Converting a 5.5kW, 1455 RPM 3-Phase Motor to Generator: Capacitors, Voltage Regulator, 220V Output
pjetrekk15 90107 49
How can I convert a 5.5 kW, 1455 rpm three-phase induction motor into a generator that can supply 220 V for tools?
A plain squirrel-cage induction motor will not give you a stable standalone 220 V generator with just a voltage regulator; it must either be driven above synchronous speed (about 1500 rpm for a 1455 rpm motor) and self-excited with capacitors, or be rebuilt with a rotor that has permanent magnets [#10467530][#16966914][#10467200] People in the thread mention connecting capacitors to the phases (for 5.5 kW, roughly 137–187 µF total) and sometimes briefly applying 12 V DC to help residual magnetism start the excitation, but the voltage and frequency then vary with load and the generator can drop out if overloaded [#10487630][#10513011][#16966914] The most concrete “proper” conversion described is to remove the rotor, cut grooves for neodymium magnets, glue them in, balance the rotor, then use a 3-phase rectifier and a DC converter/inverter to get usable output such as 3×220 V / 45–55 Hz or regulated 230 V [#10467200] A simple regulator alone is not enough, and several replies warn that without rotor modification the machine is not a truly independent generator [#10467530][#10467883]
  • #31 10506807
    zdziwiony
    Help: 64
    Rate: 302
    Nothing was wrong. Read this PDF and faith will flow to you. Link
  • #32 10513011
    yngel1987
    Rate: 94
    At one time, for tests, I made 3.5kW generators from a squirrel-cage motor, it was enough to disconnect the connections (star connection in my case) so that I had each winding lead separately, then I connected a capacitor, or rather capacitors (large capacity required), later it was enough to give a direct voltage ( e.g. 12V - a few seconds) for any output in order to magnetize the rotor, then with the capacitor connected to turn the engine and what revolutions, I can not say higher than the rated speed. The motor was automatically excited due to the residual magnetization and further operation is possible because the energy accumulated in the capacitors magnetized the rotor all the time. On this 3.5kW motor I connected a 1.6kW farel (it heated without any problems) to about 2kW it was possible to receive current, and exceeding 2kW the motor lost synchronization and the rotor had to be magnetized again with DC voltage. The motor generated a voltage of over 300V on the other two windings, you can make the regulator or let it go through the transformer to adjust to 230V but the question is what frequency is the generated voltage ??
  • #33 11932619
    say88
    znalazłem na necie takie coś prosze przeczytać:
    Resolved QuestionShow me another »
    How to convert an 3phase electric motor to a 3phase generators?
    A 3-phase permanent magnet synchronous motor can be used as a generator simply by attaching something that will turn the shaft and connecting a load to the motor terminals. The terminal voltage and frequency will be proportional to the speed at which the shaft is turned. The voltage will vary somewhat as the load changes. This type of motor is not very common.
    A synchronous motor that has a DC power supply connected to the rotor through slip rings can be used as a generator in the same way. A battery or some other independent DC power source is required at least to get the generator started. An automotive alternator works that way. This type of motor is usually only manufactured in very large sizes.
    By far, the most common type of motor is the 3-phase induction motor. In a 3-phase induction motor, the energy in the magnetic field is constantly circulating back and forth between the power source and the motor. In order to operate as a generator, a source is required for the circulating energy. If the motor is connected to a 3-phase source and initially operated as a motor, it can be operated as a generator by increasing its speed slightly above the speed at which it operates as a motor. A battery and an inverter / converter circuit that is designed for the purpose, can allow an induction motor to act as a generator. Some less complicated circuits with capacitors, can probably be used, but they may not always start reliably and may be sensitive to the characteristics of the load.
  • #34 11936335
    yngel1987
    Rate: 94
    What's new is that each squirrel-cage induction motor, for example, which has 1480 rpm and its synchronous speed is 1500 rpm, it is enough to just exceed the barrier of 1500 rpm, i.e. increase the speed to over synchronous only the condition is one motor first must be powered from the network and then with another drive increasing its speed as above.
  • #35 11936376
    retrofood
    Help: 1140
    Rate: 4798
    This method is most often used in small hydroelectric power plants, as it allows to return energy to the grid without complicated frequency and phase control systems.
  • #37 16966914
    opto17
    Help: 8
    Rate: 22
    During motor operation, the asynchronous motor receives from the network the inductive reactive power used to generate the magnetic field and the active power converted into work, the useful rotational speed of the rotor in relation to the speed of the rotating stator field is lower, which is described by the slip.
    The asynchronous squirrel-cage motor works as a generator when:
    Apply the drive to the motor connected to the network. In this case, the rotor must be driven to over-synchronous speed.
    The reactive power will be taken from the grid, the active power will be pumped into the grid
    Since the power of the network is many times higher than the power of the generator, the generator will be naturally synchronized with it.
    The rotational speed of the generator will be slightly higher than the synchronous speed, the difference will depend on the power supplied to the shaft.
