Understanding SCANIA R380 COO Coordinator Malfunction and Engine Error - 2004 Model
Artur11GT 42988 6
  • #1 9943406
    Artur11GT
    Rate: 13
    Hello, in addition to the message entered in the title, I am still showing the error of the engine, the blocks, there is no charging and the air pressure clocks do not work. The car is burning, it is driving, the air is in the system. The car is from 2004, I bought it as damaged. Can someone "snag" something or do these glitches have no common denominator? Please help
  • #2 9946852
    igor.84
    Rate: 21
    you have a damaged coordinator or lack of so-called "COO". This is a cassette that manages all systems in scani.
  • #3 9950390
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    it would be good to connect to the computer and read errors. Something more would be known
  • #4 9950734
    multihunter
    Help: 50
    Rate: 114
    write active error codes from the clock (those with a star) from the COO system and write, I will try to help you, good morning
  • #5 9951496
    serwis_gh
    Diesel injection systems specialist
    Help: 211
    Rate: 1238
    multihunter wrote:
    from the COO system
    and also active from ICL and EMS!
    How to read error codes in Scania R?
    You probably miss Mirrora SOPS which is in ICL or some component from the complete system. It will not work without a website.
    Often such a defect occurs, for example, after replacing any component which is added to SOPS and the chassis number does not play in the parameters of this subassembly (BMS LAS GMS ICL APS).
    Mailfunction related to air pressure may be a lack of communication eg with APS no power supply etc. ... (electronic dryer with air sensors and solenoid valves)
  • #6 9953915
    szaman108
    Help: 199
    Rate: 910
    hello Artur 11gt can check the wiring harness at the front of the cab on the driver's side there are wires to the APS of the front lights sometimes can mix in the electrical system and bring a disco on the board and after connecting the computer breaks down so many errors that the wave
  • #7 9953959
    Artur11GT
    Rate: 13
    thanks to all for advice and suggestions. for the moment I noticed that someone was fumbling with a can of EBS. Tomorrow I'm going to the site. As I will find out that this is a fault and not someone's greedy hands I will share.
The discussion revolves around a malfunction in a 2004 SCANIA R380 related to the COO (Coordinator) system, which is causing engine errors, lack of charging, and non-functional air pressure gauges. Users suggest that the issue may stem from a damaged COO or wiring problems, particularly with the APS (Air Pressure Sensor) and EBS (Electronic Braking System). They recommend connecting the vehicle to a diagnostic computer to read active error codes from the COO, ICL (Instrument Cluster), and EMS (Engine Management System) to identify specific faults. The author notes potential tampering with the EBS system and plans to investigate further.
