How to Shield Galaxy Note S-Pen From Case Magnet Interference With Magnetic Cover
498 7
  • Magnetic case interferes with Galaxy Note S-Pen
    #1 21666900
    Ryan St
  • #2 21666901
    Steve Lawson
  • #3 21666902
    Bob Loy
  • Steel shield or remove the case magnet
    #5 21666904
    Frank Bushnell
  • #6 21666905
    Ryan St
  • Sheet steel or mu-metal for magnetic shielding
    #7 21666906
    Steve Lawson
  • #8 21666907
    Ryan St
A Galaxy Note user experiences interference between the S-Pen's magnetic functionality and a magnetic wallet case originally designed for an iPhone, causing an inch of the screen to become unresponsive. The interference is due to the case's embedded magnet affecting the S-Pen's magnetic field. Suggested solutions include using magnetic shielding materials such as Mu-metal or Permalloy, which are specialized alloys designed to redirect magnetic fields. However, these materials can be expensive and may be difficult to source or cut to size. A practical alternative is placing a thin sheet of steel between the phone and the magnet to diffuse or redirect the magnetic field, potentially reducing interference. Another approach involves surgically removing the magnet from the case by carefully cutting open the stitching or glue area, extracting the magnet, and resealing the case with glue or Velcro. Magnetic shielding works by conducting magnetic field lines away from sensitive areas, so even a small sheet covering the magnet's field lines may suffice to protect the S-Pen's functionality.
