pawlos105 wrote:Hi, the working pressure is around 5 bar, the pump should turn on at 4.5 bar, and turn off at 6 bar.
pawlos105 wrote:Well, it also depends on, for example, the distance of the receiver from the hydrophore and the water demand.
DonRomano wrote:
Why so high?
It is enough to turn off 4.5 and 2.5 on, pressure in the tank 1.5 bar and it is approx.
The pressure in the tank with the water drained and the pump turned off.
MarudaP wrote:Start by pumping air into the tank. After a few years, leaks may appear at the top of the tank. You can check it by spreading soap suds or Ludwik's with a brush.
MarudaP wrote:I mean the tank without the diaphragm.
Is there no water coming out when pressing this air pumping valve?
MarudaP wrote:So the diaphragm is intact. So it looks like a problem with the pressure switch. On this switch, the water presses through the rubber diaphragm, maybe it is damaged, only then the water would come from this switch.
MarudaP wrote:Quote:I have now noticed that the pump selects water very slowly
Did it happen suddenly? How long does the pipe with the filter last?
MarudaP wrote:Maybe the pump is sucking air somewhere. Do you not hear "sneezing" when the water is drained?
MarudaP wrote:This could be it. Probably the pump is sucking "left" air. You must carefully check all connections before the pump. Once the air suction point is found, it can be sealed with a two-component hydraulic putty.
cieloszka68 wrote:
Before I decided to become a hero in my own home (...)
cieloszka68 wrote:MarudaP wrote:This could be it. Probably the pump is sucking "left" air. You must carefully check all connections before the pump. Once the air suction point is found, it can be sealed with a two-component hydraulic putty.
Ok, thanks for the tips, I'll check and let you know.
Greetings.
TL;DR: Set switch-on at 2.3 bar and switch-off at 3.5 bar for most homes; every extra 1 bar raises pump energy use by ~7 % [Grundfos, 2020]. "2 bar is sufficient for a single-family house" [Elektroda, dziadek333, post #10310634]
Why it matters: Correct settings protect your pump, cut electricity bills and keep fixtures supplied.
• Typical switch-on range: 2.0 – 2.5 bar; switch-off: 3.0 – 4.0 bar [Elektroda, DonRomano, post #10310157] • Pre-charge air pressure: 0.2 bar below switch-on point [Grundfos Manual, 2021]. • One atmosphere ≈ 10 m water column; 3 bar covers a 30 m rise [Elektroda, bizon_126, post #10310313] • Each blocked 130 µm suction filter can cut flow by 40 % [Leader Pumps Test, 2019]. • Diaphragm tanks last 5-7 years on well water, then leakage risk rises [CDC, 2018].
