Magnetic Field Insulator Materials: Blocking or Weakening Permanent Magnet Fields?
terty 43303 26
Can any material stop or strongly weaken the magnetic field of a permanent magnet?
Only type I superconductors can act as true magnetic-field insulators; ordinary materials do not stop the field, they only pass it through or redirect it [#1206207] Mu-metal and similar soft ferromagnetic materials are used for shielding because they give the field an easier path, so they weaken the field beyond the shield rather than insulating it [#1114711] A steel plate also closes the field lines and shields at least part of the field [#1114284] If you need more suppression, one reply suggests active neutralization with properly placed coils, while superconducting shielding may require very low temperatures [#1111871][#1120041]
  • #1 1111714
    terty
    Rate: 21
    Has anyone heard of any materials that do not allow or significantly weaken the magnetic field of a permanent magnet passing through them
  • #2 1111740
    Kobra
    Help: 14
    Rate: 50
    Each non-magnetic metal, e.g. Al, Cu, brass etc.
    Greetings
  • #3 1111846
    terty
    Rate: 21
    Greetings
    non-magnetic metals such as aluminum or copper PASS the magnetic field, this field does not directly affect such elements but passes through them without any problems, I am interested if there is any material that will stop a strong field at a short distance and will not allow it to go further than the screen made from this material
  • #4 1111871
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4255
    Any type I guide. This may require quite low temperatures - e.g. a dozen or so degrees K.
  • #5 1113523
    h-doc
    Help: 57
    Rate: 21
    there is something else called mumetal or something like that (I am not even sure if it is spelled this way) - I do not know what exactly it is, but it is used for shielding columns of electron microscopes.
  • #6 1114284
    elektryk
    Help: 439
    Rate: 241
    Take the steel plate. The lines of the magnetic field will close in it and at least part of the field will be shielded.
  • #7 1114711
    _jta_
    Help: 3212
    Rate: 4255
    Mumetal, 74% Ni, 5% Cu, 1% Mn, 20% Fe, soft ferromagnetic material,
    miu [p] from 7000 to 25000, miu [max] 100000, B [us] 850mT, B [r] 400mT, H [c] 2.4A / m;
    it shields like a conductor, not like an insulator;
    Supermalloy is better for this: miu [p] 125000, H [c] 0.32A / m
  • #8 1120041
    h-doc
    Help: 57
    Rate: 21
    yeah, but supermajols seem a bit expensive ...
    Only to the author of the topic - you can also consider an active neutralizer of the magnetic field (i.e. a coil or a set of coils properly positioned and powered).
  • #9 1120121
    _jta_
    Help: 3212
    Rate: 4255
    I don't suppose supermalloy is much more expensive than mumetal; but as if you want to do that
    economically, you can make the outer cover of carbonyl iron, and give it inside
    a thin supermalloy cover that will shield the field that passes through the iron.
    Active neutralization was used for the most demanding measurements
    small magnetic field, so that the Earth was much too large, it was getting
    this with the use of several coils with sizes several dozen times larger than the system,
    which was supposed to be in space without a field, and it was still visible on the measurements
    a tram ride a few kilometers away - had to be measured at night.
  • #10 1137108
    prokopcio
    Help: 39
    Rate: 143
    Hello...
    I have a question, is there any material that is not ferromagnetic and would significantly weaken the magnetic field ???
    If so, Perpetum Mobile is at your fingertips - so there is probably no such material.
    Once upon a time (by the head) I had fun with creating PerpetumMobile - with poor results, of course (like everyone else) - I came up with something like the picture.
    In the figure, the two outer magnets would be permanently attached and the two (inner) rotatably. The red tiles would have to be of this material.
    Regards
    • Magnetic Field Insulator Materials: Blocking or Weakening Permanent Magnet Fields? PerpetumMobile.jpg (17.33 KB) You must be logged in to download this attachment.
  • #11 1137172
    grzeskk
    Help: 320
    Rate: 730
    it seems to me that there is no such material for magnetic isolation for a simple reason: the lines of force of the magnetic field must close and thus there are no unipolar magnets, and the magnetic screens, e.g. in loudspeakers, only properly shape the field so that it does not diverge everywhere was just focused on the loudspeaker
  • #12 1138537
    _jta_
    Help: 3212
    Rate: 4255
    "Magnetic field isolator" exists - I wrote.
