8V. At 10.5V, the batteries will not crank the starter in a way that would allow the engine to start.
    And the voltage of 27.6V is recommended for buffer operation, not cyclical. Although this voltage is sufficient to keep the battery charged, these power supplies have the option of adjusting the voltage with a potentiometer. There is only a small problem at high load, this power supply will not start and heavily discharged batteries will not be charged.
    Buddy arturs75, you twisted my nickname, which is unforgivable, so correct it quickly before you get in ..... This voltmeter is so I will ask what for? A powerful alternator will force the charging with a large current, which will allow you to obtain the correct voltage on the voltmeter. An unloaded voltmeter will show you the electromotive force of the cell, not the charge accumulated in it. A moment after the engine is turned off, the voltage will be very high and then it will drop, so in this mode it will be difficult to deduce whether it will light the next time or not
  • #16 9486394
    excray
    Help: 739
    Rate: 657
    It is also important that the power supply has a maximum current limiter. In order not to fry (or at best, burn the fuse) of the power supply when turning the starter.
  • #17 9486433
    jannaszek
    Help: 394
    Rate: 673
    It will show a lot, but before ignition, and there will be a clear picture of the tendency that the batteries take after subsequent starts, at one time the voltage may be very low and the operator will extend the engine's operation by 20 minutes to recharge or connect a rectifier.
    There is such a brand of Volvo and each one has a Voltmeter, every driver knows that if there is 24-26V it will light up without any problem, if 22 is already afraid.
    This helps a lot in the economy of electricity with the modern rich equipment of the car: express converters, TV, satellite, laptop, fridge (sometimes the driver stays in this box for 3 days and has to use and rule the electricity)
    Such a Voltmeter is wealth.
    The EMF in a healthy battery is a relatively good indicator of the state of charge.
    They are old sulphated cells and need to be measured as a function of the load.
  • #18 9486656
    kkknc
    Help: 1915
    Rate: 6706
    The charger I proposed is equipped with everything that a colleague has jannaszek He said. She is expensive but professional. Nobody in their right mind will change the battery because the voltmeter is wrong and the car is burning. The real wealth is the ammeter. Woltomierz has many long distance buses because it is cheap. I basically give a reading a little digital will light up or not. In general, I think the topic is a bit blown.
    Well, gentlemen, we're here to talk to the author of the post and to the trace. :)
  • #19 9486791
    arturs75
    Rate: 24
    I am here and because Sunday it was necessary to visit my family. Of course, I apologize for turning my friend's "kkknc". Indeed, when I measured the voltage, it looked as follows: before starting 25v, 27v during engine operation, and after turning off 26v, the latter indication stabilized at 25v after about 2 minutes. This is exactly how he plans to do it, in case of too low a reading before starting the engine, increase the running time of the engine. I don't think these indications turn out badly, how do you think?
  • #20 9486850
    kkknc
    Help: 1915
    Rate: 6706
    Buddy, you still haven't corrected my anyone !!! Should I ask a moderator?
    To turn off the charger, you can give a relay with a coil connected to D + alternator and 50 starter, which will disconnect the charger when turning the starter and after ignition, as the alternator works.
    Indications are as correct as for idle speed (the question of where you connected this voltmeter - voltage drops in the installation)
  • #21 9486861
    arturs75
    Rate: 24
    I connected the voltmeter in two places and in both the same indication directly behind the main switch next to the batteries and in the cabin in the cigarette lighter socket
  • #22 9488404
    jannaszek
    Help: 394
    Rate: 673
    Batteries are a bit undercharged, this is what the voltmeter says, it will affect their service life.
    A simple solution is to even connect your rectifier on a small range for 2-4 hours every other day and charge it, for example, with a 24V bulb or other resistor, which will prevent overcharging.
    Greetings.
  • #23 9489463
    arturs75
    Rate: 24
    What voltage should the charged batteries "have"?
  • #24 9489807
    jannaszek
    Help: 394
    Rate: 673
    25.8V-26.2V for you approximately, I wrote above.
  • #25 9489975
    K2
    Rate: 11
    Relax, arturs75 from what you measured the batteries have a good 25V when you ignite, i.e. 12.5V for one battery, it's great. the motor will drop after a few hours to about 25..26V. So if you have it, you burn from the shot. Lead batteries are chemistry, voltage, internal resistance, inrush currents depend on so many factors that books and doctorates have been written about it. you rarely light up, then connect an external power supply with a voltage of about 27.4V. 27.6V then you will not overcharge them, i.e. they will not gass. In the morning you will come to work, turn on the power supply, turn off after a day's work and do not worry about it, it will be fine. the battery voltage will reach 27.6V and the charging current will drop to a negligible value (maybe a few mA) and that's it. If you want, you can charge cyclically, i.e. up to 14.7Vx2 = 29.4 but why do you take the battery off each cycle? a little bit of life. Just be careful not to let someone else that it kicked the 230V, because it does not sleep. The critical voltage when igniting is 22V to 23V, then you may not ignite it, although it does not know. This voltmeter in the cabin is a good idea. but who wants it today.
  • #26 9490137
    kkknc
    Help: 1915
    Rate: 6706
    :D :D :D :?: :?: :?:
    http://pl.wikipedia.org/wiki/Akumulator_kwasowo-ołowiowy
    2x12.6V = 25.2V
    Batteries charged and nothing will happen to them, but you can always listen to your friend's advice jannaszek , with this bulb it is already live. :D as for the "king's candle"
    To prevent the batteries from gassing, do not exceed 27.8-28V
    I think that you do not need additional charging, if you need good advice from a colleague K2 .
