Best CD for Socket 1155: Comparing Gigabyte GA-H61M-S1, H61M-DS2, GA-P61-DS3-B3 & ASUS H61M-K
StaraNervariena 7989 7
  • Request for Socket 1155 motherboard comparison
    #1 16275823
    StaraNervariena
  • #2 16275954
    sylweksylwina
    Help: 1882
    Rate: 2355
    All boards have a similar class, all (for one) have the same chipset and additionally only two RAM slots, which means that memory expansion will be limited. What is the rest of the computer supposed to be like? Isn't it better to collect some and buy something decent?
  • #3 16275980
    StaraNervariena
    i3 1120
    6gb ram
    gts 250
    450w chieftec power supply
    In the future, upgrade the graphics card and prock to i5
    What are CDs and how much should I collect and is it even worth buying a better CD for this set?
  • #5 16276827
    StaraNervariena
    I don't have only a frame and a disc for a CD, I once bought a medion for 70 zlotys and it didn't work, I would also prefer a branded CD.
  • #7 16280145
    Kasek21
    Help: 4981
    Rate: 3548
    punkwsieci wrote:
    This is what Asus proposes, good and long-lasting discs, here you have a seller with a very good opinion and a large number of transactions and there is a 12 month warranty for the disc
    http://allegro.pl/asus-p8h61-i-lx-rm-si-s1155-itx-pcie-gw-12m-fv-i6630708042.html
    It doesn't make sense to push yourself in such a liliputa.
    You want a reasonable CD with USB 3.0, SATA3 - where you possibly overclock this future i5 then take:
    http://allegro.pl/asus-p8p67-evo-ddr3-1155-usb3-sata3-fv-sklep-i5817290863.html
    The board has 4 RAM memory banks, digital power supply, built-in bluetooth, 3 PCI-E slots, PCI slots, a lot of SATA connectors, two network cards etc., etc.
The discussion revolves around selecting a suitable motherboard (CD) for Socket 1155 within a budget of PLN 200-250. Users compare several models from Gigabyte and ASUS, noting that all listed boards share similar specifications, including limited RAM slots. One user suggests considering a higher-quality board for future upgrades, while another recommends an ASUS model for its reliability and warranty. Ultimately, a user decides to purchase the ASUS P8P67 EVO for its advanced features, including USB 3.0 and multiple RAM slots, indicating a preference for a more capable motherboard over the initially considered options.
