How to connect? And what? Is Component YPbPr cable the same as 3x Cinch?
szczwany 55350 19
Is a 3x cinch cable the same as YPbPr/component or composite AV, and will I get better picture quality from component or SCART than from a regular cable?
YPbPr/component is not the same as composite AV: a 3x cinch set can be either component video or composite video plus audio, and YPbPr carries picture only, so sound must be connected separately with red/white audio leads [#9769065][#9769649][#15842521] If the source and TV support it, component is worth using because it gives a clearly better image than composite, while RGB over SCART is the best analogue option [#9769065][#15842808] A “good” cable matters, but the connection type matters more than the label on the cable [#9769065] If you get no picture, check the source settings: one user solved it by changing the DVD output from RGB to YPbPr in the menu [#15844229]
  • #1 9768920
    szczwany
    Hello. I have a few questions:
    1. Is Component YPbPr cable the same as 3x Cinch? Is it worth connecting the decoder with this?
    2. YPbPr is the same as Cinch audio / video?
    3. Will I get better quality with a GOOD VCR cable than with a regular EURO?
  • #2 9769062
    Pablo1964
    Moderator
    Help: 507
    Rate: 641
    Ad.1. There are different 3xcinch cables. One of them is component. Another composite AV.
    Ad.2. Not.
    Ad.3. What do you call a good VCR cable?
  • #3 9769065
    irekr
    Help: 1192
    Rate: 1239
    1. YES if there are three chinches on each side.
    2. You posed a question unclear. The YPbPr signal is nothing more than three video channels where the Y cable carries the luminance signal (black and white) and two red and blue color difference signals (green is reproduced during matrixing). In terms of "cable" it is the same set of three shielded wires. So in such a connection to send audio you also need to connect the L / R sockets.
    Typical Video consists of two cables for audio and one for video where the so-called composite signal is fed.
    3. What do you mean by "good VCR cable". A typical EURO / EURO cable can also be of good quality, and the EURO connection will always be the best if you choose RGB rather than VCBS (video). As for analog connections, the RGB connection method is the best in terms of quality, as the entire process of decoding, matrixing or time unevenness of individual paths is avoided.
  • #4 9769649
    Pablo1964
    Moderator
    Help: 507
    Rate: 641
    Ad 2. In my opinion, the question is clearly formulated, so I gave a simple answer. Cinch audio video is the common name for composite video + audio (L + R) connection. There are also 3 cables with cinch terminals in total. The component YPbPr connection, on the other hand, transmits only the video signal via 3 cables (terminated with cinch). The details were perfectly described by my predecessor.
  • Does a digital-marked 3x RCA cable support YPbPr?
    #5 15842356
    Piotr_Poznan
    Rate: 24
    Good morning,
    I connect to this topic. I have a new Samsung TV and an older DVD with Component YPbPr or Composie or SCART output. TV doesn't have SCART so it doesn't work but has Component and Composite (shared partially). I bought a thick shielded 3xcinch cable (it has a digital inscription on the insulation) and I thought it was enough to connect the picture and sound, but it does not work. The same cable connected to Composite (Video + Audio L + R) works. And now the question:
    Component does not work because YPbPr is just a TV picture is so intelligent that it "sees" that there is no audio anywhere and therefore reports no signal Component or (I read it somewhere on the Internet) YPbPr connector must have an analog cable as analog and does not work is it because mine has a digital inscription and is dedicated to YCbCr ??? Thanks in advance for the hint.
  • #6 15842386
  • DVD player has only YPbPr output, no switch
    #7 15842414
    Piotr_Poznan
    Rate: 24
    mihal2002 wrote:
    Piotr_Poznan wrote:
    The TV has no SCART
    Everyone has.
    Set the output on the DVD to be used by yourself.
    And if the cable says that it was made in Japan, it won't work for you?
    And the topic is assumed to be its own and not an archaeologist.
    Thanks for the add. But:
    There is no switch on DVD, only YPrPb.
    As for the archaeologist: recently, when I assumed my own, there were claims that they were similar before, so ...
  • #8 15842458
  • #9 15842472
    Piotr_Poznan
    Rate: 24
    I'll check the possibilities in the DVD menu. And I will let you know if it helped.
    The TV does not have SCART.
    Another question 3xcinch YPrPb transmits only the image or the sound as well?
  • YPbPr carries video only; red and white RCA carry audio
    #10 15842521
    jesion40
    Help: 100
    Rate: 127
    mihal2002 wrote:
    And the TV has a scart input.
