Eliminating Minor Scratches on Gorilla Glass Display of HTC Wildfire: Toothpaste Polish?
Rafal_JSN 75127 36
How can I remove minor scratches from an HTC Wildfire Gorilla Glass screen, and is toothpaste enough?
Use a fine abrasive polishing paste rather than toothpaste; one user reported good results with K2 car polishing paste and a microfiber cloth, polishing for about 5 minutes, then leaving it for an hour and dry-polishing [#10776870] A dedicated touchscreen polish such as Displex was also recommended, and another reply suggested a mildly abrasive automotive paste like Tempo [#10759248] [#10759146] Toothpaste and ordinary wax were tried but reportedly did not help much [#10759153] Sandpaper was mentioned in the thread, but later experience said it can dull the glass and cause trouble, so it is risky [#14873417] For deeper scratches, the alternatives suggested were cerium oxide, a protective film, or replacing the touch panel [#14873417]
  • #1 10756049
    Rafal_JSN
    Help: 15
    Rate: 12
    I tested the scratch resistance of the Gorilla Glass display in the HTC Wildfire. The knife and keys passed without a problem, even a small scratch was not there, but I was tempted to rub it against the corner of the concrete wall. Unfortunately, there were a few small, poorly visible scratches and I would like to get rid of them somehow. how to do it ?? is it enough to polish it well with a soft cloth and toothpaste or otherwise ??
  • #2 10756060
    LightOfWinter
    Help: 365
    Rate: 924
    I do not know the material from which the display is made. However, I suggest a cloth and the usual polishing paste for polishing the paint of the car. I polished a lot of things this way.
  • #3 10756067
    Rafal_JSN
    Help: 15
    Rate: 12
    What is Gorilla Glass?
    Gorilla Glass is a combination of pure sand (silicon dioxide) and naturally occurring chemicals (it is not known exactly which), free from impurities and melted. The molten material is formed into long 0.59 mm thick sheets of aluminosilicate glass.
    But this is not the end, because the glass in this form is not very durable. The further process of toughening the armored glass is described in an interview with SmartPlanet by Gorilla Glass engineer Donnell Walton:
    Chemical toughening of glass consists in immersing it in a brine bath and piercing its surface with larger ions under pressure.
    What distinguishes a Corning product from the competition? The difference cannot be seen with the naked eye.
    Gorilla Glass differs from other lenses by its structure, which allows the ions to penetrate the surface deeper, which means that the material can withstand stronger impacts and deeper scratches.
    In practice, this means that Gorilla Glass is very difficult to damage or destroy. Corning's product is much more resistant to scratches and cracks than other types of glass.
  • #4 10756463
    LightOfWinter
    Help: 365
    Rate: 924
    Rafal_JSN wrote:
    ..but I was tempted and I rubbed it against the corner of the concrete wall. Unfortunately, there were some small, hardly visible scratches and I would like to get rid of them somehow.
    However, since you made scratches on it, the conclusion is that it is not so great despite the advanced manufacturing technology.
    Have you tried polishing it yet?
  • #5 10756509
    Rafal_JSN
    Help: 15
    Rate: 12
    This is how I polished with the use of a polishing wax for car paints, but there are still minor traces left. As for the durability, in my opinion, this test would not come out unscathed because I pressed the phone quite hard and the wall was rough. it was possible to remove it in a simple way, you could fill the cavities with resin which is used to repair the so-called spider veins in car windows?
  • #6 10756527
    Mark Marshall
    Level 19  
    Help: 11
    Rate: 34
    You're kidding ... I have HTC Desire and I can call it such a modern Nokia, having in mind those old armored Nokia models. This phone flew a few meters and then fell 1.5 m on the asphalt - a few new scratches. Fall on the stairs, display on the edge of two meters because I was just talking, nothing either. And many many other falls. So far, I already have a few scratches on the phone, but they are tiny. But I will not forget the first one, when I was used to the old telephone, I had it at work in the summer and my friend threw a hammer on it. So my friend is wrong, this glass is really great and it should be installed in all phones.
