[Solved] Title: Macro VBA Error: Method Range of Object_Global Failed - Troubleshooting & Solutions
Martini1005 5145 3
  • #1 18820501
    Martini1005
    The macro returns error method range of object _global failed. Asking for help - what's wrong?
    Code: VB.net
    Sub copy_nazwy_kolory()
    Dim i As Integer, j As Long, wynik As Long, wiersz As Long, zakres As Variant
    Dim kol As String
    wiersz = ActiveSheet.UsedRange.Row + ActiveSheet.UsedRange.Rows.Count
    zakres = Range("f1:f" & wiersz)
    For i = 1 To UBound(zakres, 2)
    For j = wiersz To wynik + 1 Step -1
    If zakres(j, i) "" Then wynik = j: Exit For
    Next j
    Next i
    kol = Worksheets("Nazwy+kolory").Range("T1").Value
    Sheets("Nazwy+kolory").Select 'dodawanie zakresu
    Range("f11:" & kol & wynik).Select ' zmiana zakresu kolumn do skopiowania
    Selection.Copy
    Sheets.Add 'dodawanie arkusza
    ActiveSheet.Name = "nowy"
    Sheets("nowy").Select
    Range("A2").Select 'wklejanie
    Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
    :=False, Transpose:=False
    Application.CutCopyMode = False
    End Sub
    Code: VB.net
    • Test.xlsx (61.05 KB) You must be logged in to download this attachment.
    clubs
    Help: 629
    Rate: 406
    I do not go into what is going to be going on there but you have a wrong declaration 'Dim kol As String' as it is 'long'
    and an error in the syntax 'Range ("f11:" &' as already 'Range ("f11: f" &'
    Maciej Gonet
    VBA, Excel specialist
    Help: 824
    Rate: 481
    The cause of the error is the result of a mis-declaration or misuse of the col variable. It is declared as String (text), and in the text of the procedure, its value is read from the T1 cell, which contains the numeric value 50. Then the following is used:
    Code: VBScript
    which, after substituting the values of the variables, gives the result
    Code: VBScript
    which makes no sense and generates an error. The question is, what does this variable col mean? If the column number, it would be the AX column, which does not stand out in any particular way in the sheet. So what exactly is going to be copied to this new sheet?
  • #4 18821654
    Martini1005
    Problem solved. A variable that lists the penultimate column (and therefore the range to be copied) should be taken from the V1 field, not T1. Thanks for the help.
