How to Fix a Scratched CD: Home Remedies & Chemical Solutions for Silver Side Damage
ziel_inf 101029 13
How can I repair a scratched CD on the silver side?
You can sometimes improve a scratched CD by gently polishing it with a mild abrasive such as toothpaste or car polishing paste; one detailed method is to wet-sand the whole disc with 2000-grit paper first, then remove the micro-scratches with Farecla polishing paste on a soft cloth [#1036275][#5094526][#1039513] Results are inconsistent, though: one user said ordinary toothpaste made a CD-RW come out matte, so test carefully and expect that not every scratch can be removed [#1036490][#1036253] If you only need the data back, try reading the disc in a newer or more sensitive drive or use CDcheck to recover files and copy them to a blank disc [#1039847][#1039819] Some replies also mention CD cleaning kits with fluid/polishing, or even dishwashing liquid and warm water as light cleaning steps [#1036287][#5094634] If the scratches are on the print side, polishing is unlikely to help [#5094758]
  • #1 1035817
    ziel_inf
    Rate: 11
    How can you "repair" a scratched (silver side) CD, there were supposedly some chemical preparations to restore this type of damage; I can't find it in blinds; any home remedies? ;
    (?) - ornament? [h]
  • #2 1036253
    andszka
    Help: 15
    Rate: 29
    WTM
    Flannel + very thick green tea (essence) and of course polishing.
    Of course, we understand that not every scratch can be removed.
  • #3 1036269
    PiotrPK
    Help: 7
    Someone once told me that he used toothpaste (the most ordinary one) and a cotton pad :D . I cleaned the display in C35 with the paste and it came out OK, maybe the disc would help.
  • #4 1036275
    dudi777
    Rate: 21
    I used to use toothpaste with an admixture of castor oil. Rubbing with such a paste gave a good effect, recently I regained the CD using this method, checked. : sm30:
  • #5 1036287
    md
    Help: 681
    Rate: 791
    www.google.pl
    type there: CD cleaning kit.
    Lots of information, but beware, there are laser cleaning kits and laser + CD cleaning kits - these kits include additional disc fluids and additional polishing.
  • #6 1036490
    leonov
    Help: 1039
    Rate: 2247
    With this toothpaste it doesn't work that well. I tried recently on CDRW and the effect was "tragic" the album came out MATTE so maybe it depends on the type of toothpaste ??? as for the display from the cell phone, the "milk", I think "cif" was "SUPER" as fast as new, but whether the CDR will work like this, I have not tried.
    Regards.
  • #7 1039513
    rewik
    Help: 15
    Rate: 61
    I use agents that are used to remove scratches on the car. So I take a 2000 grit water sandpaper and sand the entire plate to remove the coarsest scratches, then polishing paste - preferably Farecla on a soft cloth to remove micro scratches from the sandpaper.
  • #8 1039819
    jaron75
    Hello, if the methods provided by your colleagues do not help, try using the CDcheck program to rescue data from scratched and damaged media and copy what you will recover to a blank CD.
  • #9 1039847
    Włodi
    Level 19  
    Help: 20
    Rate: 46
    Or go to a friend who has a decent (preferably quite new) cd / dvd player and try to read the scratched disc from him.
  • #10 5094526
    GroobyG2
    try car polishing paste "pace" checked and it works :D
  • #11 5094634
  • #12 5094709
    Szpanbix
    Rate: 30
    Try to insert the disc into a different drive, a more sensitive one, for example a DVD recorder, and then copy this disc.
  • #13 5094726
    Chillout
    Help: 24
    Rate: 11
    Try to insert this disc into the recorder - data writers have more precise readers. And if that doesn't help, I suggest treating the puck with warm tap water for a few minutes. After all, it does not hurt to clean the plate with special cloths, intended e.g. for LCD monitors. Most of the time it works for me.
  • #14 5094758
    DriverMSG
    Help: 3984
    Rate: 4883
    I personally polish the tiles with cigarette ash, the tile is dull after that, so I polish the Mat itself with a clean tissue. 99% success.
    However, check carefully against the light that there are no scratches on the print side, because if there are any, then forget about polishing.
The discussion focuses on various methods to repair scratched CDs, particularly those with damage on the silver side. Users suggest several home remedies and chemical solutions, including using flannel with thick green tea essence for polishing, toothpaste (both regular and mixed with castor oil), and car polishing pastes like Farecla and Pace. Other methods mentioned include using 2000 grit sandpaper followed by polishing paste, dishwashing liquid, and window cleaner. Some users recommend utilizing CD recovery software like CDcheck or trying to read the disc in a more sensitive CD/DVD player. Additionally, cleaning the disc with special cloths for LCD monitors and treating it with warm water are suggested. Caution is advised regarding the print side of the disc, as scratches there can hinder recovery efforts.