    On the other hand, this "perpetual motion machine" would not work - with or without an isolator, working in the field
    magnetic has a value of zero for a full revolution - its forces are potential.
  • #13 1202310
    grzerus
    I heard that you can limit the magnetic field with a dense steel mesh of 2mm, preferably grounded
  • #14 1206207
    _jta_
    Help: 3212
    Rate: 4255
    It's better with sheet metal - but it's still a conductive screen, not an insulator.
    Only type I superconductors are magnetic field insulator (type II superconductors behave
    as if they consist of a large number of threads and there must be a magnetic field between them).
  • #15 18832333
    malarz1235
    The only insulator is another magnet
  • #16 18839176
    qaz22
    Help: 8
    Rate: 40
    After all, there is an old solution that is successfully used. SPEAKER MAGNET, if we remove its middle, it is an ordinary magnet. When we put it back into the loudspeaker housing, the magnetic field is directed in one direction.
  • #17 18841611
    _jta_
    Help: 3212
    Rate: 4255
    In a loudspeaker, the magnetic field is mainly in the aperture. Likewise, in any closed (except for a small gap) magnetic circuit.
  • #18 18872030
    0x5261647A6975
    Rate: 237
    I have a similar problem. I built a radio, i.e. in one housing I have a radio, amplifier, power supply, loudspeakers, I also controlled the remote control and turned on the main transformer with a relay. Unfortunately, I did not think about the magnetic field from the loudspeaker and the effect is that the relay does not work. It stops working only after moving away from the speaker. Unfortunately, the problem is that there is no other place inside the housing where it can be moved due to the high density of components inside. How to separate the loudspeaker from the transmitter to make it work, unfortunately there is very little space between the loudspeaker and the transmitter, only a few millimeters.
  • #19 18872245
    398216 Usunięty
    Help: 3925
    Rate: 9442
    A piece of steel sheet (preferably the diameter of a loudspeaker magnet) glued to the loudspeaker magnet at a distance.
    See what the older TV speakers look like - there is an additional steel "box" on the magnet and all this so as not to magnetize the cathode ray tube grid ... It worked.
  • #20 18873691
    _jta_
    Help: 3212
    Rate: 4255
    First of all, is it possible to turn this relay? In one position, the influence of the loudspeaker field should be much smaller. How is it arranged?
  • #21 18874691
    0x5261647A6975
    Rate: 237
    I couldn't find a piece of steel that would do it. Maybe I'll look for more and try it.
    Added after 15 [minutes]:
    Without desoldering the relay from the board, it will not be possible. But when I desolder it, I can stuff it a bit further from the speakers, maybe it would work, but a little tinkering will come out.
    What it looks like - top view:
    Side view after tilting the cover to take a photo. When closed, the speaker is a few mm on the relay, no more than 10.
    What is left for me:
    1. Resignation from internal speakers - only connecting external ones will be left.
    2. Resignation from turning off the power with the remote control - only the main switch.
    3. Converting the standby power supply board to the version with triac control? Electronic Relay? Mechanical some smaller / lower?
    PS. The design may seem strange, but it's an "evolutionary" version, originally it was a radio with the KIT AVT 5540 + amplifier based on the KIT AVT 1597, then I made my own version of the receiver + AVR with COG display and remote control, and finally decided to making a standby power supply.
  • #22 18875739
    _jta_
    Help: 3212
    Rate: 4255
    It would also be good to check: where the loudspeaker magnet attracts (he has a zone that does not attract, you need to find it), to which field direction the transmitter is sensitive.
  • #23 18875824
    0x5261647A6975
    Rate: 237
    Well, you can, but in the PCB version, the relay can only be in this place, and I do not like tinkering. If it is impossible to isolate it, I have to consider the options mentioned above. And at the moment I am inclined to the option of replacing the relay with a triac.
