Magnetization Possibility in Past Models: METRON JS Class 2.5 Water Meter Insights
qazwsx 126480 2
  • #1 10153675
    qazwsx
    Some time ago I replaced the water meter in the installation and I would like to know if it was possible in the past to magnetize this type / model of the meter to some extent? This is exactly what it is METRON of JS class 2.5 . It's hard for me to say if it is an exam with increased magnetic resistance. or anti-, because I don't know anything about it. Maybe someone has had contact with this or the like?
    Thanks in advance,
    Regards
  • #2 10153952
    darek4168
    Help: 23
    Rate: 347
    This type of water meter has two magnets in it, so it cannot be magnetized.
  • #3 17287309
    hossekostja
    Help: 7
    Rate: 29
    You probably won't damage it with the magnet. The thing is that you can block it with a magnet and take water. Therefore, additional magnetic field indicators are sometimes installed. Or the newer ones may have them inside. With an electricity meter it is a bit different because after using a magnet you can weaken its internal braking magnets and then such a meter calculates too much kwh.
