Skoda Octavia Oil Indicator Light On: Resolving After Refilling Oil & DIY Error Deletion Options
apollo229 80308 13
Jak skasować żółtą kontrolkę poziomu oleju w Octavii po dolaniu oleju — samodzielnie czy u mechanika?
Żółta kontrolka poziomu oleju powinna zgasnąć sama po uzupełnieniu oleju; jeśli nadal świeci, sprawdź czujnik otwarcia maski / zamek maski, bo jego uszkodzenie potrafi utrzymywać lampkę [#10024919] [#10025233] [#10028151] Po otwarciu maski na ponad 30 sekund kontrola lampki powinna się wyłączyć, a jeśli problem wraca, można podejrzewać sam czujnik albo jego przewody przy zamku [#10024919] [#10033888] Jeśli chcesz mieć pewność, trzeba podjechać do mechanika na pomiar ciśnienia w układzie smarowania; gdy wszystko jest w normie, zalecana jest też wymiana oleju i filtra [#10024643]
  • #1 10024499
    apollo229
    Help: 38
    Rate: 228
    I have a question as in the subject, well, the oil light came on while driving. After checking the oil level on the dipstick, it turned out to be below the level. I replenished the missing amount right away, but the light on the board is still on, which is slowly starting to irritate. I know that you will probably "reprimand" me, that you should keep an eye on such things, but I never looked there, there were never such problems, I drove this car from change to change and it never ran out of oil and I have been driving it for two years.
    My question, can the error be deleted "at home" or will it be necessary to visit a mechanic?
  • #2 10024643
    kryzđ
    Help: 10
    Rate: 66
    Unfortunately, a visit to a mechanic and not only erasing the error, but also measuring the pressure in the lubrication system, if everything is ok, then oil and filter change.
  • #3 10024680
    apollo229
    Help: 38
    Rate: 228
    The inspection indicates that the replacement is already in 1,200 km, which is basically soon :D
    The only thing that worried me was the pressure, could it be something serious and is there such a defect often?
  • #4 10024681
    goldwinger
    Help: 534
    Rate: 2100
    It is not known how octavia, what kind of control ...
  • #5 10024723
    apollo229
    Help: 38
    Rate: 228
    Octavia 1.9 TDI 90KM 2002.
    This is the indicator, it shines yellow
  • #6 10024919
    kryzđ
    Help: 10
    Rate: 66
    The first one indicates a lack of oil pressure (red), the second - its low level (yellow).
    the yellow mark disappears by itself after the level is replenished, the red one is the service.
    When the bonnet has been opened for more than 30 seconds, the lamp
    control turns off. If no oil has been added, the indicator light will come on
    again after driving about 100 km.
    The last description is for the oil level indicator lamp, of course
    The indicator light ? flashes
    If there is a fault with the engine oil level sensor, when the ignition is turned on
    it will be signaled by an acoustic signal and switching on several times
    indicator light.
  • #7 10025233
    Pawel wawa
    Help: 1262
    Rate: 4432
    A colleague has a damaged engine hood opening sensor. And the light did not go out.
  • #8 10028124
    apollo229
    Help: 38
    Rate: 228
    But I have never had problems with it, the indicator light came on (yellow) due to low oil level, after topping up it should go out, but still on :cry:
    And what about this sensor, where can I look for it ??
  • #9 10028151
    Pawel wawa
    Help: 1262
    Rate: 4432
    In the hatch lock, the indicator light will go out after you repair the sensor.
  • #10 10032948
    apollo229
    Help: 38
    Rate: 228
    So the sensor is repairable, do you need to buy a new one?
  • #11 10033888
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4180
    Short the two wires that go to the bonnet lock for a moment. Go from the lock on the cable - you will find the plug. Unfasten the wires for a moment from the installation side and that's the problem.
  • #12 10039234
    apollo229
    Help: 38
    Rate: 228
    Yesterday I was looking for this sensor at the castle and couldn't find it. Unfortunately, it is not in my car, in fact there is a cube with two cables in such an oval housing near the lock, but there is no sensor. I don't want to shorten these wires because I don't know if they are these. The colors, if I remember correctly, are purple and I think orange.
    Is this about this cube?
  • #13 10047514
    Ireneo
    Help: 747
    Rate: 2469
    At the lock, brown and brown with red.
  • #14 10514857
    apollo229
    Help: 38
    Rate: 228
    I didn't speak for a long time, but the problem was solved by itself :D .
    Winter came to the rescue, when I took the battery out of the car for charging overnight and reconnected it, the light simply disappeared :D I also consider the problem to be solved.
    I close the topic
The discussion revolves around the issue of the oil indicator light remaining on in a Skoda Octavia after the oil level was replenished. The user initially experienced the light turning on due to low oil levels, which was addressed by adding oil. However, the light persisted, leading to concerns about potential underlying issues, such as oil pressure or a faulty oil level sensor. Responses suggest that while the yellow indicator typically turns off after oil is added, persistent illumination may indicate a malfunctioning sensor or require a mechanic's inspection. Some users shared experiences with similar issues, including a damaged engine hood opening sensor affecting the light. A solution was eventually found when the user disconnected the battery, which resolved the indicator light problem.