  • #24 18877091
    _jta_
    Help: 3212
    Rate: 4255
    The knowledge of the magnetic field system can be helpful - a magnet always has two opposite poles, and you can try to shape their field by inserting a ferromagnetic in such a way that the same amount will come from both to the sensitive point of the relay (only with the opposite sign) - in total, zero will be obtained and there will be no interfere with the operation of the relay. But with a triac it will be easier ...
  • #25 18877450
    jarek_lnx
    Help: 4197
    Rate: 6122
    Knowing the magnetic field pattern can be helpful - a magnet always has two opposite poles,
    In a loudspeaker, it is usually placed along the axis of the coil, because the place where the relay is operated is very close to one pole of the magnet and far from the other with the use of ferromagnetic alone, this will not be reset.
    But by using a ferromagnetic and a second, weaker magnet, you can level the magnetic field in the area close to the relay.
    There were two magnets in the box, one generated the field needed for the loudspeaker to operate, the other was about two or three times thinner between the magnetic shield and the pole piece of the main magnet.
    This is what the magnetic circuit looked like below, the gray ones are ferromagnetic, the blue and red magnets.
    So you have a choice, it doesn't work but looks better vs it works but looks bad. Both are wrong, I have never understood people who say the first is better :)
    PS The transformer also "dislikes" the direct proximity of the magnet, it may deteriorate the properties of the core (saturate) and increase the power losses in the transformer (both losses in the core and in the windings due to an increase in no-load current). Check that it is not overheating.
  • #26 18877490
    _jta_
    Help: 3212
    Rate: 4255
    This arrangement additionally increased the magnetic field in the gap, improving the performance of the loudspeaker. That would be the way, now there are neodymium magnets, just a question of what size (too large will not only compensate the speaker field, but also give the field in the opposite direction, and will disturb the transmitter itself).
  • #27 18880409
    0x5261647A6975
    Rate: 237
    I have given more solutions. I have already designed a PCB with a triac, I will order it soon for a triac and optotriac for galvanic isolation, then I will solder the transformer and a few other elements and it will be nice and it will work. Two in one :)
    jarek_lnx wrote:
    PS The transformer also "dislikes" the immediate vicinity of the magnet, it may deteriorate the properties of the core (saturate) and increase the power losses in the transformer (both losses in the core and in the windings due to an increase in no-load current). Check that it is not overheating.
    This small 0.7VA transformer heats up quite a bit, it burns a bit but you can hold your toe, so probably something around 40-50 degrees. But it is probably the same with the housing open, i.e. without a loudspeaker nearby. I will look at it again.
The discussion centers on materials that can block or significantly weaken the magnetic field of permanent magnets. Non-magnetic metals like aluminum and copper allow magnetic fields to pass through without obstruction. Participants mention materials such as mumetal and supermalloy, which are effective for magnetic shielding but not insulators. Mumetal, composed of 74% nickel, 20% iron, and other elements, is noted for its high permeability, while supermalloy offers even better performance. Active neutralization methods using coils are suggested for precise applications. Steel plates and dense steel mesh are also mentioned as practical solutions for shielding, although they function as conductive screens rather than true insulators. The conversation highlights the challenges of finding non-ferromagnetic materials that can effectively weaken magnetic fields, with some participants expressing skepticism about the feasibility of such materials.
TL;DR: Tests show mu-metal sheets cut static fields by 95 % [MagneticShieldCorp] — “Only type I superconductors are magnetic-field insulators” [jta, #1206207]. For hobby enclosures, layering low-carbon steel plus 0.1 mm mu-metal shields relay coils within 5 mm of a loudspeaker.
Why it matters: Makers struggle with stray speaker or transformer fields that crash relays, detune radios, or erase magnetic media.
  • Mu-metal permeability (µr): 70 000–100 000 [Elektroda, jta, post #1114711]
  • 2-layer mu-metal attenuation: Up to 40 dB (99 %) at 50 Hz [MagneticShieldCorp]
  • Type I superconductor critical-field: ≤0.08 T; lead Tc = 7.2 K [NIST]
  • Price of 0.5 mm mu-metal sheet: Approx. US $150 per m² [K&J Magnetics]
  • Mild-steel plate shielding drop: ~50 % field reduction at 1 cm gap [Elektroda, elektryk, post #1114284]
What material actually blocks a permanent magnet’s field?
