Creating a Belt Gear Calculator for Machine Design: A DIY Approach
Nemonek 100184 15
  • #1 10485143
    Nemonek
    Help: 106
    Rate: 378
    Recently I needed to calculate the gearbox for a machine I was building. Since humans are lazy by nature, I decided to use a computer to help me.
    Unfortunately, a computer can only break down of its own accord, so out of laziness a so-so calculator for calculating gear ratios was created. Calculations are based on WHEEL diameters, not on effective (pitch) diameters. In my practice, this is completely sufficient - the difference in rotation is like the stability of an elephant depending on where the fly lands on it.
    The idea of the calculator is to select diameters so that the axle distance in individual gears is the same (this speeds up gear shifting)
    I have shown the individual elements of the calculator in the drawing
    Description for the drawing:
    - part A - use the buttons to select the width of the belt
    - part B - here we enter the revolutions of the driving part (e.g. engine)
    - part C - we can enter the revolutions we want to obtain, up to ten items, in ascending order (if we want to get some reasonable results)
    - part D - in this cell, by default, the program inserts the smallest diameter of the drive pulley recommended for a given belt. But if necessary, you can manually insert a different value (in mm)
    - part E - contains three buttons, using them you can print visible tables or drawings of the pulley assembly (for clarity, the drawings are printed halfway to the symmetry axis) Note! - the drawings are scaled to fill as much of the page as possible, so they are not correspond to real dimensions!
    I forgot to add that if any field in the wheel diameter table (blue fields) is highlighted in red, it means that these diameters are not recommended (too small) and do not guarantee correct calculations. Then you need to manually set the first gray field to an appropriately higher value (field D). Such cases will occur if we enter low values in the input rpm field from which we want to obtain high rpm.
    • Przekładnie wielostopniowe.xls (166 KB) You must be logged in to download this attachment.
  • #2 10486110
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    I reward my colleague with a bonus of 100 points.
  • #3 10488207
    Nemonek
    Help: 106
    Rate: 378
    And this mod tickled me pleasantly :D :D :D
    By the way, every comment is appreciated, I greet everyone.
  • #4 11346031
    Gryszka B
    Rate: 61
    Great thing with this calculator.
    I have a question. Would it not be possible to make it possible to substitute also the diameter of driven wheels?
  • #5 11355320
    Nemonek
    Help: 106
    Rate: 378
    I'm having a bit of a hard day today and my thinking is therefore slow. Could a colleague elaborate on the problem, on some non-binding example, which would specifically be to be calculated, because in multi-stage gears there are many dependencies and, for example, any choice of driven wheel diameters may result in a change of the axle distance for individual gear ratios at the given gear ratios, which in turn would be in conflict with the idea of working this calculator. (Oh shit, I did :D Perhaps a different program needs to be created for a given group of problems. If I can, I will be happy to help
  • #6 11355579
  • #7 14168219
    ANUBIS
    Level 32  
    Help: 54
    Rate: 63
    Online calculator on the site: Link , Link
    DESIGNER HANDBOOK
    Spoiler:
    General purpose belt transmissions
    with V-belts by "STOMIL SANOK" SA
    used in the construction of machines and devices.
    + CABLE_BAND_DIRECTORY
    Belt transmissions - pulleys
    Chain gears
    Friction gears
    • przekladnie cierne.zip (1.11 MB) You must be logged in to download this attachment.
    • przekładnie łańcuchowe.zip (2.6 MB) You must be logged in to download this attachment.
    • przekładnie pasowe.zip (6.65 MB) You must be logged in to download this attachment.
    • KATALOG_PASOW_KLINOWYCH_2012_m1.pdf (5.97 MB) You must be logged in to download this attachment.
    • poradnik_konstruktora_2012_pl.pdf (4.44 MB) You must be logged in to download this attachment.
  • #8 14274421
    Nemonek
    Help: 106
    Rate: 378
    I present a sheet that allows you to calculate multiple (cascade) gears
    The idea behind developing the calculator was to calculate the gear so that the existing pulleys with a larger diameter were the same, regardless of the belts used. This assumption allows for the development of the most compact transmission. Probably, as with everything, this solution is also not without its drawbacks. If someone is satisfied with these assumptions, I invite you to use the spreadsheet.
    Below is a description of the sheet elements:
    A - field for entering the input revolutions
    B - field for entering output revolutions
    C - the column in which we select the belt type from the drop-down list, after selecting the belt type in the column
    D - the minimum predefined diameter of the pulley corresponding to the given type of belt will appear.
    The diameters appearing in column D can be freely (but within common sense) individually modified
    E - column containing minimum predefined wheel diameters used for calculations (can be modified)
    The other fields are locked, the sheet is write-protected without a password, if someone wishes to unlock it, nothing prevents. The next time you start it, it will be locked automatically.
    I leave the code for use, only one request, if you change something, write it in the comment.
    As always, any comment is appreciated.
    • Przek__adnie_wielokrotne.xls (48.5 KB) You must be logged in to download this attachment.
  • #9 14894225
    ssroot
    I need the following calculations: 1st engine, 2nd pulleys, 3.Nm
    I have a machine that must run at 1500 revolutions (about 400Nm). I would like to know what engine I should choose and the pulleys, in any configuration, so that Nm is at a minimum of 400. The less kw the engine, the more economical = better.
    Regards
  • #10 14895575
  • #11 15175889
    damian175
    Hello colleagues,
    Someone could help me in choosing pulleys for the circular saw.
    I use it to cut wood (widia) or cut paving stones.
    I performed the calculations on the basis of the peripheral speed formula
    but I do not know if I matched correctly and if I chose the pulleys correctly.
    Currently, I have a pulley on the motor fi 100, and on the saw shaft fi 75. When cutting the dice, the saw turns blue, so I am asking you for the help of the appropriate pulleys.
    data :
    engine - 1420 rpm
    wheel on the motor shaft currently -fi 100mm
    wheel on the saw shaft - fi 75mm
    max saws -80m / s
    saw blade diameter -fi 350mm
    thank you in advance and best regards
    Damian.T
  • #12 15176645
  • #13 15177936
    damian175
    the saw currently runs on such pulleys (100 on the motor shaft and 75 on the saw shaft)
  • #14 15178003
  • #15 15178050
    damian175
    I just got something wrong (the wheel on the motor shaft came out 32 mm and the wheel on the saw shaft 24 mm)
  • #16 15178200
A user developed a DIY belt gear calculator to assist in calculating gear ratios based on wheel diameters for machine design. The calculator aims to maintain consistent axle distances between gears to facilitate smoother gear shifting. Discussions included suggestions for enhancing the calculator by allowing input for driven wheel diameters and the complexities involved in multi-stage gear calculations. Users also shared experiences and sought advice on selecting appropriate pulleys for specific applications, such as a circular saw, emphasizing the importance of correct pulley sizes and gear ratios for optimal performance.
