Thermostatic mixer or mixer - question about the principle of operation and reco
Starkes 36232 11
How does a thermostatic mixer differ from a standard mixer, and when should I use one for sink taps?
A thermostatic mixer keeps the outlet water temperature constant by automatically adjusting the hot/cold mix, while a standard mixer only mixes water manually and cannot compensate for inlet temperature changes [#9514925][#9518816] Its thermostat is mechanical, not electronic: it works by thermal expansion, where a sealed gas-filled element moves the valves as temperature changes [#9515105][#9515771] For correct operation, the hot inlet must be at least as hot as the desired outlet temperature and the cold inlet must be at or below it [#9514925] Many models also have a safety lock around 38°C that requires pressing a button to go hotter, to reduce the risk of burns [#9515771] If you want one central solution for multiple draw-off points, a three-way thermostatic valve can be installed in the boiler room and set to a constant temperature; otherwise you use thermostatic taps at the individual sinks [#9516924]
  • #1 9514749
    Starkes
    Level 19  
    Help: 5
    Rate: 43
    I am considering a choice for the sinks at home.
    I have thermostatic mixers on the bath and in the shower, but at the sinks I think about the mixer (it's probably a three-way valve, if I'm not mistaken).
    Can someone explain the difference in action?
    I found on the net "description of the thermostatic battery operation", but you might as well write that the bulb just shines ...
    http://muratordom.pl/lazienka/baterie/jak-dzi...rmostat-w-baterii-termostatycznej,49_211.html
    "The heart of the thermostatic mixer is the thermostat installed in it, which is responsible for maintaining the set water temperature. It controls the mechanism that mixes cold and hot water."
    Plumpi
    Heating systems specialist
    Help: 874
    Rate: 2674
    tc - hot water inlet temperature
    tz - cold water temperature at the inlet
    tw - outlet water temperature
    The thermostatic mixing valve maintains a constant outlet temperature, regardless of the inlet water temperature. The condition for the correct operation of such a valve is that the hot water temperature at the inlet must be equal to or higher than the temperature that we want to obtain at the outlet, and that the temperature of the cold water must be equal to or lower than the water temperature that we want to obtain at the outlet.
    Condition:
    tz =
  • #3 9515009
    Starkes
    Level 19  
    Help: 5
    Rate: 43
    OK - very nicely explained (thank you - he also helped "he went"), but please tell me how it is implemented (that the light source in the bulb is the filament through which
    current flows, heats up and glows and emits light).
    Otherwise - how does a faucet without electronics know how much hot water to mix with how much cold water?
    And possibly damage to the battery can cause burns?
  • #4 9515105
    Plumpi
    Help: 874
    Rate: 2674
    It is inexplicable and you have to take it on faith ;)
    The battery has a built-in mechanical thermostat which continuously measures the temperature of the water at the outlet and controls the mixing valve. This works on the principle of thermal expansion.
    I do not know. Somehow I have not encountered such damage to the battery. Typically, this was a damage that was leaking but not affecting the operation of the thermostat. Some faucet models have an additional built-in element to prevent hot water from flowing out. This is called the "safe" function. Unfortunately, I do not know the details of the construction of such batteries. Somehow I did not have the opportunity to disassemble them.
  • #5 9515187
    serwisant73
    Help: 188
    Rate: 1260
    Standard DHW temperature is max. 55 degrees. you are unlikely to burn yourself with this.
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    The thermostat in the battery is never electronic, but mechanical - it works on the principle of thermal expansion (a tight vessel filled with gas, which, under the influence of temperature, expands and moves valves; the thermostat in thermostatic heads for radiators and in the cooling systems of car engines works similarly). Many faucets have a lock that prevents the water temperature from turning up to more than the standard 38 degrees without pressing the lock button (so you don't burn yourself). In general, these are very different models of such batteries.
  • #7 9515911
    Starkes
    Level 19  
    Help: 5
    Rate: 43
    Zbigniew Rusek wrote:
    ... but mechanical - operating on the principle of thermal expansion (a tight vessel filled with gas, which expands under the influence of temperature and displaces the valves; the thermostat works similarly in thermostatic heads for radiators and in cooling systems of car engines). Many faucets have a lock that prevents the water temperature from turning up to more than the standard 38 degrees without pressing the lock button (so you don't burn yourself) ...
    And that's what I meant ...
    So there is no need to pack in the mixer ...
    I buy valves and ultimately touchless faucets ...
    Also went well deserved helped ...
  • #8 9516924
    kabee84
    Help: 39
    Rate: 164
    Buddy, it depends what three-way valve we are talking about ...
    There are three-way thermostatic valves (eg Honeywell TM 200), which work in the same way as a thermostatic mixer, ie they mix water to a set temperature. By installing such a valve, e.g. in a boiler room, we have a constant water temperature at all points of consumption and we do not have to invest in thermostatic batteries for individual points ...
    Such a valve makes sense.
    It is different, e.g. in an apartment, where we cannot connect such a valve ... In this case, we are left with thermostatic batteries.
    FEMAX Łazienki. Ogrzewanie. Instalacje.
    Szczęśliwa 25, Gdańsk, 83-110 | Tel.: 664 XXX XXX (Show) | Company Website: femax.pl
  • #9 9517131
    Starkes
    Level 19  
    Help: 5
    Rate: 43
    But I think about such valves (and wrote) - how else do you want to connect it to a contactless battery?
  • #10 9517700
    Plumpi
    Help: 874
    Rate: 2674
    We did not understand each other.
    What I described are three-way mixing valves, which is what you asked about.
    But you meant three-way thermostatic valves.
    As described by kabee84, it is enough to have one such valve with the appropriate capacity installed in the boiler room.
  • #11 9518273
    kabee84
    Help: 39
    Rate: 164
    A non-contact faucet is often a thermostatic faucet. One does not exclude the other.
  • #12 9518816
    Starkes
    Level 19  
    Help: 5
    Rate: 43
    Thanks to everyone for the information - for my part, I consider the topic exhausted.
    To sum up - if you want to regulate the water temperature and you are not sure about the supply temperature (or the temperature is variable), an ordinary mixing valve is not enough and a thermostatic valve or a thermostatic mixer should be used.
The discussion revolves around the differences between thermostatic mixers and standard mixers for home sinks. A thermostatic mixer maintains a constant outlet water temperature by using a mechanical thermostat that operates on the principle of thermal expansion, ensuring safety against burns. In contrast, a standard mixer may not provide consistent temperature control, especially if the supply temperature varies. The conversation also touches on the use of three-way valves, which can function similarly to thermostatic mixers in certain installations, such as boiler rooms. The consensus is that for reliable temperature regulation, especially in variable supply conditions, a thermostatic valve or mixer is recommended over a standard mixing valve.
