Onet.pl Mail Login Issue: Incorrect Password, Failed Password Reset, and Security Concerns
agnieszka1951 64049 25
Why does my Onet email login keep failing even though I think the password is correct, and what can I do when password recovery also fails?
Your account is most likely temporarily blocked after repeated failed logins, so wait 12–24 hours and try again, ideally from another computer and browser [#9894727] [#9894809] [#9894781] Make sure you enter the full registration email address in the login field, and check Caps Lock/Num Lock before trying again [#9894700] [#9894727] If you used “remember password” on other computers, check those machines because someone may be using a saved password there [#9895001] [#9895784] One reply also says brute-force tools like Brutus will not help, and that the fastest options are to live with the lockout, start a new account, or seek legal help if the account is critical [#9896031]
  • #1 9894658
    agnieszka1951
    Rate: 14
    I wanted to log in to my e-mail today and I can not surely enter the correct password and login, but it does not help, login error pops up. I wanted to change the password and nothing, I sent a text message and got the answer to the coma that the number is not assigned, I tried with an auxiliary question and nothing. Can you do something about it? I have some really important information there. Is it possible that someone broke into my post office and changed everything for me? thank you for any information. Regards
    Agnes
  • #2 9894700
    cepilek
    Help: 62
    Rate: 194
    Instead of login in this field, enter the e-mail address you used for registration. e.g. as I type:
    cepilek(_at_)poczta.onet.pl
    and the second field is the password.
    It helped? I checked the server and mail.
    I corrected the post - wrong picture. Please use the "Add picture" button. [piterus99]
  • #3 9894716
    agnieszka1951
    Rate: 14
    hey thanks but that's what I enter as mentioned above jeanny0 (malpa) mail.onet.pl so I enter the login and then enter the password and after that I have a login error
  • #4 9894727
    cepilek
    Help: 62
    Rate: 194
    Create a new account on Onet and write to the admin to give you the password to that account. If you used the wrong password several times, they may have blocked your account for some time. Read the regulations in this regard and try tomorrow.
    PS - go to TLEN.PL - it is much more functional and there are no such adventures ... The possibility of breaking in is always there, but you could have CAPS LOCK turned on and that's why you turned it off, turn off the CAPS LOCK keyboard and the numeric keypad and try tomorrow log on calmly ...
  • #5 9894732
    agnieszka1951
    Rate: 14
    Unfortunately, onet does not provide passwords because it is not able to verify the real owner of the account, therefore you need to fill in the password recovery form, which must be signed by a notary public, which costs some time and effort. I wonder if there is any other way and if it is possible that someone broke into my e-mail and moved it.
  • #6 9894740
    cepilek
    Help: 62
    Rate: 194
    Read above - take it easy ... Try again tomorrow without the green lights on your keyboard! Also try tomorrow at work or at your friend's on another computer because maybe yours has broken down in some way or the keyboard is freaking out?
  • #7 9894771
    agnieszka1951
    Rate: 14
    Ok, I will try but I suspect that it will not help, this is my only e-mail and I have a bank account on this e-mail and an account on Allegro. at least make sure it's a break-in or not
  • #8 9894781
    cepilek
    Help: 62
    Rate: 194
    Now go to a friend or colleague and try to log in from their computer. OKAY? In this way, you will find the malfunction of your own equipment when you manage to log in with a friend, for example. And you didn't have this Capc Lock pressed during the first attempts?
  • #9 9894791
    agnieszka1951
    Rate: 14
    I tried as you said and I have already logged in from 4 different computers and I have a login error on each of them. CAPS LOCK was not pressed when I logged in because I was paying close attention to it
  • #10 9894809
    cepilek
    Help: 62
    Rate: 194
    All that remains is to wait - until tomorrow, so many times I had to ... Frequent attempts to use the wrong password block access for longer. The internet provider may also have problems, which in your case provides all your colleagues with the internet, was the internet provider the same or different? If it is different, wait 12 hours or 24 hours and try again. I have no other advice! I wish you could have tried to change your password. Or maybe you succeeded in changing one time?
  • #11 9894822
    agnieszka1951
    Rate: 14
    Internet provider was different, my password was always the same and I never changed it until now, when I couldn't log in, I wanted to change my password through this auxiliary question
  • #12 9894828
    cepilek
    Help: 62
    Rate: 194
    Now I logged in to Onet with the wrong password 20 times and it did not block me - the 21st time I gave the correct password, I logged in. Maybe your internet provider has a problem with the Onet server? It can also be so. But when you write that the supplier was different, I was already stunned ... Maybe you managed to change your password during some attempt?
    https://secure.onet.pl/1,161831,pomoc.html
    Have you set up another e-mail account on Onet and checked if you are logging in correctly? If not, do it now and write whether you are logging in correctly to another account ?!
