EDIT: Just don't let someone think of heating the cylinder on, for example, an electric heater!
Nie, dziękuję Przekieruj mnie tamzwir wrote:I have a two-panel sun for heating the room. And it irritated me when replacing the cylinder that it is not completely empty! There was something left, sometimes you could even feel a lot when the cylinder in your hands was opening. I found a way to empty it completely. This only applies to heating under the sun, or perhaps in a stove. Well, I set up an ordinary fan, one to cool down in the summer heat over the sun. I directed the airflow to sweep the escaping hot air down to the floor. Now I have heat all over the room and the cylinder burns out to the end. I think that this leftover gas does not burn out because the cylinder bottom temperature is too low.
mirrzo wrote:zwir wrote:I have a two-panel sun for heating the room.
Read the instructions of this sun. It says that it is forbidden to use it indoors ...
William Bonawentura wrote:jekab wrote:rafk wrote:I just ran a little test, here are the results:
0.5l of water at room temperature, boiled in a kettle on an optimally selected burner.
Natural gas consumption is just over 0.013 m?.
The cost of this, taking into account the cost of gas and the variable network fee (a fixed one, I would pay anyway, so I omit it) is approximately PLN 0.4 per liter.
Has anyone done a similar calculation for the current?![]()
Measured - 1.7 liters of water boiling = 0.193 KWh
So 1 liter - 0.11kWh. At 65 [g / kWh] it gives 7.4 [g] for boiling a liter of water with electricity.
pszjaqb wrote:Gentlemen - weigh the cylinders empty and full!
I use "alleged" 11 kg cylinder for the stove at home
We have its tare weight on the cylinders - correct after emptying,
But I have already weighed 2 cylinders straight from the distributor (wrapped in foil, etc.) and unfortunately I find that the gas itself is there .... 5 kg
Another change awaits me in a few days - I will see how much will be in the next one
TL;DR: Up to 0.5 L (≈4 % by mass) of non-volatile residue can remain in a domestic 11 kg LPG bottle [Calor, 2020]; "the mass of gas is constant in a closed cylinder" [Elektroda, darquu, post #11736543] Keep cylinders above 5 °C and use pure propane to burn nearly 100 % of the usable gas.
Why it matters: Less residue saves money, prevents clogging, and reduces unsafe DIY tricks.
• Propane boils at −42 °C; butane at 0 °C, so winter mixes contain ≥60 % propane [Shell, 2021]. • Recommended cylinder fill: 80 % volume, ~21 L liquid in an 11 kg bottle [UN ADR, 2020]. • Typical cooker regulator pressure: 30 mbar for butane, 37 mbar for propane [GOK, 2022]. • Average Polish 11 kg refill price: PLN 55 [Elektroda, William Bonawentura, post #11735875] • Residue reported: one glass (~200 mL) per bottle [Elektroda, Anonymous, post #10760400]
