[EXCEL] Converting Formulas to Text in Older Versions: Using Formulatext Function Alternative
bystrotrecon 6483 4
  • #1 16423800
    bystrotrecon
    Hello. The problem is not a problem, but still .. I have a column with formulas that needs to be converted from a machine to values (text). I know that since 2013 there is "Formulatext". How can this be solved in an older version of Excel?
  • #2 16423939
    JRV
    VBA, Excel specialist
    Help: 805
    Rate: 455
    XL 2007
    Copies the column with formulas
    paste values
  • #3 16423987
    bystrotrecon
    Yes, it's obvious, my point is that the data in one column (in which there are formulas in the rows) are automatically copied to the second, separate column (only values as text).
  • #4 16424038
    JRV
    Help: 805
    Rate: 455
    bystrotrecon wrote:
    to the second separate column ..
    eg to col. D
    Code: text
  • #5 16428832
    bystrotrecon
    Cool, thank you very much .. this was the solution. Best regards.
