Starting & Charging SPARTA ION Bike Battery: Ni-Mh 9000mAh R20 Cells, 24V PCB, E0001 Error
pawnol 91853 18
Why does a Sparta ION bike show E0001 and refuse pedal assist even after the battery cells have been replaced?
The most likely fault is the battery’s control PCB/controller, not the cells themselves, so replacing the Ni-MH pack with new batteries or gel batteries will not necessarily fix E0001 [#11146670] In the original Sparta setup, that board is treated as non-replaceable separately, so the official solution is usually a complete new battery pack and service connection, which was quoted at about PLN 1,500 plus about PLN 150 for fitting [#11146670] A practical workaround reported by other users is to remove the original Sparta/Batavus electronics and drive the hub motor with a generic Chinese BLDC controller [#20061281] That means bringing out the three motor phase wires and, if used, the five Hall-sensor wires; some controllers can also run without the Hall sensors [#20061281][#18883276][#19588291] Users also noted that the original electronics have to be discarded for this conversion, and there is very little space in the hub for the cabling [#19588291]
  • #1 10896500
    pawnol
    I have a problem with starting the Spart ION bike (with power steering).
    The battery is housed in a frame and consists of 16 individual R20 Ni-Mh 9000mAh 1.5V cells.
    Connected in series, giving 24V.
    They are connected to the PCB shown below.
    Starting & Charging SPARTA ION Bike Battery: Ni-Mh 9000mAh R20 Cells, 24V PCB, E0001 Error Starting & Charging SPARTA ION Bike Battery: Ni-Mh 9000mAh R20 Cells, 24V PCB, E0001 Error
    The motor, the charger connector, the controller located on the steering wheel, which sets the power of assistance, and the lighting are connected to the same PCB at the same time.
    And maybe someone had contact with these bikes, because at the time of pedaling, the only reaction was the appearance of an error on the controller screen indicating a discharged battery - E0001, and the assistance of course does not work. I tried to connect new gel batteries, but the effect is the same.
    The service is located about 300 km from me, and to the question of what the repair costs may be, I got the answer:
    "It all depends on what you will have to do, from PLN 150 to PLN 1700"
    The amount of PLN 1700 concerns the replacement of the bike with a new one.
    Maybe someone had contact with this bike and will help?
  • #2 11146670
    lestac
    A lot of this type of damaged bikes is now appearing in PL.
    The most common problem is defective batteries, specifically a damaged controller - a printed circuit board. So all links are good, but something fell on the PCB.
    Unfortunately, it is impossible to replace the board itself, you have to buy the entire battery. Such a policy of Sparta. The cost is about PLN 1,500 through a bicycle company from Wrocław that is not very favorable to the customer.
    The new battery has to be connected to the engine, unfortunately only this "company" can do it - I honestly do not recommend it based on my experience, and they wish for PLN 150 for it. About PLN 10 per minute of work.
    The bikes come from the Netherlands. A project was created there to break the monopoly, hack the software so that people do not have to replace the entire batteries, and these break down. So much so that the Dutch suspect it is being done on purpose.
    Below is a link to the entire topic in the Netherlands.
    Unfortunately, they have not managed it so far, they have been fighting since 2009.
    Link
    Maybe some Pole will break it.
    The option is to match the Chinese driver, but there is a problem with that, because the motor is three-phase, so the option is a new motor and a new controller.
    I am still struggling with two such bikes.
  • #3 11277107
    bajan
    Help: 13
    Rate: 44
    I have the same problem, I'm in the process of repairing. I am interested in whether the electronics inside the battery is physically damaged or is it a software issue? For me, the display shows a fully charged battery and the support does not work, the light switch works. No errors. When I get to something, I will inform you.
  • #4 11840025
    zwirek2
    Rate: 51
    How are you gentlemen, someone broke this patent, how to connect the batteries with the engine in this type of Sparta ION mgear bikes? Apart from the service, which wants a lot for the service, if there were even more of these services, but it would be an exaggeration to travel so many kilometers.
  • #5 12674002
    arcady11
    Help: 5
    Rate: 92
    I have an eye on the SPARTA ION bike with the e0003 error and I'm afraid that if I buy it, I will throw the money down the drain, because I will not be able to afford a new battery. What could be the fault?