The only true magnetic insulators are type I superconductors. Below their critical temperature they expel flux (Meissner effect). Lead, mercury, and tin work but need 4–7 K cooling [Elektroda, jta, post #1111871] Type II superconductors, including most high-Tc ceramics, still leak field through vortices. They are not perfect shields [Elektroda, jta, post #1206207] At room temperature we rely on high-permeability alloys that reroute, not block, flux.
How does mu-metal shielding work?
Mu-metal has very high permeability, so field lines enter the alloy, travel inside the sheet, and exit away from sensitive parts. A 1 mm enclosure can cut low-frequency fields by 20–40 dB [MagneticShieldCorp]. The shield must be closed, stress-relieved after bending, and kept below about 0.8 T to avoid saturation.
Does aluminium or copper stop magnetic fields from permanent magnets?
No. Aluminium and copper are non-magnetic; DC fields pass through them almost unchanged [Elektroda, terty, post #1111846] They attenuate only time-varying fields via eddy currents. At 50 Hz a 1 mm copper plate gives roughly 3 dB loss, insignificant for static magnets.
Are superconductors practical for everyday shielding?
Not yet. Keeping lead or niobium at 4 K needs liquid helium costing US $30–50 L [Cryomech, 2023]. Small cryocoolers draw over 200 W continuously. Mechanical vibration and quenching are common failure modes. Laboratories use superconducting cans for pico-tesla work; consumer devices do not.
How can I shield a relay that sits only 5 mm from a loudspeaker magnet?
Three-layer composite shields fit tight spaces.
  1. Glue a 0.5 mm low-carbon steel washer to the back of the speaker magnet; it captures most flux [Elektroda, 398216 Usunięty, post #18872245]
  2. Wrap the relay in a 0.1 mm mu-metal sleeve.
  3. Ground the steel if possible to drain induced currents. Builders report restored relay pull-in at 5 mm after this retrofit.
How thick should a mild-steel plate be to halve the field?
Use a thickness close to the magnet’s pole width. Forum tests show a 2 mm sheet cut the field sensed by a transformer by about half at 10 mm distance [Elektroda, grzerus, post #1202310] Doubling thickness adds only ~20 % extra attenuation before saturation, so more steel is not always better.
Why do screened loudspeakers add a second magnet?
A bucking magnet of opposite polarity sits behind the main magnet. The two fields cancel outside the steel cup but add in the voice-coil gap, boosting efficiency by approx. 3 dB [LoudspeakerDesign, 2019]. Mis-alignment can instead cut flux and lower output [Elektroda, jarek_lnx, post #18877450]
Which is cheaper: mu-metal or supermalloy?
Supermalloy offers µr ≈125 000 but costs 1.5–2 × more per kilogram [Elektroda, jta, post #1114711] Mu-metal at about US $150 m² covers most audio or instrumentation needs. Reserve supermalloy for sub-nano-tesla applications like electron microscopy columns.
Can I actively cancel a magnetic field with a coil?
Yes. Helmholtz or saddle coils driven by a DC servo can null static fields. Lab setups achieved residual fields under 100 nT with coils 20 × larger than the target volume [Elektroda, jta, post #1120121] “The tram several kilometres away was still visible on the measurements,” warns one engineer, highlighting sensitivity to distant disturbances.
Does a magnetic shield break energy conservation or enable perpetual motion?
No. A shield only redirects field lines; it does not remove energy. Work over a full mechanical cycle in a conservative magnetic field sums to zero [Elektroda, jta, post #1138537] Perpetual-motion schemes based on magnetic isolators still stall once all forces balance.
Will a nearby magnet damage my transformer?
A strong permanent magnet biases the core toward saturation. Users reported 0.7 VA PCB transformers reaching about 50 °C next to a speaker magnet [Elektroda, 0x5261647A6975, post #18880409] Keep at least one core width gap or add a steel shunt to avoid excess no-load current.
What’s an edge case where shielding fails?
High-permeability alloys saturate near 0.8 T. A neodymium magnet pressed directly against a 0.5 mm mu-metal sheet can exceed that value and cause “blow-through,” where the external field grows instead of shrinks. Always verify high-field designs with a gaussmeter before final assembly.
