[Solved] Octavia 5E 2.0tdi - 5580 -Oil Pressure Switch help in locating the sensor.
stefcio 35109 12
Where is the oil pressure sensor/switch located on a 2015 Skoda Octavia 5E 2.0 TDI CRMB, and which side is best for access?
The oil pressure switches are mounted from underneath the engine, best accessed from below near the starter; there are two of them there, one brown and one green [#18640195] The P164B00 fault was identified as a faulty brown F1 oil pressure sensor, with corrected part number 04L919081B [#18643806] The other sensor, on the right when looking at the engine, is the reduced-pressure sensor [#18643806] Because of their location, one reply recommends replacing both sensors [#18642574]
  • #1 18639817
    stefcio
    Help: 24
    Rate: 27
    Gentlemen and Ladies, I am asking for help in locating the oil pressure sensor / switch in Octavia 2015 2.0 Tdi CRMB.
    The error occurs sporadically, but more and more often, the glow plug light flashes and the car starts to slow down. Usually and most often on a cold engine. Usually, after warming up, just turn off the engine and start it again and you can drive without any problems.
    1 FaultFound:
    5580 - Oil Pressure Switch
    P164B 00 [109] - Malfunction
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 145026 km
    Date: 2020/03/26
    Time: 10:39:04
    Engine speed: 1851.00 / min
    Standard load value: 56.1 %
    Vehicle speed: 49 km/h
    Coolant temperature: 19 °C
    Intake air temperature: 41 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 14.840 V
    Unlearning counter according OBD: 40
    Fuel consumption: 7.62 l/h
    Engine oil temperature: 9.2 °C
    Status of oil pressure switches-Bit 0: 5
    Oil fill level: 53.468 mm
    Extern.temp.sens.1 bank 1: raw value: 9.0 °C
    Fuel temp. sensor 1 bank 1: raw value: 9.6 °C
    Does anyone know or have any illustrative drawings where this sensor is located and from which side it will be better accessible?
    Regards
    Stefcio
    andi731
    Help: 19
    Rate: 62
    Preferably, from the bottom, near the starter, you have 2 sensors, brown and green, marked in diagram S2
    • skodaschemat.pdf (263.03 KB) You must be logged in to download this attachment.
  • #3 18642422
    stefcio
    Help: 24
    Rate: 27
    Thanks for fast reaction.
    I have Etka 8.1, unfortunately an attempt to generate a file with the TMBKJ7NE7G0084850 wine myself resulted in the message "unknown sale type" from Etka. I looked through all the drawings that could be related to my engine or electrics, but I did not find any photos with these sensors.
    But I googled that it`s most likely these?
    04L 919 081 and 04L 919 081 A
    Octavia 5E 2.0tdi - 5580 -Oil Pressure Switch help in locating the sensor. Octavia 5E 2.0tdi - 5580 -Oil Pressure Switch help in locating the sensor.
    Replace both as a preventive measure, or do these errors and symptoms suggest any particular one?
    Could I please ask for part number A54 "Oil Pressure Regulating Valve".
    Regards
    Stefcio
  • #4 18642531
    Auto Bil
    Rate: 10
    And the sensor cables are ok?
  • #5 18642574
    andi731
    Help: 19
    Rate: 62
    You provided the correct original number, due to the location of these sensors, replace two.
  • #6 18643302
    stefcio
    Help: 24
    Rate: 27
    Does my engine have part A54 "Oil Pressure Control Valve"? If so, what is the number, if I may ask?
    Octavia 2.0tdi CRMB
    Regards
    Stefek
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    The reason for the P164B00 error is a faulty F1 brown oil pressure sensor no. corrected code 04L919081B . The second one (looking at the engine on the right) is the reduced pressure sensor. There is a pressure regulation valve in this engine, but there were no problems with it, but the issue of the sensor was known in the group.
    • Octavia 5E 2.0tdi - 5580 -Oil Pressure Switch help in locating the sensor. 20200424_140041.jpg (602.69 KB) You must be logged in to download this attachment.
    • Octavia 5E 2.0tdi - 5580 -Oil Pressure Switch help in locating the sensor. 20200424_135952.jpg (2.24 MB) You must be logged in to download this attachment.
  • #8 18664726
    stefcio
    Help: 24
    Rate: 27
    Sensors replaced with: green original and brown Febi 107974, first day approx.
    I will wait a few more days and if there are no more problems, I will close the issue.
    For now, I would like to thank everyone once again for their input and help in fixing the error.
    Ps: Does anyone know where I can ask for a wine bag for Etka? TMBKJ7NE7G0084850
    Regards
  • Oil change coincidence questioned for P164B00 fault
    #9 19398667
    kamska
    Rate: 24
    Hello, let me add to the topic.
    Golf 1.6 TDI data from 2015. and error code P164B00, the same symptoms - emergency mode during sudden acceleration with the engine not warmed up.
    Today I was at the dealership for inspection and diagnostics, a very nice gentleman said that they would have to disassemble the engine and look for the cause, and I would have to leave the car for 2 days. A man-hour of PLN 320 x 2 days = a bag of money.
    The solution to this issue shows a faulty brown sensor, but there is something that really bothers me - in my case, the problem started after changing the oil to Castrol. A friendly Bosch service tells me to start by replacing the oil with a higher quality one. The car has traveled 2,000 km since the replacement, I don`t want to believe that it could "not like the taste of the oil". Maybe it`s a coincidence?
  • #10 19399052
    stefcio
    Help: 24
    Rate: 27
    Replace sensors. After the replacement, i.e. about a year ago, I forgot that such a problem even existed.
    And by the way, it`s a nice ASO.
    Regards
    Replacing the sensors solved the problem, but I don`t know which of the two caused the problem.
