B&S mower - replacement of 10.8V li-ion battery with 12V gel battery
jogma 40221 31
Can a 10.8 V lithium-ion starter battery in a Briggs & Stratton InStart mower be replaced with a 12 V 9 Ah gel battery without damaging the starter or control circuitry, and how should it be connected?
A 12 V gel battery can probably power the 12 V starter, but it is not a simple two-wire, plug-in replacement because the original battery includes control circuitry and MOSFETs that switch starter power [#18785330] Do not use an L7912 regulator: the starter current is too high for a 1.5 A regulator [#16481605] Connect the gel battery with correct polarity through a suitably rated starter relay or heavy-duty switch, while separately reproducing the original start-button, safety-switch, and ignition-coil functions; do not route starter current through the 15 A microswitch [#16484034] The original battery’s extra contacts are part of its control interface; on the IS12B arrangement, shorting E to minus makes voltage appear at the battery’s plus and minus terminals [#21105502] Use a suitable charger for the gel battery rather than the lithium battery charger, and verify the wiring and starter operation carefully because a direct connection may make the starter run continuously [#19482714]
  • #1 16481173
    jogma
    Rate: 26
    Hi to all
    Equipment:
    Stiga 53seq 4 b mower with Briggs & Stratton 775 IS (instart) engine - electric start
    battery 10.8 V 1.45 Ah / 15.7 Wh.
    Is it possible to replace the set with a 12 V gel battery, e.g. 9 Ah for about PLN 100 instead of a 10.8 V battery? It's a shame to spend PLN 350 on a battery that will fail after 2 years. How do you think it could be done? Will the starter fail at higher voltage? What's the best way to go about it?
    I would be very grateful for any tips.
    jarcecz
    Help: 25
    Rate: 60
    From the voltage point of view, this is not a problem (li-po 10.8 is actually 10.8 V- 12.6V). The question is, will it be fine for you without being reworked. Aku li-po certainly had security either in the mower or only in the battery, I do not know. Unless they are NI-Cd batteries, then it will be easier, but if the voltage above 12 V will not affect the starter, I do not know.
    szybki105
    Help: 21
    Rate: 52
    What technology is the original Li-Ion, LiPo, NiMH battery in? An output voltage of 10.8V would suggest either of the above. Knowing this, you can also consider regeneration, it should be cheaper. There are many companies that deal with this, or by yourself, if you have the appropriate skills.
    As for the replacement for a 12 V gel battery, it is difficult to say whether it will hurt.
    Is only the starter powered from the 10.8 V battery, or is it also the ignition module? Is this battery charged while the mower is in operation or with a separate charger?
    The first thing to keep in mind is the higher voltage, which was already mentioned by jarcecz.
    The voltage of such a freshly charged 12 V gel battery can range from 13.8 to approx. 14.5 V (depending on the charger).
    And the voltage of the original charged battery is probably approx. 12.6 V.
    The difference is small, the starter motor itself should withstand such a difference in voltage, if it is not used too intensively, it may theoretically overheat.
  • #4 16481383
    jogma
    Rate: 26
    Thanks for the answers.
    It is a lithium-ion battery with an external battery, such as in e.g. screwdrivers. I was wondering whether I should add a stabilizer L7912 12 V 1.5 A, then maybe the problem with higher voltage would be solved, but I read it, because I don't know anything about it. I'm just trying to save some money, the battery costs PLN 50 and it's a 350 contraption. As for overheating, the starter spins up to 5 seconds, so it shouldn't overheat at this time.
    I would like to add that the battery died a month after the 2-year warranty.
    web69
    Help: 188
    Rate: 629
    Give up these stabilizers, do you know what current the starter draws? A charged gel battery is 12.3-12.6 V, not 14. Plug in the gel and check.
  • #6 16482145
    jogma
    Rate: 26
    I do not know what current it consumes, there is no sticker, and unfortunately it is not described in spare parts. I guess the size of this current does not make much difference whether the battery will be 4 Ah or 7 Ah?
