Office 2016 - Recover Product Key for Home & Business Edition on Win 8.1 &32bit Office
kontownik 10512 4
  • Need a method to recover Office 2016 key
    #1 17480467
    kontownik
    looking for some sensible way to recover office 2016 Home and Business product key
    I have already tested many different types of programs and none showed the key even did not detect that office 2016 is installed and activated
    I've only come to the last 5 characters through cscript
    system description:
    Windows 8.1 64bit
    Office 2016 32bit
    if someone knew a solution to this problem I would ask for info
  • Office 2016 key likely tied to Microsoft account
    #2 17480468
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    Welcome. From what I read only the last characters are stored in an explicit form, the entire key is encrypted in the registry. Therefore, key extraction programs cannot see Office 2016 (and the older version of 2013 also). Nowhere did I find information on how to get the key from this character.
    Have you contacted Microsoft support to help solve your problem? Probably the product is assigned to a Microsoft account, the manufacturer should best help in this topic.
  • Microsoft hotline can map keys to product identifiers
    #3 17480475
    Borygo123
    Help: 122
    Rate: 196
    In this case, I don't know if the MS helpline can help. Once I had to determine which license was used on one of the computers (I had 2 the same packages and 2 different keys). I had to provide both keys and product identifier and only after that I got the answer on the hotline that this particular key is assigned to a specific product identifier. The other key remained unassigned and I could use it. You couldn't do the opposite.
  • #4 17483030
    kontownik
    and here is the problem
    microsoft won't help
    and the last 5 characters do not arrange me because I have office 2016 installed on 10 computers and 2 boxes with keys and accounts
    so i don't even get my keys back
  • #5 17483444
    Borygo123
    Help: 122
    Rate: 196
    If you have 10 keys on 10 computers, then the MS telephone will arrange you. You provide all computer codes and keys and the method of elimination (provide codes from the other 9 computers) will give you the one key you are looking for.