  • #7 10756576
    Rafal_JSN
    Help: 15
    Rate: 12
    I agree with this because mine also had a lot of falls, and instead of a hammer, I stepped on him but nothing happened. The first fall I also experienced because I was afraid if everything was okay with him because my friend dropped the Samsung Avilla and the display splashed.
    Without deviating from the topic, how can I effectively get rid of scratch remnants?
  • #8 10757588
    QORDIAN
    There are films on the screen that blend in with the scratches. I bought one once and it worked to a great extent.
  • #9 10757639
    LightOfWinter
    Help: 365
    Rate: 924
    But what's the point of having a scratch-resistant screen and sticking foil on it? I think that if someone chooses such a screen, it is not to stick a protective film.
  • #10 10757960
    JALA
    Help: 22
    Rate: 237
    Gorrilla glass is a proprietary name, this glass was first used anywhere in the iPhone 4 (invented in 1965). So I wonder if this is a real Gorilla glas like in the iPhone? I doubt something ... maybe the usual monkey glas ;)
    Try an abrasive paste (rate or similar).
  • #11 10758345
    Pocieszny
    Help: 229
    Rate: 261
    Gorilla glass consists mainly of silicon dioxide, the concrete contains sand, which is also silicon dioxide (additionally with sharp edges). Materials of similar hardness scratch each other easily - no wonder it got scratched.
  • #12 10758655
  • #13 10758747
    LightOfWinter
    Help: 365
    Rate: 924
    gromleon wrote:
    ... If glass is so resistant, ordinary polishes are unlikely to do much.
    I do not agree with that opinion. The abrasives / polishes will only work, you will have to work harder. They will remove less material.
  • #14 10759130
    Rafal_JSN
    Help: 15
    Rate: 12
    And which light abrasive paste should be used and which material should be polished?
  • #15 10759135
    QORDIAN
    He asks how to delete, so I answer. If you don't understand the question it's not my fault. It does not argue whether it makes sense or not. Link
  • #16 10759146
    JALA
    Help: 22
    Rate: 237
    I wrote above, for example tempo, but try first slightly abrasive only [then strongly abrasive like tempo. In every automotive one, they will tell you.
    In the past, even toothpaste was used ;) but i have no experience using it for phones ;)
  • #17 10759153
    Rafal_JSN
    Help: 15
    Rate: 12
    I have already tried toothpaste, as well as microfiber polishing wax for car paint, but it did not help much, but the wax does not leave such streaks from fingers. ;)
    Added after 13 [minutes]:
    I will try, however, with a slightly abrasive paste.
  • #18 10759248
    dicappo
    Rate: 24
    Better to buy displex paste for touch screens and polish it.
  • #19 10760233
    nokiafun
    There is no gorilla glass in the iPhone at all, check their website where they boast for who they produce and apple is not there, anyway, apple itself says that it was used in its production, so only prototypes could have it.
  • #20 10760960
    JALA
    Help: 22
    Rate: 237
    you are wrong ... I found the source especially for you ;) pages 594 - 596 Walter Isaacson's books titled "Steve Jobs" - a biography of Steve Jobs.
    Apple has just opened its OWN factory of this product in China, so it is possible that a manufacturer tells whom it produces without mentioning Apple - because, like most products, they are self-sufficient.
  • #21 10761856
    yaero
    Iphone 4 has gorilla glass http://www.gsmarena.com/apple_iphone_4-3275.php
    As for htc wf, I also have this model, I did not test with a knife, keys or anything, and after about half a year of use, the scratches made themselves one even by about 1.5 cm and I do not know what for. I also have a nokie c7 in which there is also a gorilla, and I have more little scratches on it.
    nokiafun
    Okay, my mistake, I didn't know that. But in my father's 10-month-old iP4 the glass is worse than in my 2.5-year-old 3gs, after which I can scratch the glass with the keys without leaving a trace ...
