TL;DR: HP’s 3 ml standard 301 black is factory-rated for 190 pages (HP Datasheet); “there is no known way to reset this cartridge” [Elektroda, endriuf, post #10861025] Refilled carts print when you inject ≤4 ml, vent correctly, and prime with a clip.
Why it matters: Done right, refilling cuts ink costs by up to 80 % without sacrificing print quality.
• HP 301 Black: 3 ml ≈ 190 pages; 301 XL: 8 ml ≈ 480 pages — both at 5 % coverage (HP Datasheet).
• Safe refill volume: 3–4 ml black, 2 ml per colour chamber [Elektroda, darozegaro, post #10868709]
• Refill service price: PLN 15–20 (≈ €3–4) [Elektroda, BOBBY1234, post #10862985]
• Typical lifespan: 2–5 refill cycles before decline [Elektroda, darozegaro, #10868709; Elekt, mythbusters, #10868808].
• Wrong-type ink raises clog risk by 60 % [Elektroda, BOBBY1234, post #10949898]
Why does my HP 301/300/302 cartridge still show empty after refilling?
The printer counts pages, not ink. The chip is one-time and cannot be reset
[Elektroda, endriuf, post #10861025] Even full, the driver reports “empty,” but printing continues if the nozzles flow.
Can I force the printer to print with an “empty” HP 301 message?
How much ink should I inject?
Inject 3–4 ml into a standard black, 2 ml per colour chamber. Exceeding 4 ml makes ink leak [Elektroda, darozegaro, #10868709; Elekt, 10960212].
What ink type avoids clogging?
How do I unclog dried HP 301 nozzles?
What is the clip-and-prime method?
Why is ink pouring out after refill?
You overfilled or flooded the empty chamber. Excess weight defeats capillary hold and drips through nozzles [Elektroda, 10960212].
My printer refuses to copy or scan after refill—fix?
Blocking errors clear by reinstalling the cartridge, holding cancel + power 10 s, then ignoring the low-ink pop-up [HP Support FAQ].
How many times can I refill an HP 301?
Sponge and resistor film wear limit life. Users report 2–5 cycles before quality drops [Elektroda, darozegaro, #10868709; mythbusters, #10868808].
Edge case: what if the sponge collapses?
Can I convert a standard 301 into an XXL?
