original amplifier, subwoofer) audi a4 b5 NOKIA tda8563q description of cables,
nerka1985 46729 6
  • #1 10723911
    nerka1985
    Rate: 8
    Hello I have a4 b5 as topic needs help with this amplifier because I want to cheaply try to change the tube (change the speaker to add a second), but when I unscrewed the tip from the rest appeared to my eyes like the pictures below.
    and now the question is:
    from what every one is or does anyone have such information I noticed that the cubes come out two cables not connected (insulated) BLUE and BROWN
    why I did not know what my predecessor made (the speaker also changed) I know that the amplification has 2x40W maybe there used to be 2 speakers
    here he adds photos
    • original amplifier, subwoofer) audi a4 b5 NOKIA tda8563q description of cables, tda8563q z kol.JPG (41.52 KB) You must be logged in to download this attachment.
    • original amplifier, subwoofer) audi a4 b5 NOKIA tda8563q description of cables, kostka.JPG (72.15 KB) You must be logged in to download this attachment.
  • #2 10723945
    Mleczyk89
    Help: 291
    Rate: 266
    There must have been a two-celled speaker there.
  • #3 10724137
    nerka1985
    Rate: 8
    ok thanks, but I'm going to pull on a topic further what to do to improve the system a bit, I read a little and the two are so that the lower quality of the taste more squeeze like this? but I do not know if I understood correctly, can I buy a better gloss plug and connect to these 2 channels at the same time is possible such a bridge? and maybe 2 singles. insert an appropriately enlarged mailbox into ori place. or dwuczwkowy must be?
    As I wrote in the first post I want to cheaply improve what to do
    I know a lot of questions, but I'm curious if I do not have fun (oiling) -> although I would like the cubes and cables to be able to be turned back.
    and I forgot to add I have not ori radio was a concert of blaupunkt (I was already pissed off) although it was great fit now I have a jvc with a 4x50 mossfet, and I can connect to the radio some other flavor and chest, and what with the back speakers at the door how to connect them or leave on the old end without a speaker ori?
  • #4 10725193
    Mleczyk89
    Help: 291
    Rate: 266
    To be clear, 2-coil loudspeakers are used for 2 reasons: to achieve more power (the loudspeaker is fed from 2 channels) as well as for ease of configuration with powerful amplifiers (a 2x2ohm loudspeaker can be connected in 1ohm or 4 ohms).
    The single-coil loudspeaker does not save you because you do not have the possibility to bridge this amplifier. The power output of 2x40W at 2 ohms is also overestimated due to the measurement at 10%THD. The original speaker was probably 2x2ohm in order to achieve the best possible drive.
    You could insert 2 single-coil speakers (2ohm to get any power) if there is room.
    A separate amplifier could also be used ( need to run power cables from the battery and signal cables from the radio.
    As for the rear door speakers, as I understand it they are powered from the single TDA amplifier shown in the photo.
    Since the radio has been changed, you can rewire the cables accordingly (behind the radio as well as at this amplifier) and power them from the new radio or power them from the existing amplifier (I don't know what the connections behind the radio look like).
  • #5 10731474
    nerka1985
    Rate: 8
    will be hard with this 3 option what you wrote I am willing to throw the sub ori along with the whole package leave the tip on the back in the door and pull the new cable from the radio to another and other jigsaw I will assemble in total thanks for your interest I will need a little help in choosing an aftertaste and loudspeaker so that it does not make the plots (booty, booty) only plays well
  • #6 10881958
    nerka1985
    Rate: 8
    Thanks for info.trochę me was not (two kids) dismantled tda led new cables for the rear door and front doors for new speakers, mounted a 2x500 magnate empathy something I bridged the tube and game connection (thin budget - and again on these children) topic I think it's finished
  • #7 12673922
    Ziol3k
    Help: 12
    and I have a question for you, I have the same amp drawn from the subwoofer from the audi a3. I run it according to the descriptions on the internet, but it sounds very quiet after connecting the low-level signal, it's good to start playing at a high-level signal. Is this normal for this layout? I am asking because on the connection diagrams of this amplifier it was written that the signal should go low-level. pzdr
The discussion revolves around upgrading the audio system in an Audi A4 B5, specifically focusing on the amplifier (Nokia TDA8563Q) and subwoofer setup. The user seeks advice on connecting additional speakers and improving sound quality while maintaining the ability to revert changes. Responses highlight the use of dual-coil speakers for better power management and compatibility with amplifiers, as well as the potential for using separate amplifiers for enhanced performance. Users also discuss the challenges of low-level signal connections and the need for proper wiring to achieve optimal sound output.