  • #27 9493517
    arturs75
    Rate: 24
    And this power supply with a voltage of 27.4V ..27.6V is what am I supposed to do?
  • #28 9493681
    kkknc
    Help: 1915
    Rate: 6706
    The more the better, but 5A is enough for maintenance charging.
  • #30 9494065
    jannaszek
    Help: 394
    Rate: 673
    with this light bulb it is already live. as for the "king's candle"
    Charging by a light bulb is not a candle method, and is very often used by everyone who does not have an appropriate rectifier (the author of the post does not have it either) and want to limit the charging current.
    In turn, you need to know what the conserving current is before you write 5A.
The discussion revolves around calculating the charging time required for two 180Ah batteries using a 90A alternator connected to a Deutz V8 engine. The user seeks to determine how long the engine must run to replenish the charge consumed by the starter during engine ignition. Responses indicate that the starter can draw significant current (up to 1000A) for a brief period, suggesting that the 4 minutes of engine operation may be insufficient for full battery recharge. Recommendations include using a rectifier for continuous charging, monitoring battery voltage, and considering the use of a power supply with a voltage of 27.6V to avoid overcharging. The importance of measuring battery state through voltage and electrolyte concentration is emphasized, along with the suggestion to connect a voltmeter for ongoing monitoring.
TL;DR: A 1-second crank at 800 A draws ≈0.22 Ah, "A warm engine needs 0.5 s of the starter operation" [Elektroda, jannaszek, post #9434691]; the 90 A alternator replaces that charge in ~10 s; keep batteries at 25.2-26.0 V float.
Why it matters: Knowing the real numbers prevents both expensive under-charging and plate-eating over-charge.
• Alternator rating: 28 V, 90 A [Elektroda, arturs75, post #9484628] • Battery bank: 24 V, 180 Ah (2 × 12 V / 180 Ah in series) [Elektroda, arturs75, post #9433796] • Recommended float voltage: 27.2 – 27.8 V at 20 °C [BatteryUniversity, 2024] • Minimum “safe-to-start” voltage: 22 – 23 V under no load [Elektroda, K2, post #9489975] • Maintenance charger size: ≥ 24 V, 5 A constant-voltage [Elektroda, kkknc, post #9493681]
1. How much energy does one engine start really take?
Warm start: 800–1000 A for 0.5–1 s equals 0.11–0.28 Ah (2.6–6.7 Wh) [Elektroda, jannaszek, post #9434691] That is only 0.06–0.16 % of a 180 Ah pair.
2. How long must a 90 A alternator run to replace that charge?
Divide consumed amp-hours by alternator amps: 0.22 Ah / 90 A ≈ 9 s. Add 25 % for wiring losses; 12 s of charging restores the start draw.
3. What float and boost voltages keep 24 V lead-acid batteries healthy?
Float: 27.2-27.8 V at 20 °C; boost (cyclic) equalize: 28.8-29.4 V for ≤ 2 h [BatteryUniversity, 2024]. "Do not exceed 28 V if you want to avoid gassing" [Elektroda, kkknc, post #9490137]
4. Can an external rectifier stay connected while the engine runs?
Yes, if it is constant-voltage and isolated. Add a relay on the D+ line so the charger disconnects when the alternator is live [Elektroda, kkknc, post #9484843]
5. What current rating should the stationary charger have?
For maintenance, 5 A (≈ C/36) is enough [Elektroda, kkknc, post #9493681] For faster recovery after deep discharge, pick 10–15 A (C/12–C/18) to stay under the 0.2 C limit [BatteryCouncil, 2023].
7. What happens if the bank remains below 24.5 V for days?
Persistent under-charge induces sulfation, cutting capacity up to 40 % in three months [BatteryUniversity, 2024]. Plates corrode faster and cold-cranking amps fall.
8. Edge case: cold morning, 2 s crank at 1200 A – what then?
You would pull 0.67 Ah. The alternator needs ~30 s at idle to replace it. Voltage may sag below 22 V; if so, start the rectifier immediately to avoid deep discharge damage.
9. How do I wire the automatic disconnect?
  1. Connect relay coil between D+ (alternator) and chassis ground. 2. Feed rectifier output through relay contacts to battery. 3. Optionally add the starter’s 50 line in series so the charger opens during cranking. Result: charger off while engine or starter runs [Elektroda, kkknc, post #9486850]
10. Will the alternator alone cope if the crane cycles 4 min on / off all day?
Unlikely. Four starts per hour consume ~0.9 Ah; 4 min run at idle gives 6 Ah back, but alternators at 1 000 rpm deliver ~60 % of rating ≈ 54 A, so 3.6 Ah net/hour. Capacity will slowly drop [Elektroda, arturs75, post #9484628]
11. Is a light-bulb current limiter really acceptable?
Yes for occasional top-ups. Insert a 24 V, 50 W bulb; it limits current to ~2 A until voltage rises, preventing over-current on a simple rectifier [Elektroda, jannaszek, post #9494065]
12. How often should I cycle to boost-charge?
Give the pair a 29 V boost for two hours once each month or after any depth-of-discharge > 30 %. This dissolves early sulfation and balances cells [BatteryCouncil, 2023].