    However, this solution is not suitable for use in a portable generator.
    Second solution
    Most electrical machines are reversible, i.e. a generator, under certain conditions, may be an engine, and the engine may be a generator, it is also the case of a squirrel-cage asynchronous motor
    by the way, the synchronous generator can go into motor operation and work with zero excitation, although it is a very undesirable operation.
    In order for the 3f engine to work as a generator, active power must be supplied to the shaft in the form of a drive - the matter is taken care of by the internal combustion engine, and inductive reactive power
    Inductive reactive power can be supplied from the network or generated on site - appropriately selected capacitors are enough because the production of capacitive reactive power is synonymous with the consumption of inductive reactive power
    this solution is suitable for applications in a portable generator
  • #38 16967530
    lasko
    Rate: 36
    Buddy, you have everything in my film.
    Even in the jungle, this solution is the easiest and the cheapest way.
  • #39 16973691
    kszumek
    Help: 10
    Rate: 33
    this and I will also write for the doubters
    I have a factory generator that works like that
    if someone wants, he can come and feel himself
    motor + capacitors, my version is a little better because
    it also has a driver that connects capacitors depending on the load
    but the basic version doesn't have it, so it will go without it too
    once I had an adventure that after a long time he would not wake up
    so I had to treat it with a battery as colleagues wrote
    and the fact that it turns up at lower speed is also true
  • #40 16974034
    lasko
    Rate: 36
    Kszumek here laskolasko2000 (this is my video on YouTube) if you can enter the name and parameters of this aggregate.
    Regards.
    Mariusz.
  • #41 16974051
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    kszumek wrote:
    which, depending on the load, connects the capacitors
    Another fabulist? And how many of these capacitors are disconnected and connected? :D How many times have I written about this.
    You have the rest here
    opto17 wrote:
    In order for the 3f engine to work as a generator, active power must be supplied to the shaft in the form of a drive - the matter is handled by the internal combustion engine, and inductive reactive power
    Inductive reactive power can be supplied from the network or generated on site - appropriately selected capacitors are sufficient because the production of capacitive reactive power is synonymous with the consumption of inductive reactive power
  • #42 16974061
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    if someone wants, they can come and feel for themselves
    Except there's no cage on the rotor, just winding and poles, haven't you seen that mate?
    Secondly, the excitation of an asynchronous motor is a very inconvenient matter, how to compensate for reactive power and when overcompensating for too large capacity, after turning off the power, the motor switches to generator operation due to the load inertia, generating a voltage much higher than normal, which I probably don't need to write.
  • #43 16974063
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    kszumek wrote:
    and the fact that it turns up at a lower speed is also true
    You wanted to flash, and here ..... ass. :cry: We are constantly talking about an over-synchronous generator because that is what the squirrel cage motor is.
    Friend @ opto17 he presented the matter beautifully and reliably. :idea:
    Strumien swiadomosci swia wrote:
    generating a voltage much higher than normal, what is the risk of it, I do not need to write.
    In self-excited generators this phenomenon does not occur.
  • #44 16974087
    lasko
    Rate: 36
    Stream of consciousness
    So my video is a scam ????
    It is because of people like you that don't try to do anything themselves.
    And because he wrote that it is impossible, maybe we don't ... ????
    We say no to unbelievers ????
    It works for me and don't mislead people.
    This is the cheapest emergency generator.
    For propulsion, the best mower engine maintains its revolutions under load by itself.
    So much for the topic ?.
  • #45 16974104
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @lasko @Spring of holy awareness he didn't mean you. I saw the video, I know it works. I built not one generator - I repaired it.
  • #46 16974144
    lasko
    Rate: 36
    Christopher
    This is sorry.
    I just can't explain why many electricians say it is impossible to do.
    A moment ago my wife gave me a great answer ????
    .... BECAUSE THESE THEORETICS ....
    there is something about it
  • #47 16974158
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @lasko Maybe because with the entry into force of MOSFETs and thyristors (AVR pulse regulators), this circuit has lost its popularity, because it actually behaves a bit unpredictably depending on the load.
  • #48 16974164
    kszumek
    Help: 10
    Rate: 33
    Does an unbelieving friend want to make a bet with me ???
    I am even able to undress and prove that there are no magnets there
    and the regulator connects 3 additional capacitors through a special contactor containing additional contacts with resistance in series
    limiting current surge at the moment of switching on
    in a system where such an engine works as a generator without the mains
    it will wake up at much lower revolutions
    tested not theorized !!!
    my old post on this chiller
    https://www.elektroda.pl/rtvforum/topic979980.html
  • #49 16974181
    Help: 1405
    Rate: 6430
    What's strange about that?
    But please don't mix over-synchronous braking work with under-synchronous generator work.
    M It is not the voltage that is interesting, but the frequency in such a system.
    Because this is how it is systematized about electrical engineering.
