Mastercook LC-27ADX refrigerator how to remove the water container on the compre
alkalkalk1 88367 5
  • #1 10404461
    alkalkalk1
    Hi, the problem is very simple, but troublesome. I want to clean the water and waste tank that is located on the compressor (?) On the back of the refrigerator (Mastercook LC-27ADX), but I can't take pictures of it. I don't know if I need to pull it upwards towards myself ... I don't want to destroy it or damage it or someone will give me an idea. I want to take it off because it is very dirty and access is poor.
    Mastercook LC-27ADX refrigerator how to remove the water container on the compre Mastercook LC-27ADX refrigerator how to remove the water container on the compre
  • #2 10407707
    rychomuch
    Help: 142
    Rate: 693
    In the middle - the highest point - pry the hook.
  • #3 11205027
    mbanasik
    Rate: 10
    maybe it should be enough, but unfortunately I can't help myself. May I have a more precise explanation? I have the same problem as my colleague and I cannot return this container :(
  • #4 12320050
    goog
    I know it's an old topic but I had a similar problem and couldn't find a solution. At first I wanted to use the "force" solution, but the container was full of dirt (water with dust), it turned out that there was a simple latch.
    Yes to posterity:
  • #5 12895669
    komdez
    I also have a tip for posterity who have an AEG Elektrolux refrigerator and a similar problem. You have to press your knees on the compressor, grab the container on both sides and pull it towards you. This model does not have any clasps, everything is done with a so-called slide-on.
  • #6 18942982
    lukasz-myzia
    Whirlpool refrigerator, the appearance of the mounting on the aggregate and the latch on the container.
    Mastercook LC-27ADX refrigerator how to remove the water container on the compre Mastercook LC-27ADX refrigerator how to remove the water container on the compre Mastercook LC-27ADX refrigerator how to remove the water container on the compre