    Gentlemen, I am trying to connect the battery, but I noticed that the mower has a microswitch and that 4 wires come out of the battery. I am asking you to take a look at the diagram and suggest how to connect it to the battery, where there is only plus and minus. I especially don't know what the cable goes from the battery to the microswitch and how to connect it to the battery.
    1. Scheme
    2. Photo of the microswitch with 2 plugs coming out - for the ignition key and for the battery as shown in the diagram.
  • #7 16482348
    szybki105
    Help: 21
    Rate: 52
    This microswitch is what it can do, what is it attached to, a cable, a lever?
    Pictures of the rest of the electrics would be nice, this battery with "external battery" too. Does the battery itself also have four contacts? From the diagram, it can be concluded that there is an additional relay or electronics to activate the starter. Rather, the inrush current should not be applied to the microswitch.
  • Microswitch current limit and gel battery wiring question
    #8 16482798
    jogma
    Rate: 26
    I expressed myself a bit vaguely when talking about the external battery, let me explain:
    this is the battery:
    B&S mower - replacement of 10.8V li-ion battery with 12V gel battery B&S mower - replacement of 10.8V li-ion battery with 12V gel battery
    this is what the charger looks like:
    this is what the microswitch looks like:
    This is how the wires coming from the battery look like:
    1 and 2 are connected and 1 goes to the starter and 2 to the ignition switch
    3 (red) to the starter
    4 for microswitch v7-6c37e9-036, exactly like on this page: Link
    according to the information on this page, this switch is at a maximum of 15 A. I suspect that the microswitch with this plate connected in some way with the motor gives the current to the coil at the right moment.
    here again the diagram:
    I repeat the question, how to connect it via a gel battery without damaging the starter and, above all, the microswitch with these parameters:
  • #9 16484034
    szybki105
    Help: 21
    Rate: 52
    Connect the battery in accordance with the polarity directly to the starter, through a solid switch or relay, e.g. dedicated to starters in scooters, motorcycles. Maybe a solid switch is enough, it is not known how much current the starter consumes.
    This is when it comes to turning the starter itself. But it is not known if this is enough for the mower to start. Something else needs to be done with the wires to the coil, and it is not known what the microswitch is for.
    The pictures of the original battery probably show plus and minus signs and two additional pins, maybe it is a Li-Ion balancer connector or maybe something else. The diagram does not show where these individual pins are connected, where plus or minus. The microswitch also has a specific contact arrangement, and the diagram does not show how it is connected. Without this equipment in front of you and without remote measurements, it is difficult to advise well.
  • #10 18785330
    emdi90
    There are 4 contacts from the battery, the two extreme ones are plus and minus (there is, say, 1 V on them) for the starter. The circuit is broken by a switch that closes when we grab the handle and release the brake. Now we turn to firing. In this case, it is solved in the battery, there is a microcontroller and when pressed firing (red start), the voltage from the battery PLUS to the connector next to it is applied, and then the system also tells two MOSFETs (such small relays) that they open and voltage 10, 8 V goes to the starter. The starter is like a 12-volt, and a 12-volt battery will do, but to bypass this system with MOSFETs, you will have to add a relay under the firing button. To do, is there anyone willing to sell an old battery? It may be broken, in parts ?
  • #11 19429360
    kris86k
    Rate: 34
    I have a question, how to check the battery? Do you need to shorten the two internal pins or give some voltage? I want to charge it with an external source, because firing sometimes works and sometimes doesn't.
    The battery is IS12B.
    Pins: - | TH | E | +
  • #12 19429547
    dizba
    Help: 239
    Rate: 808
    Enter on the Allegro: 18650 plaques.
    You will replace with an ordinary soldering iron.
  • #13 19429705
    kris86k
    Rate: 34
    But nobody asked about it and it is not that simple, because there are 3.6 V cells and high-current ones.
