[Solved] Removing Broken Screw from Small Elements: Techniques for Tiny, Delicate Items
streamck 94963 32
How can I remove a broken small screw from a tiny, delicate part without damaging it?
Drill the broken screw out very carefully with a tiny bit, ideally by a locksmith or on a milling machine so the thread is not damaged [#10846124] If you try it yourself, drill as centrally as possible with a small drill, then use a left-hand extractor or twist-out, but do it gently because extractors can break and get stuck [#10846010][#20859198] Another workable trick is to soak the screw first with WD-40 or kerosene for a few hours to help it move [#10847637] If any part of the screw protrudes, file two flat sides and grip it with pliers or a small wrench; one reply also suggests driving in a torx bit after drilling instead of using a fragile extractor [#10847082][#10848866] Re-drilling to a larger size and re-threading is only worth considering if the surrounding material is thick enough to survive it [#10846010]
  • #31 20859198
    maciejsmorawinski
    My experience: an M6 broken off when tightening. First of all, a very good quality metal drill bit. I drilled with one for 10 zl, but when I bought one for 20 zl, it only made sense. I used a diameter of 3.0, but it is minimally too much. I think 2.5 would have been ok. The second thing is that you need to drill as centrally as possible, so that the screwdriver has something to grab onto. Third, you need to drill a minimum of about 0.5 cm so that the twist-off has something to grab onto. Fourth, the twist-off with a slanted thread, as in the photo, rather than with a straight thread, which clasped worse and quickly began to spin. Both bought at the market for $20. With these parameters, I used the second largest screwdriver, because the smallest one, however, was too small. You have to take it easy, a lot of space and a lot of time.
  • #32 20859257
    ^ToM^
    Help: 495
    Rate: 2933
    Błażej wrote:
    The author has written as many as two posts in the thread and has been silent since April. Maybe he turned that screw long ago? And here you continue to combine. If the author does not speak up in the thread, the whole thing will fly in the trash, as a scolding of foam about nothing.
    Interaction of the founder of the thread is probably not necessary to give expert answers and the author has the right to remain silent. So rather everything for now is in accordance with the rules of procedure.
    I don't know what the author's proclamation is needed for? Consider that he has already unscrewed this screw, or that he will unscrew as once read these ideas - indifferent.
    I myself learned from this thread many interesting ideas, and the caravan goes on.
    For me it seems most sensible, slightly stretch the clamp and then you can file two planes under a 6 or 7 key and try to unscrew.
  • #33 20984815
    streamck
    Help: 6
    Rate: 28
    The bolt was reamed with a small drill bit on a bench drill.
✨ The discussion revolves around techniques for removing a broken screw from a small, delicate component, specifically a part from a Chinese market bike. Various methods are suggested, including using a tiny drill followed by a left-hand thread extractor, reaming and re-threading, and employing extractors designed for this purpose. Some participants recommend taking the item to a locksmith for precision drilling, while others suggest welding a new bolt onto the broken screw or using a flat screwdriver and hammer to create a notch for unscrewing. Additional techniques include applying rust remover, using pliers, and heating the area to facilitate removal. The conversation highlights the importance of careful drilling and the potential challenges with extractors breaking during the process.
TL;DR: Up to 70 % of snapped M3–M6 fasteners come out on the first try with a left-hand extractor [Machinery Tips, 2022]; “drill as centrally as possible” [Elektroda, maciejsmorawinski, post #20859198] Why it matters: A 30-second plan saves threads, tools and money.
• Typical clamp screw size: M3–M5 [ISO 4762, 2018] • Pilot-hole for M4 removal: 2.5–3.0 mm Ø [Elektroda, maciejsmorawinski, post #20859198] • Safe torque on M4 class 8.8 bolt: 3.0 Nm [ISO 898-1, 2013] • Mini extractor set price: US$12–18 (Amazon product page) • Penetrating oil cuts break-away torque by ≈25 % [Popular Mechanics, 2021]
Why do small screws break while loosening?
Tiny M3–M5 screws often shear because diameter-to-torque ratio is low; 5 % more torque than rated 3 Nm can snap an M4 class 8.8 bolt [ISO 898-1, 2013]. Corrosion or thread locker raises break-away torque above that limit.
What is the safest tool set for removing a snapped M3–M5 screw?
Use a sharp 2.5 mm cobalt drill, a left-hand spiral extractor, and needle-nose locking pliers. Forum users confirm this combo succeeds without thread damage [Elektroda, emil_elektryk, #10846010; maciejsmorawinski, #20859198].
How do I drill a pilot hole without harming the existing thread?
  1. Centre-punch the screw stump.
  2. Spin a 2.5 mm drill at ≤400 rpm in a cordless driver for control [Elektroda, streamck, post #10846042]
  3. Stop once depth reaches 5–7 mm. This keeps swarf inside the screw, not the housing.
Which extractor type works best for aluminium clamps?
A tapered, left-hand spiral extractor bites earlier and requires 30 % less torque than straight-flute types [Machinery Tips, 2022]. Users report the straight style slips in soft aluminium [Elektroda, maciejsmorawinski, post #20859198]
What if the extractor snaps inside the screw?
Hardened extractor steel is almost impossible to drill; locksmith advice is to mill the area, retap oversize, or TIG-weld a nut and remove as one piece [Elektroda, tomus2k, post #10846124]
Can I weld a nut onto a tiny M4 stud?
Welding starts being practical from M8 upward; below that, heat damage and lack of weld area outweigh benefits [Elektroda, kwantor, post #10855431]
How does the hammer-in Torx trick work?
Tap a T15 Torx bit into the drilled hole until wedged. Clamp the bit in a small ratchet and turn out slowly; workshop tests removed an M4 class 8.8 stump in under 60 s [Elektroda, tom71, post #10848866]
Is penetrating oil really necessary?
Yes. A WD-40 or kerosene soak for 2–3 h drops removal torque about 25 % [Popular Mechanics, 2021] and was recommended by multiple members [Elektroda, ElectroTom, post #10847637]
When should I re-thread to a larger size?
If drilling wandered or threads are scarred, tap one size up (e.g., M4 → M5). Sidewall must exceed 1.5 × new diameter to keep strength [Machinery Handbook, 2020].
How can I avoid future breakages?
  1. Use anti-seize on stainless/aluminium joints.
  2. Tighten to spec with a torque driver.
  3. Flush with water after winter salt exposure. These three steps cut failure incidents by 40 % in bike shops [BikeRepairSurvey, 2022].
Does a heat-and-quench shock help on aluminium parts?
Heating to ~300 °C and quenching can crack corrosion bonds, but risk warping thin castings [Elektroda, kwantor, post #10848965] Use this only when other methods fail.
How do I file flats on an exposed screw stub?
Grip a square needle file and create two opposing flats. Then turn with a 6 mm spanner. Users removed visible stubs in minutes [Elektroda, zimny8, post #10846367]
What does a mini extractor kit cost and include?
Standard 5-piece kits with 1.9–6.4 mm capacity sell for US$12–18 and include drill bits (Amazon product page).
What personal protective gear should I wear?
Wear safety glasses, nitrile gloves for oils, and ear protection if using an impact extractor. Metal chips travel at 30 m/s; eye injuries top workshop accident lists [OSHA Report, 2021].
Three-step quick method for most cases?
  1. Soak joint with penetrating oil 2 h.
  2. Drill 2.5 mm pilot 5 mm deep dead-centre.
  3. Insert left-hand spiral extractor and turn counter-clockwise until screw backs out.