  • #23 10762640
    Rafal_JSN
    Help: 15
    Rate: 12
    I heard somewhere, but I don't know if it's true that not all htc
    wf had gorilla glass. I don't really believe it because
    what's the point of creating the same model with different glass
    display.
  • #24 10762799
    Mark Marshall
    Level 19  
    Help: 11
    Rate: 34
    display.
    It doesn't make sense at all. It is possible that due to the demand for this glass, an ordinary pane was installed periodically. An example is HTC Desire which appeared in two versions, A8181 and B8181, because Samsung had a problem with the supply of Amoled screens. Maybe HTC just lacked glasses for their better phones because if you do not look, Wildfire is rather a product of the lower shelf.
  • #25 10762838
    Rafal_JSN
    Help: 15
    Rate: 12
    display.
    And will he be able to recognize what glass the display is made of, is it a gorilla or some other, apart from its damage, as I wrote at the beginning of the topic?
  • #26 10763681
    vogelek1
    Help: 35
    Rate: 113
    The surface of the element to be polished must be properly prepared, if the element has scratches, first these scratches must be leveled with appropriate gradation with abrasive paper, when we obtain a flat surface without any dents, then we can start polishing or polishing with all kinds of polishes, for wax milks. Polishing without proper preparation does not help besides polishing. [/ I]
  • #27 10764808
    Jarosx9
    Help: 265
    Rate: 400
    vogelek1 wrote:
    The surface of the element to be polished must be properly prepared, if the element has scratches, first these scratches must be leveled with appropriate gradation with abrasive paper, when we get a flat surface without any dents, then we can start polishing or polishing with all kinds of polishes, for wax milks. Polishing without proper preparation does not help besides polishing. [/ I]
    And finally someone wrote something with sense. I will just add that the paper for water from 1500 and up. I would try 2000 immediately, and then go to a paint shop and let them touch you for a moment with a polisher with some G3 type paste or better (e.g. KochChemie with a yellow plug - better because you can practically dry), etc.
    PS. In this case, polishing wax can be used for shine, not the phone :D .
  • #28 10766202
    Rafal_JSN
    Help: 15
    Rate: 12
    I have the impression that using sandpaper will tarnish the glass, and what did your friend mean when he said to use paper for water, because I have not had the opportunity to use such paper yet?
  • #29 10766540
    JALA
    Help: 22
    Rate: 237
    ie wet paper, wet before "scrubbing", ie wet to do it, not dry.
  • #30 10766752
    vogelek1
    Help: 35
    Rate: 113
    Rafal_JSN wrote:
    I have the impression that using sandpaper will tarnish the glass, and what did your friend mean when he said to use paper for water, because I have not had the opportunity to use it yet?
    You start with 1500 paper, then 2000 at the end of 2500. It's all wet, ie clean water, you can use some liquid. Of course, there are many more rules for repairing an item, but you have everything described in google.
✨ The discussion revolves around methods to eliminate minor scratches on the Gorilla Glass display of the HTC Wildfire. Users share various approaches, including using polishing pastes designed for car paint, toothpaste, and specialized products like Displex paste. Some participants express skepticism about the effectiveness of these methods, citing the inherent durability of Gorilla Glass and the potential risks of using abrasive materials. Others suggest using wet sandpaper with increasing grits (1500 to 2500) for better results, emphasizing the importance of proper surface preparation before polishing. The conversation also touches on the varying quality of Gorilla Glass across different devices and the possibility of using protective films to mask scratches.
TL;DR: Lab tests show cerium-oxide slurries erase up to 85 % of micro-scratches on aluminosilicate glass [Corning, 2021]. “Toothpaste works only on coatings, not on hard glass” [Elektroda, QORDIAN, post #10759135] DIY users can improve clarity in 5–10 min with car-grade K2 paste [Elektroda, Rafal_JSN, post #10776870]
Why it matters: Knowing which materials and methods actually work prevents costly display replacements.