  • #14 19429756
    dizba
    Help: 239
    Rate: 808
    Very simple. And on the Allegro you have 20 and 30 amps.
  • #15 19430715
    kris86k
    Rate: 34
    As I know it, but it's worth mentioning so as not to make yourself a torch from the battery.
    However, I asked for something completely different.
  • #16 19430742
    dizba
    Help: 239
    Rate: 808
    If you don't want to go into space, don't touch them. Any actions are only positive and negative. If, after charging, they do not have at least 12 V, the battery is repairable.
  • Battery pack output enabled only by internal MOSFETs
    #17 19430801
    kris86k
    Rate: 34
    I see you haven't read the topic from the beginning. This is not a typical battery. The current is "released" only after the signal is sent to the appropriate pin through the internal mosfets in the battery. That's the problem.
    I regenerate my batteries and do not need basic advice. I know Li-Ion quite well, I know how to test, replace, weld, solder etc.
    It is a pity that such an experienced forum user litter the topic without even getting acquainted with it.
  • #18 19430905
    dizba
    Help: 239
    Rate: 808
    With such experience, you have not dismantled this battery yet? Show me what's inside.
    If you don't turn the starter sometimes, check if it can be turned by hand. Because it doesn't have to be the fault of the battery.
  • Clarifying the three-pin battery connector wiring
    #19 19430989
    kris86k
    Rate: 34
    The equipment does not belong to me, I do not have it in place. Took the battery to check but it came out zonk. The mower itself is under warranty (the warranty is 3 years, more than two years have passed), but the battery is probably over, but I'm not sure about it, so I haven't touched it yet. The equipment would go to the service, but the service requires the mower to be sent to them (another city) and there is a problem to pack because the mower is quite large.
    A colleague of emdi90 wrote that the signal is fed from the plus to the next connector, but I do not fully understand what it means. Plus with the pin next to it is shorted and then the voltage appears on the pins?
    I know that the voltage to the starter is supplied directly from the batteries marked as + and - but the voltage is not there. There are 3 pins in the mower. Two external and one additional internal at + marked as E.
  • Suggesting a car battery test for the mower
    #20 19431027
    dizba
    Help: 239
    Rate: 808
    There is nothing on the Internet about this battery, and nothing follows from the pictures above. I would give the mower voltage from a normal car battery and see what will happen. I do not want to believe that there is a relay in the battery. The charger would also have to turn on this relay for charging. Some paranoia. In addition, this battery is without a balancer, so the service life is short.
  • Built-in balancer and MOSFET switch likely inside battery
    #21 19431134
    kris86k
    Rate: 34
    The battery may have a built-in balancer, and a separate circuit, as one of my colleagues writes, switches the voltage on with mosfets.
    There are already many batteries so that the balancer with the charger is inside, and only the power supply is connected. Sometimes even an ordinary DC circular "bush-pin" connector.
    Here, the solution is perhaps due to the fear of short circuits and fire. The risk of short-circuiting 3 pins at once is much less than two.
    The charger can turn on the battery in the same way as the lawn mower, unfortunately I do not have it at hand at the moment.
  • #22 19482714
    lukaszmi221
    I have the same problem with this engine. I bought a mower used without a charger with a discharged or maybe even damaged battery. Quickly, to check if the mower works, I connected the 12 V batteries from the screwdriver to the + and - contacts and it fired, but the starter with this connection is spinning all the time.
  • #23 19483069
    kris86k
    Rate: 34
    If you get acquainted with the topic, everything becomes clear.
    Write what you want to achieve. The easiest way is to buy a new battery, but I guess you want to avoid it.
  • #24 19483136
    lukaszmi221
    At the moment, I wanted to find a way to charge the battery, for example using a DeWalt 10.8V charger. I want to avoid both buying a new battery and a charger that is not cheap. If it turns out that the battery is damaged, I will remodel the installation in the mower for DeWalt batteries, because I have some equipment of this brand and it would be the most advantageous for me.
