B 196 Transistor in TO-126 Case: Identification and Suitable Replacement Options
LA72 4644 3
  • #1 9504144
    LA72
    Help: 648
    Rate: 1658
    What is this transistor?
    B 196 in the TO-126 housing.
    The transistor is located in the receiver of the helicopter model.
    I need his output and / or replacement.
    Thank you in advance.
    sq8luv
    In the TO-126 case, it is possible to use transistors with the number 196
    BD196, see here: DESCRIPTION AND , or here: ,
    or HBD196, see HERE , but this is an audio amplifier.
    Unless it's about the BF196 in the TM-1 case, but you probably did not :)
    pozdr
  • #3 9544141
    Andrzej59
    Help: 49
    Rate: 43
    This is 2SB196
  • #4 9614559
    LA72
    Help: 648
    Rate: 1658
    This is however the transistor HBD196.
