How to Polish Scratched CDs and CD-R/CD-RW: Methods and Materials for Scratch Removal
Smok 37848 15
How can I remove scratches from CDs or CD-R/CD-RW discs, and what should I polish them with?
You can often improve a scratched disc by gently polishing only the reading side, and commercial regeneration kits use very fine sandpaper plus chemicals that fill and protect the surface [#56704] People in the thread also report success with green polishing paste, toothpaste, or Diplex, applied by hand with a soft cloth, leather, or felt disc; one warning is to keep the process wet enough to avoid overheating or melting the disc [#56773] [#56776] [#190520] [#62598] If you sand first, one method is 1200-grit wet sanding followed by felt and a car paint polishing paste, using plenty of water [#192709] Polish only the bottom side of the disc, not the top, and move from the center outward along the radius rather than around the perimeter [#56698] [#62556] Small scratches can often be reduced, but very deep ones may still be beyond repair [#56776] [#56701]
  • #1 56675
    Smok
    Rate: 28
    Hello everyone
    Does anyone know how to polish scratched CDs?
    I do not know if it is possible to save discs in this way, and if so, what to polish them with and how and whether it is possible to polish all discs, or maybe in the case of CD-R and CD-RW you need special methods?
    Maybe someone knows other ways to remove scratches!
    _________________________
    Regards, SmokSerwis
  • #2 56698
    djlj24
    Car audio specialist
    Help: 1104
    Rate: 1327
    It used to be done with silicon blaizer (a product of crap amway). You can try to use car polish (not polish !!!), but it requires a lot of caution. Only the lower part of the plate is polished (do not touch the upper part).
  • #3 56700
    elektryk
    Help: 439
    Rate: 241
    If the tile is scratched, only I wash it with soap and dry it. Then you just need to wipe it clean of the tarnish (stone from the pipes). I put the prepared disc into the CD-ROM. I only do this with very scratched tiles and it usually helps.
  • #4 56701
    djlj24
    Help: 1104
    Rate: 1327
    Or maybe wash with Ludwik? Then there is no raid on the stone. Or in distilled water. But that won't help very scratched discs anyway.
  • #5 56704
    Jaco18
    Help: 7
    Rate: 15
    Commercially available kits for the regeneration of compacts. In such a set we will find very fine sandpaper (there is no such paper in the market), and depending on the set, appropriate chemicals. The procedure looks like this. Gently grind the CD (we get rid of delicate scratches), then apply a preparation that fills the gaps, then another preparation that protects the surface of the CD.
    The basket of such a set, which in total is enough for quite a lot of CDs, is about PLN 40.
    I think it's worth it, depends what you want to get back? Some important data, or maybe pirated games ;-) ))
    Regards
    I what
    oxyd(_at_)poczta.onet.pl
  • #6 56745
    Smok
    Rate: 28
    I'm talking about CD Audio discs that already have their own and are a bit scratched. When playing normally, everything is fine (of course, in CD-ROM, in ordinary players it is different)
    but after ripping to MP3 there is a problem, there is crackling and it is not suitable for listening. I tried different programs but the scratches are too big.
    Besides, for the future, it would be good to know how to deal with this problem, because you never know if (accidentally) some important disc will be scratched!
  • #7 56773
    aceton
    Help: 26
    Rate: 94
    I do it green polishing paste and a small felt disc on the motor is ok a bit you have to be careful not to melt the plate but it really works 100%
  • #8 56776
    toko0311
    Help: 18
    Rate: 12
    I use toothpaste - you need to gently spread a small amount of psasta dissolved in a small amount of water and wait for a while until it dries. Then rub it with a soft cloth to a shine. This method allows you to remove small scratches. However, the disc will not regain its original splendour.
  • #9 56798
    voro
    Help: 5
    The paste is ok, but you only need to polish it in one direction, then the scratches are arranged in one line, not causing large refractions of the laser light later.
  • #10 56815
    pioter
    Rate: 16
    Hmm, a piece of leather works very well. With larger scratches it is a bit laborious, but when polishing by hand, there is no problem of burning the tile, because then the only method is to buy a new one.
  • #11 61997
    Motonit
    I also used green paste, but I polished it by hand - the effect is first class.
  • #12 62556
    bergerac
    Well, just remember to drive from the center of the plate to the edge along the radius, not around the perimeter, because you can make the situation even worse
  • #13 62598
    DWAserwis
    Rate: 51
    I don't know how it relates to discs, but jewelers, and especially watchmakers, used a leather dial and soaked it with toothpaste for glass - the better ones use special pastes of a similar consistency, leather and paste must be wet, and the final polishing took place in water
  • #14 190520
    free22
    Rate: 9
    I USE "DIPLEX" you can buy it at promaco it is used to clean the display glass but the cdki also cleans nicely
  • #15 192709
    zort
    Rate: 9
    I put sandpaper 1200 on the oscillating sander and polish it wet, then the felt also on the oscillating and special paste for wet polishing of car paint. Brick effect - NO SCRATCHES! Just with plenty of water! Then the plastic won't melt... I used to use "tempo" instead of this paste, but it had to be dry and I had to do it by hand - it didn't give such great results...
  • #16 627277
    arkuz
    Laughs hichy and a friend in the army polished with CD polishing paste for PS and it worked. Regards
The discussion revolves around methods for polishing scratched CDs, with various techniques and products suggested by participants. Common methods include using car polish, toothpaste, and specialized polishing pastes. Participants emphasize the importance of polishing only the lower side of the disc and recommend using fine sandpaper or commercial CD repair kits that include sandpaper and chemical solutions. Some users mention the effectiveness of green polishing paste and leather for manual polishing. Caution is advised to avoid damaging the disc further, with specific polishing directions recommended to minimize laser refraction issues. The conversation also touches on the limitations of these methods for heavily scratched discs and the potential need for professional repair or replacement.