    Only what I found was:
    http://www.internet-bikes.com/public/batavus-padova-easy.pdf
  • #6 12697044
    panwisnia
    Rate: 24
    I have, maybe a stupid question, but can't this motor be connected "for a short time"? bring out a button under the thumb and in this way start the engine? If the battery is good, the engine is good ... However, I may be wrong.
  • #7 12863951
  • #8 16333265
    granderik
    Rate: 29
    I have a question about the banana type batteries in Sparta, there are 20 of them each with 1.2 V Ni-MH which gives 24V. The question is how is it with charging such a package without a plate only with a charger, e.g. Li-Ion? I have 29.3 max charging current. The original charger has 34 V or 33 V, I don't remember anymore, but it is probably blocked by the driver. When charging Li-ion 29.3 V 2 A, the battery gets warm, add another 1.2 V cell to increase the possibility of charging? I would like to use this package for another bike with a 24V power supply. Now I have 1.2 V, 20 cells, or 1.4V. A charged cell 20 pieces = gives me 28V max I understand? Add 1 cell, which will increase the charging current to 29.4 V and the charger will stop charging? It will be fine ? Please correct me if I am thinking wrong.
  • #10 17665432
    Zbigniew 400
    Help: 283
    Rate: 794
    The conclusion is, do not buy this type of bike.
    Car-like problems.
    I bought a bike with a DC motor locked to the pedals.
    Advantages:
    - simple controls
    - no communication between the battery and the controller
    - failure of the gears does not necessitate the replacement of the motor and vice versa
    Defects:
    - no energy recovery
    Range approx. 30 km.
    Used, PLN 1000.
  • #11 18883276
    rybaczenko
    Rate: 18
    This engine, however, has Hall effect sensors. I am in the process of connecting this motor to a Chinese driver, but I have no batteries. As you can see, the electronics are removed from the wheel.
  • #12 19587770
    ABLublin
    Photocopiers specialist
    Help: 383
    Rate: 447
    Hi
    Were you able to get it started?
  • #13 19588006
    rybaczenko
    Rate: 18
    Yes, I was able to start without the Hall effect sensor, but I connected it through the power supply and only for a moment.
  • #14 19588149
    ABLublin
    Help: 383
    Rate: 447
    Do you have any photos or drawings?
    And those halotrons on the plate?
  • Original electronics can be removed for a hub motor retrofit
    #15 19588291
    rybaczenko
    Rate: 18
    No, I don't have any drawings. I can send a picture of the driver I used, there is described what and how to connect and that's it. It is possible to connect a hall effect sensor in the controller, but you do not have to. All the original electronics have to be thrown out, it is unnecessary. I dropped the topic, I did it a year ago. There is little space in the wheel hub of this bike to pass the cables, and you need 3 cables as phases.
  • #16 19588742
    ABLublin
    Help: 383
    Rate: 447
    Show, I will have a link, did you change anything in the connection of three phases to the engine?
  • #18 20061281
    smzagajny
    Hi
    I launched such a bike on a Chinese controller.
    I threw out the Sparta / Batavus electronics, and led out 3 cables, because the motor is three-phase and 5 cables from the hall sensors, although these controllers also work without connecting the hall sensors.
    Unfortunately, the original worked better. The power steering is not well suited despite the programming options of 3, 5, 7 gears.
  • #19 20115031
    tademo
    Rate: 25
    Can you describe in more detail how you understand that the controller works worse than the original? And one more thing, since in the original there are only 3 phase wires, why not connect the Chinese driver there, leaving the electronics in the circle?
✨ The discussion revolves around issues with the SPARTA ION bike's starting and charging system, specifically related to the Ni-Mh 9000mAh R20 cells and the E0001 error displayed on the controller. Users report common problems with defective batteries and controllers, often requiring complete battery replacement due to the design policy of Sparta. Some users have attempted to connect new gel batteries without success. Alternatives discussed include using universal controllers and modifying connections to bypass original electronics. Concerns about the cost of repairs and the reliability of the bike's components are prevalent, with suggestions for DIY solutions and warnings against purchasing these bikes due to their complex issues.