  • #50 16974211
    kszumek
    Help: 10
    Rate: 33
    I do not know, I am running away from here, because it is difficult to discuss here
    I read that it is impossible without the network that it is impossible
    maybe I will find pics, I would put it somewhere
    control system with current measurement on transformers,
    the contactor because it was quite unusual,
    rotor
    I measured the frequency but not
    I tested what will happen under the load
    I suspect it might fall a bit but I don't think that's much
The discussion revolves around converting a 5.5kW, 1455 RPM three-phase motor into a generator. The main query involves the feasibility of this conversion and the necessary components, such as capacitors and a voltage regulator, to achieve a 220V output. Participants debate the principles of using a three-phase induction motor as a generator, emphasizing the need for excitation and the role of capacitors (typically around 137-187 µF) to facilitate this process. Several users share experiences and methods, including the necessity to exceed synchronous speed (1500 RPM) for effective operation. The conversation also touches on the economic viability of such a setup compared to conventional electricity sources, with some suggesting modifications to the rotor for better performance. Overall, the consensus is that while it is technically possible to convert the motor into a generator, practical challenges and costs may limit its utility.
TL;DR: A 5.5 kW, 1455 rpm induction motor can deliver roughly 2–4 kW off-grid when driven above 1500 rpm and excited with ~150 µF 400 V capacitors per phase [Elektroda, marcin55246, post #10487630] “Connect three capacitors and spin it” [Elektroda, ZGG, post #10473064]
Why it matters: Knowing the limits and setup steps prevents burnt loads, wasted fuel, and frustration.
• Self-excitation capacitance: 27–35 µF per kW (≈150 µF for 5.5 kW) [Elektroda, marcin55246, post #10487630] • Required overspeed: ≥3 % above synchronous (≈1500 rpm for 4-pole motor) [Elektroda, Aleksander_01, post #10467530] • Typical stand-alone output: 35–70 % of motor rating (efficiency 70–80 %) [KOMEL, 2008]. • Voltage drift: ±20 % between no-load and full-load without AVR [Elektroda, czesiu, post #10466747] • Edge-case surge: over-excited units can spike >500 V on sudden load loss [Elektroda, Strumien…, post #16974061]
1. Can any three-phase induction motor act as a generator?
Yes. Reversible electromagnetic principles let a squirrel-cage motor produce power once you supply shaft torque and reactive excitation. Grid-tied units borrow Vars from the mains; stand-alone sets need capacitors [Elektroda, opto17, post #16966914]
2. What speed must I reach for a 1455 rpm (4-pole) motor?
Drive it slightly over synchronous—about 1500 rpm. A 3 % overspeed lets it begin generating; higher speed raises voltage and frequency linearly [Elektroda, Aleksander_01, post #10467530]
3. How much capacitance should I use for a 5.5 kW machine?
Start with 137–187 µF total (≈45–60 µF per phase, 400 V AC). This range produced full brightness on three 100 W lamps in tests [Elektroda, marcin55246, post #10487630]
4. Why did my bulbs stay dark when I spun the shaft?
The rotor probably lacked residual magnetism. Without an initial flux, the stator cannot build voltage, so nothing lights [Elektroda, pjetrekk15, post #10466578]
6. How stable are voltage and frequency under load?
They vary. Expect voltage to sag up to 20 % and frequency to fall 1 Hz per 2 % speed drop when you add load [Elektroda, czesiu, post #10466747]
7. Can a simple 230 V regulator fix the fluctuations?
No. Standard triac regulators need a fixed frequency. Use an electronic AVR or inverter stage after rectifying the three-phase output [Elektroda, Aleksander_01, post #10467883]
8. How much power can I safely draw?
Plan for 40–70 % of motor nameplate, so 2–4 kW here. Above that, voltage collapses and the caps overheat [KOMEL, 2008].
9. Is grid connection possible and legal?
If you leave the capacitors out and sync by overspeeding the motor, it will feed energy into the mains, but local regulations demand anti-islanding protection and utility permission [Elektroda, retrofood, post #11936376]
10. Three-step stand-alone build guide
  1. Delta-wire stator, attach 50 µF 400 V AC capacitor to each phase.
  2. Spin above synchronous; flash 12 V DC if no voltage appears.
  3. Adjust engine throttle until output reaches 230 V at 50 Hz, then connect loads gradually.
12. How does fuel cost compare to utility power?
A 3 kW diesel generator burns about 0.8 L h⁻¹; at €1.60 L⁻¹ that is €0.43 kWh⁻¹, triple Poland’s retail tariff of ~€0.14 kWh⁻¹ [IEA, 2023].
13. Should I swap the rotor for permanent magnets?
Yes if you need tighter voltage and frequency. A milled rotor with neodymium magnets can supply 3×220 V at 45–55 Hz without capacitors [Elektroda, Marek_Pe, post #10467200]
15. How does an induction generator compare to a synchronous alternator?
Induction units are cheaper and brushless but need reactive power and give poorer voltage regulation; synchronous or PM alternators deliver stable output but cost more and need field control [KOMEL, 2008].
