Starting an Engine While Battery is Charging: Safety and Technique?
Dj.McG 66947 4
  • #1 5403614
    Dj.McG
    Level 19  
    Rate: 93
    My battery was completely discharged, I connected it to the charger, I charged it 5 to 10 minutes, I disconnected the clamps, I wanted to fire on the starter, turned once and the battery fell again
    So I wonder if it is possible to start the engine while charging the battery?
    I request information
  • #2 5403624
    viper555
    Help: 582
    Rate: 2157
    In 10 minutes, you can even light the lamp inside and not start with the starter
  • #4 5403688
    Dj.McG
    Level 19  
    Rate: 93
    elektrit wrote:
    Can not. Even if you succeed, the deeply discharged battery will significantly overload the alternator, which will cause the winding to overheat and possibly the rectifier failure, because the alternator is a voltage source, not a current one.
    I think so too, I just needed to be sure
    in general, my rectifier is a huge old Russian machine that is able to transmit a large current
  • #5 5403950
    kwok
    Level 40  
    Help: 493
    Rate: 1336
    the rectifier may be large, but it probably will not give several hundred amps and therefore it fires from the second battery
    And the fact that a heavily discharged battery loads the alternator is true, but the alt should not burn anyway and that sometimes it happens it is a result of the trash produced in newer cars
