Indesit washer – detergent drawer stuck, softener compartment holds water?
marenga 72501 5
  • #1 13204538
    marenga
    Rate: 18
    Hello, I have been struggling with a powder and liquid container for some time. I read on the forum that the container (exactly the part intended for the rinse aid) retains water, which also happens to me.
    I read that the container can be removed by slightly lifting it up and / or tugging it .. unfortunately for me this option does not work. I mean, it seems to jump out slightly from the right side, while the left one holds stubbornly, I'm afraid that some parts will break if I jerk too much.
    is this problem only for me, has it happened to someone and how to deal with it.
    aaa, I don't remember the washing machine model, front loading, narrow, 2009
  • #2 13204729
    goldi74
    Help: 1367
    Rate: 1539
    At the back of the drawer, on the side or in the middle, there should be a tab which, when pressed, allows for the complete removal of the drawer. Something like this picture:
  • #3 13204776
    marenga
    Rate: 18
    I checked, unfortunately the back part of the drawer is "empty", if you look closely, you can see the chamber, it is impossible to press anything.
    I also checked from the bottom, it looks like on the left side (under the first compartment) something is blocking the opening of the drawer, you can see it comes out on the right side without any problems. I tried to undermine it, but the effect is that now I have a problem with completely closing the drawer ...
  • #4 13205848
    goldi74
    Help: 1367
    Rate: 1539
    And what exactly is the washing machine model?
  • #5 17658128
    vElendill
    Rate: 59
    It is enough to bend the drawer down slightly when pulling it out and then it will slip out of the catches.
  • #6 17659174
    goldi74
    Help: 1367
    Rate: 1539
    After almost five years, the problem has rather been resolved. :)
