[Solved] What is the transistor? Motherboard TP.MSD309.BP85, Tv Blaupunkt B40A133TCFHD
leo59vb 3549 4
  • #1 17477343
    leo59vb
    Please help me to decode the SMD transistor with the WyG4B designation. I have dug a lot of catalogs available on websites, but I have not found such a designation. The transistor works as a 12V switching key, the designation on the QM12 board.
    mirex
    Help: 1950
    Rate: 1990
    ME2325 or any other p-fet.
    Moderated By Artur k.:
    And maybe for example MMBFJ270? It can not !, because if it's already P-MOSFET, P-FET is definitely not a very precise concept, which may suggest a slightly different kind of field effect transistors. Any other can not be either, because this is so-called. "logic level".
    I suggest to learn about the differences between the types of field effect transistors.
     3.1.11. Do not send messages that do not contribute to the discussion. They are misleading, dangerous, or not a user problem.
    • MQTSUKI ME2325-G Wy marking.pdf (1.2 MB) You must be logged in to download this attachment.
  • #3 17477521
    leo59vb
    Thanks a lot. Greetings.
  • #4 17755354
    hassanelektro
    Rate: 26
    tell me you find flach eprom j have the flash of this map sea
  • #5 17788782
    leo59vb
    I applied according to the "mirex" ME2325 and successfully fulfills its role. Thank you and finish the topic.