  • #11 19424274
    lechm56
    Help: 112
    Rate: 368
    The topic was unlocked at the author`s request.
  • #12 19424472
    kamska
    Rate: 24
    I replaced the brown sensor - 04L919081B, problem solved, the car runs as before. When it comes to replacement, in the Golf VII, just remove the covers on the front fascia and access the long 24mm socket from the top, no need for a workshop.
    Regards
  • #13 19449069
    stefcio
    Help: 24
    Rate: 27
    Solution in topic, recent posts.
The discussion revolves around locating and addressing issues with the oil pressure sensor in a 2015 Skoda Octavia 2.0 TDI CRMB. The user reports sporadic errors indicated by a flashing glow plug light and a slowdown of the vehicle, particularly when the engine is cold. The error code P164B 00 points to a malfunctioning oil pressure switch. Participants suggest that the oil pressure sensor is located near the starter, with two sensors identified: a brown and a green one. The brown sensor, with part number 04L 919 081 B, is highlighted as a common failure point. Users recommend replacing both sensors as a preventive measure. After replacing the sensors, one user confirmed that the issue was resolved. Additionally, concerns about oil quality affecting sensor performance were raised, with a suggestion to use higher quality oil.
TL;DR: For Octavia 5E 2.0 TDI P164B00 limp mode, replace the brown oil pressure sensor; "I replaced the brown sensor... problem solved," using a 24 mm socket; part 04L919081B works. [Elektroda, kamska, post #19424472]
Why it matters: This helps Octavia 5E owners clear false oil‑pressure alarms fast and avoid costly, unnecessary engine teardown.
Where is the oil pressure switch on Octavia 5E 2.0 TDI CRMB?
Access the sensors from underneath, near the starter. You will see two sensors: brown and green. Diagrams mark them together at position S2. Approach from the bottom for easiest reach on the CRMB. Expect limited room beside the starter body. [Elektroda, andi731, post #18640195]
Which sensor should I replace first for P164B00?
Start with the brown F1 oil pressure sensor. "The reason for the P164B00 error is a faulty F1 brown oil pressure sensor." The other switch, on the right, monitors reduced pressure. Reports did not flag the regulation valve here. [Elektroda, jacek074, post #18643806]
What is the correct part number for the brown sensor?
Use the corrected brown sensor code 04L919081B. The right‑hand switch monitors reduced pressure. This code specifically addresses P164B00 on these engines. [Elektroda, jacek074, post #18643806]
Do I need to replace both sensors at once?
It is efficient to replace both due to their tight location. A contributor confirmed the original numbers and recommended changing two. This avoids repeat labor if the second switch fails later. [Elektroda, andi731, post #18642574]
Can an oil change cause P164B00 limp mode?
One driver saw P164B00 after switching to Castrol. The actual fix was replacing the brown sensor 04L919081B. They accessed it from the top with a long 24 mm socket. "Problem solved," and no workshop time was needed. The reported solution was sensor replacement, not an additional oil change. [Elektroda, kamska, post #19424472]
What are the typical symptoms when this fault appears?
The glow plug light flashes and the car slows into limp mode. It occurs more often on a cold engine. A warm restart usually clears the warning temporarily. Freeze frame showed 1,851 rpm engine speed and 9.2°C oil temperature during a fault. [Elektroda, stefcio, post #18639817]
How do I replace the brown oil pressure sensor on Golf VII quickly?
  1. Remove covers on the front fascia.
  2. From the top, use a long 24 mm socket to remove 04L919081B.
  3. Install the new sensor and reconnect. This approach needs no workshop and takes minutes. [Elektroda, kamska, post #19424472]
Does the CRMB engine have an oil pressure control valve (A54)?
Yes, this engine uses a pressure regulation valve. Contributors did not report valve failures in these cases. The brown sensor issue was known across the group. Diagnose the switches first before suspecting the valve. [Elektroda, jacek074, post #18643806]
How should I check wiring before buying sensors?
Inspect the sensor cables near the starter for damage or loose connectors. Clean any oil contamination and ensure a firm plug fit. Fix harness faults before assuming sensor failure. [Elektroda, Auto Bil, post #18642531]
Can I access the Octavia sensors from the top?
On the Octavia CRMB, better access is from underneath near the starter. Top‑side access is limited by components. Plan the job on a lift or ramps for reach and safety. [Elektroda, andi731, post #18640195]
Which aftermarket sensor cross‑reference has been used?
One owner installed Febi 107974 for the brown sensor and kept an OEM green switch. Initial operation was reported as OK. This provides a non‑OE option if needed. [Elektroda, stefcio, post #18664726]
After replacing sensors, did the issue stay gone long‑term?
Yes. The original poster said the fault disappeared and stayed gone for about a year after replacement. They replaced both sensors, so the single failing part was not confirmed. Driving returned to normal. [Elektroda, stefcio, post #19399052]
What should I do if a dealer suggests engine teardown?
Try the brown sensor replacement first. A dealer proposed disassembly, but replacing 04L919081B solved the fault instead. On Golf VII, a long 24 mm socket from the top worked. This avoids multi‑day labor charges. [Elektroda, kamska, post #19424472]
How do I find exact part numbers (e.g., A54) for my VIN?
Use ETKA with your VIN to retrieve exact part numbers. The thread author used ETKA 8.1 and saw “unknown sale type.” If ETKA blocks access, ask a dealer to print the parts page using your VIN. [Elektroda, stefcio, post #18642422]
What if replacing the brown sensor doesn’t fix P164B00?
Check the reduced‑pressure sensor on the right next. A regulation valve exists, but contributors did not report failures. Prioritize sensor replacement and wiring checks before suspecting the valve. [Elektroda, jacek074, post #18643806]
