ASUS HD7750 OC 1GB DDR5 Graphics Card Compatibility with Gigabyte GA-M61PME-S2 Motherboard
cahir1987 37920 10
Will an ASUS HD7750 OC 1GB DDR5 PCIe 3.0 graphics card work in a Gigabyte GA-M61PME-S2 motherboard?
Yes, if the motherboard has a PCIe 2.0 x16 slot; PCIe 3.0 cards are physically compatible and should work in 2.0 slots [#10791312][#13057618] Several replies warn that HD7xxx cards, including the HD7750/7770 family, may not boot on PCIe 1.0/1.1 x16 boards because the card relies on slot power and may not get enough current there [#11638865][#13057618] The HD7750 itself is described as drawing about 50 W, with OC versions possibly reaching 75 W, so the slot version matters [#10791312] So the key point is: PCIe 3.0 on the card is not the problem, but a PCIe 1.0/1.1 motherboard slot may be [#10791312][#11638865]
  • #1 10791204
    cahir1987
    Hello, my question may seem silly to you, but I was looking for a specific answer and I haven't found it anywhere. So the point is, I want to buy a graphics card:
    ASUS HD7750 OC 1GB DDR5 HDMI 820/4600 DX11
    and it is on the PCI-Express 3.0 connector
    while my motherboard is:
    Gigabyte GA-M61PME-S2.
    Will this graphic work on a given album? :)
  • #2 10791296
    fiend_
    Help: 161
    Rate: 223
    There will be a problem.
    The card is powered by pci-express, so on pci-e 1.0 x16, it will not get enough electricity.
  • #3 10791312
  • #4 10791340
    cahir1987
    So finally the graphics will work on my motherboard, but to fully use it, you need to change the motherboard from PCI e 3.0 x16?
    Do you think it makes sense to buy a graphics card like you have PCI e x16?
  • #5 10791441
    fiend_
    Help: 161
    Rate: 223
    First of all, this card is unprofitable. Power consumption is low, but I haven't seen the connection you are going to make yet.
    There are better graphics cards for the 7750 price.
  • #6 11638865
    Killer_2k
    Nonsense, unfortunately.
    HD7xxx cards will not work on PCI-Ex 1.0 / 1.1 x16. Checked and confirmed, I bought it myself and melted it down. On the ASUS M2V-MX board, the ASUS HD7770 card does not boot even when connected to the OCZ ModXStream 600W power adapter. No signal over DVI and VGA through the VGA-DVI adapter. On another motherboard, also ASUS, the M4A785TD-V EVO model and the OCZ Fatality II 550W power supply started right away.
    I read on English-language forums that cards in the 3.0 standard can only run on slots from 2.1 and up. Unfortunately, this is not possible on older PCI-Ex 1.0 / 1.1. Slots 1.0 and 1.1 are compatible with cards up to bus 2.0.
    EDIT:
    Sorry for digging up the post. But the information is extremely useful, maybe someone will not blend in like me.
  • #7 12761551
    undof
    And I bought it blind and it works for me
    The MSI 760GTX card with PCI 3.0 in the Gigabyte X48T-DQ6 with PCI x16 board works like a dream, of course, additional power supply is connected to the card.
    Name of the motherboard Gigabyte GA-X48T-DQ6
    Number of expansion slots 2 PCI, 3 PCI-E x1, 2 PCI-E x16
  • #8 13057395
    badguy
    I understand that if I have a pci 2.0 x16 board, it will fit a card with 3.0 x16 input?
  • #9 13057618
    fiend_
    Help: 161
    Rate: 223
    Because your 760 requires a plug to be plugged in, and it does not rely on the current supplied only through the socket, as in the case of the 7750 ...
    pci-e 2.0 will power the 7750 without any problems, with 1.0 and 1.1 probably happened and there are still problems ...
  • #10 13074305
    Zioolko00
    I have just such a problem, pci 3.0 graphics card and only 1.0 on the board and the black screen has started for you, my friend, because this gigabyte has 2.0 pci, so my gigabyte n650sli-ds4L has 1.0 and dark ...
  • #11 13347233
    tomiqu
    Rate: 20
    Yes, the card will work. I just checked. I have an Asus P5KPL board and I put a Radeon HD7770 on PCI-E 3.0 in it and it went.
The discussion centers on the compatibility of the ASUS HD7750 OC 1GB DDR5 graphics card with the Gigabyte GA-M61PME-S2 motherboard. Users confirm that while the HD7750 can physically fit into the PCI-Express slot of the motherboard, there are concerns regarding power delivery and performance. The motherboard likely supports PCI-Express 2.0, which is compatible with the HD7750, but issues may arise with older PCI-Express 1.0 slots. Some users report successful operation of similar cards on different motherboards, while others caution that the HD7750 may not perform optimally without a motherboard that supports PCI-Express 2.1 or higher. Overall, the consensus is that the card will work, but upgrading the motherboard could enhance performance.
