Creating VBA Macro in Excel to Insert Formulas: Sum and IF Function with Selected Cell
Marjan123 16514 13
How do I insert a formula such as SUM or IF into the currently selected Excel cell from VBA?
To insert a formula into the active cell in VBA, assign it to `ActiveCell.Formula` or `ActiveCell.FormulaR1C1` instead of typing it as plain text, and use English Excel function names with commas, e.g. `=IF(...)` or `=SUM(...)` [#10371851] If you use relative references, `FormulaR1C1` is convenient because it records formulas relative to the current cell; for example, `=RC` means the current cell and `=R[-2]C[-1]` means the cell two rows up and one column left [#10371851] If you want to use Polish/localized function names, use `FormulaLocal` rather than `Formula` [#14517149] Also remember that double quotes inside the VBA string must be written twice [#10371851]
  • #1 10371776
    Marjan123
    Hello, I am a beginner when it comes to creating macros in VBA under excel, I need your help on the topic of a macro inserting a formula into a selected cell, any formula, even the sum of the two cells above. After inserting the code below, the macro crashes, it only works if I do not put the = sign before if, i.e. it inserts the text only.
    Code: text
    Thanks in advance for your help
    marcinj12
    Level 40  
    Help: 1024
    Rate: 250
    VBA does not support Polish formula names, only their English equivalents.
    The easiest way to do this is to turn on the macro recorder, enter the formula in Excel, and finish recording. Then you go Alt + F11 into the code, enter the module and find the last macro recorded. From it you copy the mentioned formula, possibly correcting its arguments.
    By default, the recorder registers the formula in the R1C1 format - in the R code is the current row, C - the current column. If you enter the formula into cell B3, the formula: "= RC" means "= B3"
    The equivalent of dollars (absolute reference) in the formula is the number next to R or C, which is "= R2C5" (which translates directly as: second row, fifth column) corresponds to "= $ E $ 2".
    The equivalent of a relative reference (without dollars - moved when dragging) - is specifying a positive or negative number for R and / or C, meaning by how much the reference should be moved relative to the current one, e.g. for the mentioned B3 formula: "= R [1] C" means " = B4 ", the formula" = R [-2] C [-1] "means" = A1 "," = R [3] C [2] "means" = D6 "etc.
    You insert a formula by means of a cell reference (or precede it with the name of a sheet from the Worksheets collection):
    Code: text
    You can also use letter designations of cells, but then the assignment method changes:
    Code: text
    You must also remember that if you are inside a quotation mark, if you want to put a single quotation mark: ", you must precede it with the second one, ie write" ".
    Additionally, all semicolons separating arguments in functions in Excel are converted into commas in VBA.
    So finally your example function written in letter format should look like this:
    Code: text
    and in the R1C1 format - here it depends on which cell you are inserting it into, let's assume that in A1, like this:
    Code: text
  • #3 10381162
    Marjan123
    Thanks a lot Marcin, the macro works :)
    While working on the file, I encountered a new problem. The NEW file contains a new version of one of the sheets in the OLD file, I copy this sheet (with the changed name) to the OLD file, the macro adjusts, among others, the formulas in other sheets of the OLD file to the current version, but ... the problem is the fact that the new file introduces several new macros that are not in the OLD file and even with the recorder I am unable to create macros that would copy macros from one file to another. Hope it is possible?
  • #4 10381527
    marcinj12
    Level 40  
    Help: 1024
    Rate: 250
    If it is a one-time operation, you can manually copy this macro from the old file to the new one. If it's supposed to be automatic, check it out this link where shows how to copy the module between workbooks (just don't do it on C: \, but somewhere to the pace)
  • #5 13887434
    koradam
    I have registered a formula that references another sheet in the same workbook.
    Range ("K2"). Select
    ActiveCell.FormulaR1C1 = "= IFERROR (IF (INDEX ('Sheet5'! C [-10]: C [-3], MATCH (RC [-10], 'Sheet5'! C [-10], 0), 5 ) = RC [-6], RC [-6], "" ""), "" "") "
    My macro first asks for the name of the sheet with which to compare the values of the current sheet. Hence I have this sheet name (specified by the variable sheet ).
    However, I would like to Sheet5 replace the variable in the given formula sheet .
    Please help :cry:
  • #6 13888392
    Maciej Gonet
    VBA, Excel specialist
    Help: 824
    Rate: 481
    This is how it should work:
    Code: text
    Remember about the spaces around the & sign.
  • #7 13889128
    koradam
    Of course it works :D
    Maciej Gonet thank you / you.
  • #8 14516592
    wzpiotrg
    I have formulas typed in cells of one sheet as:
    '= (I563 + I564) * 2
    '= (B350 + I564) * 3, etc
    My macro rewrites the contents of multiple cells to another sheet (in a loop):
    ActiveSheet.Cells (x + 565, y) .Formula = Sheets ("first_sheet"). Cells (x, y)
    Everything fits correctly on the second sheet, but the formulas don't work until you double-click each cell. Only then does it work.
    What to add in the vba code to make it happen automatically?
  • #9 14516624
    JRV
    Help: 805
    Rate: 455
    ActiveSheet.Calculate
  • #10 14516686
    wzpiotrg
    Unfortunately it does not work.
  • #11 14516735
    JRV
    Help: 805
    Rate: 455
    Hmm ... In my works. Automatic recalculation is not turned off? Attach a pricelist file
  • #12 14516811
    Maciej Gonet
    Help: 824
    Rate: 481
    An attachment would be nice, but please try this:
  • #13 14516908
    wzpiotrg
    Thanks.
    Started working, but stops when the formula says:
    '= IF (I569 = "Carwash", 2, 0)
    Added after 1 [hours] 29 [minutes]:
    Approx. I coped.
    What blind eyes (at the top there is information that vba does not recognize Polish commands; besides, the semicolons must be converted to commas).
    Ultimately, the entry looks like this:
    '= If (I569 = "Car wash", 2.0)
  • #14 14517149
    Maciej Gonet
    Help: 824
    Rate: 481
    These are the consequences of not having an attachment. VBA recognizes Polish formulas, you only need to use FormulaLocal property instead of Formula.
The discussion revolves around creating a VBA macro in Excel to insert formulas, specifically addressing issues with Polish formula names and the correct syntax for using the IF function. A user initially faced problems with the macro crashing when attempting to insert a formula with the Polish name "JEŻELI". It was clarified that VBA does not support Polish formula names, and users should use their English equivalents. The macro recorder was suggested as a tool to generate the correct VBA code. Additional queries included copying macros between workbooks and ensuring formulas work correctly after being transferred. Solutions involved using the FormulaLocal property for Polish formulas and ensuring automatic recalculation is enabled for formulas to function without manual intervention.
