Magnetization of Old Analog Meter's Magnetic Yoke: Calibrating & Restoring Lost Magnetic Field
zdzisiek1979 7464 5
  • #1 16515036
    zdzisiek1979
    Help: 563
    Rate: 1256
    Strange topic, but I have a thought in my head.
    There is an old analog meter. It has a magnetic yoke and here is my doubt.
    When trying to calibrate (let's call it) I don't get a repeatable indication.
    I will switch the range, change the position of the pointer, then come back and I have a discrepancy.
    Moving the meter and similarly.
    I suspect that the magnet has lost the field and there is no magnetic force acting on the coil.
    Hence my question: How to magnetize a magnet that lost some of its power (so I would put it that way)?
    Applying neodymium magnets is probably a "fairy tale" idea.
    Wind the coil and release a constant voltage? But it would probably have to be a large current peak.
    What do you say? How to do it I know this is on the verge of absurdity but ... :D
  • #4 16515141
    zdzisiek1979
    Help: 563
    Rate: 1256
    Well, you could add a bite of fresh field, but there is little space in the housing.
    But I have now done tests for repeatability of indications and it is not fun.
    Giving uA is ok I set the current to have a reference on the scale. I break the circuit and switch on the indications for approx.
    By applying voltage, maintaining the reference scale and moving the system, the pointer already travels about 2mm from the reference. For it to come back I have to break the circuit and supply it again. I guess this is because I suspect that the magnet has lost some of the power that affects the coil.
    I will think about it.
    klamocik
    Level 36  
    Help: 334
    Rate: 727
    This is not the fault of the magnet, or; hair; crooked brushes rub against each other or the casing or looseness in the suspension of the body, these are adjusted with a screwdriver.
  • #6 16515234
    zdzisiek1979
    Help: 563
    Rate: 1256
    I don't know.
    This is what the system looks like.
    Magnetization of Old Analog Meter's Magnetic Yoke: Calibrating & Restoring Lost Magnetic Field Magnetization of Old Analog Meter's Magnetic Yoke: Calibrating & Restoring Lost Magnetic Field Magnetization of Old Analog Meter's Magnetic Yoke: Calibrating & Restoring Lost Magnetic Field
    I do not notice slack.
    The magnet is behind the silver cover. Between two pole pieces.
    Now the question is, if I would add neodymium pills, would it not spoil the magnetic field. They are in the store like what.
    I assume that after the movements of the system, the magnetic forces should bring the coil to the correct position as it occurs after "voltage reset".
    Added after 2 [hours] 53 [minutes]:
    However, the ticking of the magnet is a broken idea. I put neodymium and ... the system to be thrown out. You can't play like this because it will only get worse.
    Well, I stated experimentally :D and the application one "Do not magnetize"
    Best regards and thanks for the feedback.
