Calculating Lift Force of a Propeller: Using Zhukovsky's Coefficient, Fluid Density, Wing Area
Janadamis 18314 3
  • #1 9703220
    Janadamis
    I have a problem I want to calculate the lifting force of a propeller
    Because I want to know what surface area, angle and rotation it must have in order to lift the appropriate weight.
    I'm talking about such an arrangement of propellers as in the main rotor of a helicopter
    I found such a formula:
    http://upload.wikimedia.org/math/0/a/e/0ae45f85f5362024a34386396cd5a802.png
    where:
    * Pz – generated lift force (kG)
    * Cz – lift force coefficient, calculated theoretically for the first time by Zhukovsky, but determined mainly empirically, depending on the angle of attack, but also on the shape of the body.
    * ρ – density of a fluid (air at sea level 1.225 kg/m3)(according to the international standard atmosphere – at an altitude of 0 m at +15 degrees Celsius is 0.1249 kG•s2/m4)
    * S – wing area (m²)
    * V – velocity of the body relative to the fluid (m/s)
    example: Assuming that: S=30m2, V=180 km/h (50 m/s), ρ=0.125 kG•s2/m4, Cz=0.7 the lifting force will be 3281 kG.
    Now I have questions
    How to calculate the "Cz"?
    The result gives as much as these propellers will carry?
    And where is given the propeller's contour after all, it also depends on it.
    Or unless this is not the formula is supposed to be.
    Please answer.
  • #2 9704413
    Zbych034
    Help: 550
    Rate: 1417
    You have the angle of attack in Cz
  • #3 9705189
    Janadamis
    Aha thanks
    Are you able to replace ??
    "V m/s"
    to
    "V rpm".
  • #4 9723931
    Zbych034
    Help: 550
    Rate: 1417
    Quite different units ;) Of course you can convert rpm to average rotor blade speed
