How to read pulses from Apator JS 4 water meter without AT-MBUS-NE-02 module?
Pc209235 2709 4
  • Clarifying whether Apator JS 4 uses magnetic or optical pulses
    #1 20975728
    Pc209235
    Rate: 11
    Hey!
    I have an Apator JS 4 water meter, I would like to read water usage from it in a wired way (currently I use an AT-WMBUS-16-2 radio overlay and I am not satisfied - readings often lost and the receiver 30 cm from the meter). The AT-MBUS-NE-02 pulse module is hard to get (and quite expensive). I'm wondering how to put together its equivalent myself. Does this water meter send a pulse by an electromagnetic field (in which case a Hall sensor should do the job), or do you have to play around with reading the color transition from white to black on this rotating disc (RGB sensor then - but that's more fun).
    So in short: does anyone know how the Apator JS 4 meter transmits the pulses?
    Greetings,
    Paul.
  • #2 20975733
  • #3 20976894
    TvWidget
    Help: 472
    Rate: 699
    Does this water meter have a rotating mirror, part of which is black and part reflective ?
    What do you want to do next with these impulses ?
  • #4 20980520
    Pc209235
    Rate: 11
    Yes.
    TvWidget wrote:
    What do you want to do with these pulses next ?
    Wire to ESP32. The ESP32 is controlled by the ESPHome and the Home Assistant. In ESPHome, pulse counting is virtually free: https://esphome.io/components/sensor/pulse_counter.html
