Extracting Windows 7 64bit Product Key from MSDNAA Account for Formatting Purposes
lenek34 122698 11
How can I extract the Windows 7 64-bit product key from my MSDNAA installation before formatting?
Windows 7 64-bit product keys are often not recoverable with the usual registry-based tools, which is why they show BBBBB-BBBBB-BBBBB-BBBBB-BBBBB [#9469071] One reply says the free WinGuggle program can extract the key on Windows 7 64-bit, and that it worked in version 2.3 for 64-bit systems [#9903899]
  • #1 9468944
    lenek34
    Rate: 12
    I have original Windows 7 32bit (PC) and 64bit (laptop) from MSDNAA account, due to the fact that I graduated, my account has been disabled and I cannot see my series, I have CDs.
    How to read / extract product key (serial) in Windows 7 64bit? Because I want to do a format, and I haven't saved the series anywhere.
    There are some programs on the net that take out the keys. With Windows 7 32bit no problem, each program shows fine (I had a 32bit key written down). When he tries Windows 7, 64bit always shows me BBBBB-BBBBB-BBBBB-BBBBB-BBBBB. I have already used the following programs: Everest Ultimate, winproductkey, Win_Key_Finder, ProduKey, SoftKeyRevealer none of them helped on a 64bit system.
  • #2 9468984
    donek901
    Help: 5
    Rate: 32
    Have you tried Sunrise Seven?
  • #3 9469060
    lenek34
    Rate: 12
    Also shows: BBBBB-BBBBB-BBBBB-BBBBB-BBBBB
  • #4 9469071
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    You will not recover the key because it is not stored in the registry. Therefore, BBBBB is displayed.
  • #5 9899656
    Matuzalem
    Help: 1653
    Rate: 1101
    lenek34 wrote:
    ... I graduated, my account has been disabled ..., ... wants to do a format, ...
    Your wish, in this part, causes the loss of legality (verification, e.g. by the installation date is possible immediately), and thus do not look for the key, because he can only get a doghouse.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #6 9903899
    marcinpalasz
    The key in Windows 7 64-bit is easily removed with the free WinGuggle program (I checked it on version 2.3 for 64-bit systems).
    Maybe someone else will find this information useful.
    Greetings!
  • #7 9970667
    Jendkier
    I am a student and I also have Wondows from the university. Unfortunately, I have to format the disk and I have not written the code anywhere. When using the above programs, I have the same problem as the author. Do you see any solution?
    PS. I cannot go to university.
    Windows *
  • #9 9970872
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    As an MSDN user, you have an account on the Microsoft server for which you should have a login and password. there you can personally check what the generated installation code is.
  • #10 9999945
    ravmar
    Help: 5
    Rate: 74
    I have a similar problem, with the difference that I am still studying, but it's time to reinstal. Unfortunately, I do not have the key or the installation image, because I fired. On my MSDNAA account in the history tab, I do not have a single item, the history is empty, and I can not download the other Win7 because they have it saved in the database, that I already have one and what should I do now?
    Greetings!
    It doesn't work at all
    As a colleague wrote
  • #11 10000271
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    ravmar wrote:
    On my MSDNAA account in the history tab, I do not have a single item, the history is empty, and I can not download the other Win7 because they have saved in the database, I already have one and what should I do now?
    Advertise bad operation of the MSDNAA database.
  • #12 10000313
    Pawell_88
    Help: 5
    A very valid point. Under the terms of the MSDN AA license, a student after graduation may use the operating system until the system is reinstalled. If you're not already studying, you might as well download Winde from torrents and it'll work out. And so it will be software used in violation of the license terms (i.e. pirate).
The discussion revolves around the challenge of extracting the Windows 7 64-bit product key from an MSDNAA account after account deactivation due to graduation. The original poster has both 32-bit and 64-bit versions but can only retrieve the 32-bit key. Various software tools like Everest Ultimate, ProduKey, and Win_Key_Finder have failed to extract the key, displaying a placeholder instead. Suggestions include using the WinGuggle program, which reportedly works for 64-bit systems, and the Magical Jelly Bean Keyfinder, which is claimed to successfully retrieve the key if it exists. Some participants mention the limitations of the MSDNAA database and the implications of using software outside of licensing terms.