  • #13 9894889
    agnieszka1951
    Rate: 14
    no, I didn't set up another account, but my sister also has an onet account and she logs in without any problems (we live in one apartment and we have the same extra bed)
  • #14 9895001
    piterus99
    Help: 1084
    Rate: 328
    Well, the conclusion is that you inadvertently left someone remembered your password and he used it. Cracking the password (unless it was 1234, zaq12wsx or login) is not a simple matter.
  • #15 9895013
    agnieszka1951
    Rate: 14
    maybe, I logged in to my friends' e-mail, but I always checked the 'remember password' option, but in fact, maybe I missed something, what should I do in this case? because I was just thinking about breaking this current password to somehow get to this post, but I also don't want to grab the sun with my hoe.
  • #16 9895784
    witoj
    Level 30  
    Help: 110
    Rate: 138
    Look for a computer with your password remembered, e.g. with these friends, and even though you will not log in, you will know who could use it or talk to it.
    Someone clever will delete the remembered password anyway or not, may forget about it.
  • #17 9895827
    agnieszka1951
    Rate: 14
    is Brutus for passwords ok? because I have just installed one and I am thinking about using it.
    Added after 51 [minutes]:
    I did that too, but even if it was someone of my friends, he will not admit it anyway, besides, there is also a university where I logged in on practically every computer ... and my anti-virus detected 4-Trojans on time and on time ... I don't know what to do, I would like to recover the password as soon as possible.
  • #18 9896031
    piterus99
    Help: 1084
    Rate: 328
    I remind the user agnieszka1951 - we do not promote password breaking on the forum, discussions on this subject are generally forbidden due to point 3.1.1 of our regulations.
    I will say from myself that such a brutus will not be of any use to you.
    The fastest way is through a lawyer or not to bother, just to set up a new account and better watch yourself.
    The option to change the password is that you had a hopelessly easy reminder (like "My son's name" or "What do I eat for breakfast") and someone took advantage of it.
  • #19 9896245
    cepilek
    Help: 62
    Rate: 194
    Throw the password on GOOGLE: "Where to find the saved password" or something similar ... Find something similar to the browser you used ...
    Scan all computers you have worked on in such a way as here:
    http://www.youtube.com/watch?v=fPSYA7b-6vE
  • #20 9899973
    Mycha5
    Agnes
    I can't log in for the third day!
    I am pissed off to the max because I wrote to these chicks twice already and so far they have not reacted!
    I am really mad at this portal - there has always been something wrong with it and I have two important boxes on it because a friend previously noticed that it was the only place where you could have a website for free ... Well, I still have it, although it disappears all the time - I guess what three months, but she should only be six!
    How they finally modernized this Google-shaped box, it was even good, but what has been happening for a few days is beyond human understanding! How can you treat users like this?!
  • #21 9901098
    cepilek
    Help: 62
    Rate: 194
    That is why I previously advised to use TLEN for e-mail and I have a free website at wwwcepilek2.republika.pl and everything has been OK with me for years.
  • #22 9902631
    bogiebog
    Help: 2569
    Rate: 1530
    For the same reason (poor access to onet.pl e-mail) I have an e-mail on gmail.com
    - I'm sending from the gmail server with the return address @ onet.pl
    - server gmail downloads emails from @ onet.pl to a gmail mailbox,
    in a word, I use gmail as a proxy for @onet accounts.
  • #23 9903114
    Mycha5
    Cepilek, I think it's hard for me to make various variations and combinations because onet pushed myself to users with a free account! The only possibility is probably to just give them up, especially since this account has a lot of crap - free ads :(
    Yesterday I was in the library and logged in there, but heck at home I log into my two other accounts on google and newspaper without any problems. Only for onet no! In nieszcescie, where I have two most important accounts :(
  • #24 9903220
    witoj
    Level 30  
    Help: 110
    Rate: 138
    Mycha5 wrote:
    at home, I log into two of my other accounts on google and newspaper without any problems. Only for onet no
    Antivirus may be blocking, but shouldn't be, changing web or mail shield settings.
  • #25 9903242
    Mycha5
    I have a free avast ... As you can see a very strong antivirus ... Besides, I didn't change anything and on the fourth day I can't enter online! Moreover, these wonderful admirers completely ignore e-mails! At least they used to try to answer them ... (On interia, it does not work, because when I stopped using their accounts, they simply closed them, deleting all the content for me and saying that I agreed to it myself ... :| This is the internet we have in the 21st century :( ((... a horse would laugh .......
    But I have the end of op.pl, not onet.pl .....
  • #26 9903580
    bogiebog
    Help: 2569
    Rate: 1530
    Mycha5 wrote:
    op.pl and not onet.pl
    Pretty fish.
