Understanding 690V Voltage Origin in Star and Delta Motor Connections
lorakw 26329 4
  • #1 10766915
    lorakw
    Hello!
    I have a question about the delta and star connection. I know that if the motor is connected in a star, the voltage will be 230 V, and if the motor is connected in a triangle, it will be 400 V. After reading a few topics on the forum, I also learned about a voltage of 690V when connected in a star. Where does it come from? 230*3?
    greetings and Merry Christmas!
    It is taken from the normal 3x400V mains. You don't have to take anything - this is a parameter that determines the work of the windings when connected in star and delta with a switch.
    If there is an inscription on the nameplate
    230/400 or (220/380) This means that it can only work star-coupled.
    380V/660V (400V/690V - approx. -> 400V x √3 = 690V ) connected to the mains can work both star- and delta-coupled. Then you can use the λ/Δ switch to reduce the starting current of the motor (unless the motors were rewound according to someone's "wish").
    In the first case (230/400) the motor can work with a voltage of 3x230 connected in delta, but powered by an inverter, i.e. powered with a voltage of 3x230V
    [Acres]
  • #2 10766937
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2660
    I think it is similar to 400V voltage (400V phase-to-neutral, 230V phase-to-neutral), here (690V phase-to-phase, 400V phase-to-neutral).
  • #3 10767045
    12pawel
    Help: 207
    Rate: 697
    230V x √3 = 400V
    400V x √3 = 690V
  • #4 10767243
    lorakw
    I got a little carried away with everything. But I already know that the first value is the effective value and the second is the maximum value. Thanks for the replies. Regards
  • #5 11092228
    sq9jjh
    Electrician specialist
    Help: 95
    Rate: 271
    However, my colleague managed to do it, please carefully read what Akrzy74 wrote in red.
    For it to be 690V, there would have to be a specially built network (transformer) in which the phase-to-phase voltage is 690V, and the voltage of 1 phase between the neutral point would then be 400V.