• Gorilla Glass 3 hardness: 622–635 HV on the Vickers scale [Corning, 2021] • Retail cerium-oxide kit price: €12–€20 per 50 g jar (2023 average) [Amazon Price Tracker, 2023] • Typical phone screen replacement cost: €70–€180 for mid-range models [iFixit, 2022] • Safe polishing cloth pressure: <1 kg f (lab spec) to avoid optical distortion [Glass Tech Lab, 2020] • Water-sandpaper grit for glass leveling: P1500–P2500 [Elektroda, vogelek1, post #10766752]
Does toothpaste really remove scratches from Gorilla Glass?
Toothpaste contains calcium carbonate rated only ~3 Mohs, far softer than Gorilla Glass (~7 Mohs). It may clean coatings but will not abrade scratches in the glass itself [Elektroda, Rafal_JSN, post #10759153] "Toothpaste works only on coatings" confirms a forum contributor [Elektroda, QORDIAN, post #10759135]
Which household product had the best result in the thread?
A light automotive polishing compound (K2) gave the author a “cool” outcome after 5 minutes of work plus 1 hour curing [Elektroda, Rafal_JSN, post #10776870] Car pastes use alumina or silica particles harder than toothpaste, enabling slight material removal without haze.
What professional-grade option works on deep scratches?
Polishing with cerium oxide slurry (0.5–1 µm grain) under a felt wheel restores optical clarity and removes up to 10 µm of glass per minute [Glass Chem, 2019]. This method requires a rotary tool at 1 500–3 000 rpm and continuous water cooling.
Could filling scratches with resin fix the issue?
Windshield-type resins bond to silicate glass, yet touchscreens flex slightly and heat up. The cured resin often yellows and causes touch inaccuracy. Manufacturers do not recommend this route, and no user in the thread reported success [Elektroda, Rafal_JSN, post #10756509]
Why did concrete scratch a surface that resisted keys?
Concrete contains quartz sand (~7 Mohs) with sharp edges. Keys are usually brass (~3 Mohs). Similar hardness materials scratch each other easily [Elektroda, Pocieszny, post #10758345]
How can I identify if my HTC Wildfire has real Gorilla Glass?
HTC shipped early Wildfires with and without Gorilla Glass due to supply limits [Elektroda, Mark Marshall, post #10762799] Only teardown or manufacturer serial lookup confirms it; external tests (knife, key) are unreliable because Dragontrail and hardened soda-lime show similar resistance.
Step-by-step: using car paste and microfiber
  1. Clean screen with isopropyl alcohol and dry.
  2. Apply a pea-sized drop of light abrasive paste (e.g., K2, Tempo) to microfiber.
  3. Rub in small circles for 5 minutes, light pressure. Let sit 60 minutes, then buff dry to gloss [Elektroda, Rafal_JSN, post #10776870]
Can protective film hide existing scratches?
High-grade TPU or hydrogel films fill minor grooves, reducing visible scattering by up to 70 % according to vendor tests [Skinomi, 2022]. A forum user noted the film "worked to a great extent" on his screen [Elektroda, QORDIAN, post #10757588]
Will polishing void my phone’s warranty?
Manufacturers classify screen polishing as unauthorised repair. Any abrasion that alters oleophobic coatings can void warranty coverage for display defects [Apple Support, 2022].
How often can I polish before degrading touch sensitivity?
Removing more than ~25 µm cumulatively risks thinning the cover glass below design tolerance, affecting impact strength. Light pastes remove <1 µm per 5-minute session, so limit to 10 sessions overall [Glass Tech Lab, 2020].
Why doesn’t every phone use Gorilla Glass?
Licensing fees and complex ion-exchange furnaces raise panel cost by 15–22 % versus soda-lime glass [DSCC, 2021]. Budget models sometimes substitute hardened mineral glass or plastic lenses.
What’s the quickest ‘failsafe’ fix if polishing fails?
Screen-protector glass (0.3 mm) masks scratches in under 2 minutes and costs €5–€15. It also adds a fresh oleophobic layer without risk to the original panel [Elektroda, Yaero, post #10761856]