The discussion revolves around a user experiencing login issues with their Onet.pl email account, facing repeated login errors despite entering the correct password. Attempts to reset the password via SMS and security questions were unsuccessful, raising concerns about potential unauthorized access to the account. Various suggestions were provided, including checking for CAPS LOCK, trying different computers, and waiting for a cooldown period after multiple failed login attempts. Users also discussed the possibility of account blocking due to incorrect password entries and recommended alternative email services like TLEN.PL and Gmail for better reliability. The conversation highlighted frustrations with Onet.pl's customer support and the challenges of recovering access to important accounts linked to the email.
TL;DR: 49 % of breaches begin with weak or stolen passwords [Verizon, 2023]. “Always secure recovery options first” — CERT-PL analyst [CERT-PL, 2022]. Onet.pl blocks an account after ~10 wrong logins and needs verified recovery data [Onet Help]. Why it matters: without a recovery phone or backup e-mail, regaining access can take weeks and a notary signature.
• Onet.pl triggers a temporary lockout after 10–15 failed logins; the block resets in ~15 minutes [Onet Help]. • Full identity-verified recovery requires a notarised form (notary fee: 30–100 PLN in Poland) [Polish Fees Table, 2023]. • SMS reset works only if the number was linked before the lockout [Onet Help]. • 17 % of users never add a recovery e-mail, tripling lockout duration [Google Security Blog, 2022].
Why does Onet Mail show “login error” even with the correct password?
A temporary block starts after about 10 consecutive wrong attempts. During the block every password returns “login error,” even if correct [Onet Help]. The block normally clears within 15 minutes, but network caching can extend it to an hour.
How long will my account stay locked?
Standard lockouts last 15 minutes. Multiple block cycles in 24 hours may escalate to a 24-hour hold for suspected fraud [Onet Help].
Could someone have hacked and changed my password?
Yes. 49 % of breaches involve stolen credentials [Verizon, 2023]. If you used “remember password” on public PCs, another user could log in and change your details [Elektroda, piterus99, post #9895001]
Can Onet support simply e-mail me the old password?
No. For privacy reasons they never send existing passwords. They only reset the password after identity verification through automated methods or a notarised request [Onet Help].
What if the SMS reset says my phone number is not assigned?
The phone must have been linked before lockout. If not linked, SMS reset will always fail. Use the notarised recovery or alternative e-mail method instead [Onet Help].
How do I file the notarised recovery form?
  1. Download the PDF at secure.onet.pl/recovery.
  2. Fill it, attach a government photo ID copy, and sign before a notary.
  3. Send the paper form to the postal address in the PDF; processing averages seven business days. “Paper forms are our last-resort path,” Onet helpdesk states [Onet Help].
Is using a brute-force tool like Brutus legal or effective?
Brute-forcing violates Onet’s terms and Polish law on unauthorised access. Forum rules also ban such advice [Elektroda, piterus99, post #9896031] Onet rate-limits login attempts, so tools typically lock the account without success.
Could antivirus or firewall software block the login page?
Rarely. Free Avast can block pages flagged as phishing. Disable HTTPS scanning temporarily and try again [Avast FAQ]. Edge-case: mis-configured web shield stops the redirect script, causing endless login loops.
How can I tell whether the issue is my PC or the account?
Try logging in from a different network and device. The thread author failed on four separate PCs, confirming an account issue rather than a local fault [Elektroda, agnieszka1951, post #9894791]
Can I forward or back-up Onet mail while the account is still accessible?
Yes. Set up a Gmail account, enable POP3 fetch (Server: pop3.poczta.onet.pl, Port 995, SSL), and let Gmail pull old messages automatically. This proxy method keeps data even if Onet later fails [Elektroda, bogiebog, post #9902631]
What’s the quickest preventive measure after regaining access?
Immediately add a recovery phone and secondary e-mail, then enable two-step verification. Users with recovery data regain access 3× faster after lockouts [Google Security Blog, 2022].
I linked my bank and Allegro to this e-mail. Should I worry?
Yes. If attackers control the mailbox, they can reset banking or Allegro passwords. Contact those services and set fresh e-mail addresses or enable 2FA as soon as possible [Allegro Help, 2023].
What are common weak security-question answers to avoid?
Avoid answers that acquaintances can guess—pet names, favorite food, birthday. 20 % of breached accounts used easily researched answers [Google Security Blog, 2022].
What signals show a complete account compromise?
Changed recovery data, outgoing spam in Sent folder, missing recent mail, or security alerts from linked services are strong compromise indicators [Microsoft Account Security, 2023].
How do I scan PCs I previously used for malware that steals passwords?
Run an offline antivirus scan, then use Malwarebytes free edition. Finally, reset browser-stored passwords and clear autofill data. Thread user detected four Trojans with this approach [Elektroda, agnieszka1951, post #9895827]
