Oil Pressure Issues in SKODA OCTAVIA II 1.6 TDI 2010 After Oil Cooler Replacement
BOLO-O 6438 4
  • #1 16351089
    BOLO-O
    SKODA OCTAVIA II 1.6 TDI 2010. So from the beginning.After a long journey, the coolant began to decline rapidly and the liquid level indicator light came on, after refilling I could drive about 30 km and the problem repeated, the reason was the oil cooler, and more precisely the oil filter housing, so black, because on the water channel where the gasket is placed there was a chipped edge that holds the gasket in place. After replacing it with a used one with a mileage of about 10,000, a problem with the oil pressure began, namely after heating while driving, the oil pressure light turns on, after the engine is turned off and after restarting the indicator light goes out, but after adding gas above 1500 rpm. before replacing this cooler, I had no problem with this pressure, even with a damaged one and with this fluid leakage
    refrigerant.
  • #2 16351129
    BOLO-O
    the oil level is ok, but why after replacing this cooler, there was no problem before, because when I drove to the mechanic, the engine was hot and the indicator did not light up, there was a valve on the spring in the filter housing, maybe this could be a reason?
  • #3 16351557
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    You have something wrongly screwed, a damaged filter housing or a wrong filter, o-rings.
    It will show what exactly was mentioned.
  • #4 16352966
    domex32
    Help: 585
    Rate: 2450
    Or the oil pressure sensor is not connected.
  • #5 16624803
    seba24
    Help: 25
    Rate: 212
    Hey buddy and what was to blame?