    I suggest optimistically assuming that the author of the topic knows better, and if it bothers a friend, you can say that he has, but e.g. broken / occupied / inconveniently placed ...
    Picture only, as it was explained above. Additionally, you need to connect the DVD to the TV with the sound supply cable - usually two shielded cables with CINCH plugs plugged into the sockets marked in white and red.
  • #11 15842570
  • Defending component use with a suitable adapter
    #12 15842648
    jesion40
    Help: 100
    Rate: 127
    mihal2002 wrote:
    I am writing once again that it has a suitable adapter for this.
    You mentioned the adapter for the first time. Maybe it will actually tell the author of the topic something, and maybe not. If he wants to use component and he asks why should we avoid the answer and insist on using SCART?
    mihal2002 wrote:
    If he knew, he would not ask questions.
    He didn't ask about it because he knows, or at least thinks he knows. He asked about it, but for something else.
    mihal2002 wrote:
    They can be black, pink, yellow, etc.
    They can. But most often they are white and red.
    Why are you so upset that someone just wants to help the author of the topic and not scold him and instruct him what to do?
  • Questions about component video without audio and quality
    #13 15842710
    Piotr_Poznan
    Rate: 24
    Thanks for the answer. Can the TV be so "intelligent" that having YPbPr plugged in and not audio plugged in - it recognizes it as no signal or the image itself should show without sound? I am over 5 meters from dvd to tv and I would not like to buy another long 2cinch - 2cinch cable and then see that it does not work. I will add that the cable I have (3cinch-3cinch) connected to composite (video + audio L + audio R) works fine. It is also a question if I will notice the difference in the picture between the connections:
    - composite (3cinch-3cinch - video + audio L + audio R)
    and
    - component (5cinch-5cinch - YPRPb + audio L + audio R)
  • Testing audio detection and component video quality
    #14 15842808
    jesion40
    Help: 100
    Rate: 127
    Yes, it's not difficult.
    Piotr_Poznan wrote:
    I would not like to buy another long cable
    Maybe you have a short cable and some other device that is easy (for a moment) to be placed closer to provide some audio signal? it can also be a small jack - 2x cinch connected to a phone or notebook. Certainly, the TV is not so "intelligent" as to distinguish that it is not the sound. On the other hand, the connection can recognize purely mechanically (something is plugged in) or alternately impedance (something has to be connected, but the signal is irrelevant) or the presence of a signal.
    and
    Objectively, the difference will be considerable, and whether you will see it is not a technical question anymore :D
  • #15 15842841
    Piotr_Poznan
    Rate: 24
    Thanks to the evening, I will test on a short cable and write here what test results. Greetings
  • #16 15844229
    Piotr_Poznan
    Rate: 24
    I made a change in the DVD menu in the picture section, changed the output parameter setting from RGB to YPbPr and after this change by connecting the 3cinch-3cinch cable to the YPbPr sockets on the TV I got the correct image without sound. So the cable is ok. The setting in the DvD menu was important.
    But I guess I will not decide to buy another long 2cinch-2cinch cable to use the Component connection because on the DVD I could not see any significant advantage over the Composite connection in the image.
    I would like to thank both colleagues for participating in the interview. Health!
  • #17 16352944
    kamillo14089
    Rate: 15
    Hello. I have a problem, I want the sound when watching TV to spread through the speakers from the Blu-ray 5.1 home theater, what do I need for such a connection? How to connect? And what? Is Component YPbPr cable the same as 3x Cinch? How to connect? And what? Is Component YPbPr cable the same as 3x Cinch? How to connect? And what? Is Component YPbPr cable the same as 3x Cinch?
  • #18 16352961
  • #19 16353022
    kamillo14089
    Rate: 15
    Sorry, but this is the first time I use it. I searched but I'm not sure that's why I wrote here.
  • #20 16353025
The discussion revolves around the differences between Component YPbPr cables and 3x Cinch (RCA) cables. It clarifies that while both can use three cables, YPbPr is specifically for video signals (luminance and color difference), whereas 3x Cinch typically refers to composite video plus audio. Users emphasize the importance of connecting audio separately when using YPbPr, as it only transmits video. The quality comparison between a good VCR cable and a standard EURO connection suggests that RGB connections provide superior quality. A user successfully connected their DVD player to a TV using a 3x Cinch cable after adjusting the DVD's output settings from RGB to YPbPr, noting no significant visual difference compared to composite connections.
