[PC] Power SW, Reset SW, Speaker – which pin is +/- and can swap damage?
Jankesik 50908 8
  • #1 10676912
    Jankesik
    Rate: 116
    Which side is the minus and which side is the plus. Write which cable color is minus and which is plus
    Could an unintentional swapping of + and - damage the motherboard?
  • #2 10676917
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    In a loudspeaker cable, black is a minus, red is a plus. It does not matter for the power and reset buttons (although according to the accepted principle, a colored wire would mean a plus, and a white one a minus).
    Connecting these cables upside down will not damage anything. A speaker connected upside down will also work. Only reverse connection of the HDD LED and POWER LED will cause that these LEDs will not work (but after correct connection, everything should be OK).
  • #3 10676927
    Kasek21
    Help: 4981
    Rate: 3547
    It doesn't matter how you hook it up SW reset and Power SW .
    About Speaker this downside is black.
  • #4 10676944
    Jankesik
    Rate: 116
    and how does this relate to Power LED, because it does not shine for me.
    I can insert the plug the other way round. Will I not damage anything? :)
  • #5 10676950
    dt1
    Help: 7315
    Rate: 8292
    Power led, if it is not lit, try to connect the other way round (white on it is minus, color is plus).
  • #6 10676951
    Kasek21
    Help: 4981
    Rate: 3547
    If you connect the other way, the diode will not light - just turn the plug.
  • #7 10676962
    Jankesik
    Rate: 116
    I will not damage the disc if I connect it the other way round? They probably connected wrongly on the website
  • #8 10676963
    Kasek21
    Help: 4981
    Rate: 3547
    Not.
  • #9 10676974
    Jankesik
    Rate: 116
    Approx. I close the topic. Thanks
In the discussion regarding the connection of power switches, reset switches, and speakers, it is clarified that in loudspeaker cables, the black wire is typically the minus (-) and the red wire is the plus (+). For power and reset switches, the color coding is less critical, but generally, a colored wire indicates plus and a white wire indicates minus. Connecting these cables incorrectly will not damage the motherboard; however, reversing the connections for the HDD LED and POWER LED will result in non-functioning LEDs until corrected. Users are advised that if the Power LED does not light, they can try reversing the connection without risk of damage to the components.