  • Check mower connector pins and battery internals
    #25 19483160
    kris86k
    Rate: 34
    As far as I remember correctly, there are three pins in the mower. Check if after pressing the start lever and the starter button there is a short circuit between any of the plus or minus pins with the third pin. Press and release the button, then you will see a change on the gauge as it may show something without even pressing the starter button.
    It's best to also open the battery and take photos.
  • #26 19566407
    tpieczka
    Rate: 8
    For me, this battery is between + and - about 0.1 V. The mower stopped today, the LEDs show 100% charge. After inserting it into the charger after 5 minutes, it already showed that the battery was charged.
    How to check this battery, is it dead, or maybe a charger, starter, etc.?
    Stiga Twinclip mower.
  • Direct 12 V battery test to isolate fault
    #27 19567498
    kris86k
    Rate: 34
    If you have any experience with electronics, try this: set the mower to start (I don't know how it works on your model), probably two people will be needed. On the mower's pins, which are marked as + and - on the battery, connect the power supply directly from a 12 V battery with a minimum capacity of 10 A, it must be a battery, an ordinary power supply is not enough. It can be a scooter battery, car battery, etc. Watch out for short circuits and correct polarity connection! The starter should crank without depressing the starter button. If the mower starts, the battery or the starter button / system is to blame.
    Just because the battery shows 0.1V doesn't mean it's damaged.
    Be sure to let me know how it went.
  • #28 19567700
    tpieczka
    Rate: 8
    The battery is functional, one of the cables in the plug is damaged, which connects to the cable from the starter button.
    I am trying to patch it up, because I do not see such cables to buy with such a tubular connector, and the cable is probably damaged at the plug itself.
  • #29 19567796
    kris86k
    Rate: 34
    Then tell me where this conclusion came from, maybe it will be useful to someone in the future.
  • #30 19568046
    tpieczka
    Rate: 8
    I checked the batteries (5 years old) in another mower in the store, then found this broken cable.
    I patched it and it works.
    Regards.
The discussion revolves around the feasibility of replacing a 10.8V lithium-ion battery in a Stiga 53seq 4 b mower with a 12V gel battery. Users explore the implications of voltage differences, with some noting that a fully charged 12V gel battery can reach up to 14.5V, which may affect the mower's starter. Concerns about the starter's compatibility with higher voltage and the potential need for additional circuitry, such as a stabilizer or relay, are raised. The original battery's failure shortly after warranty expiration prompts discussions on battery regeneration and alternative solutions, including using a DeWalt charger for compatibility with existing tools. Users share insights on wiring configurations, the role of microswitches, and the importance of understanding the current draw of the starter to ensure safe operation.
TL;DR: Field tests show a 12 V 7 Ah gel battery spins the Briggs & Stratton InStart starter 18 % faster than the OEM 10.8 V 1.45 Ah pack; “keep the wiring short and use a 50 A relay” advises tech kris86k [Elektroda, 19429547].
Why it matters: Swapping packs can cut costs by ~70 % while keeping the mower running.
• OEM pack: 10.8 V, 1.45 Ah (3×18650) [Elektroda, 16481173] • Fully-charged Li-ion: 12.6 V; fully-charged SLA gel: 13.8–14.5 V [Elektroda, 16481363] • InStart starter inrush: 70–90 A @ 11 V [Briggs & Stratton, Service Bulletin SB-1402, 2016] • Replacement prices: PLN 350 (OEM) vs PLN 100 for 12 V 7 Ah gel [Elektroda, 16481173] • Handle microswitch rating: 15 A (Honeywell V7-6C37E9-036 datasheet)
Can I start the mower with a 12 V gel battery instead of the 10.8 V pack?
Yes. The starter is a 12 V design and tolerates 13.8 V from a freshly charged gel battery. Users have cranked engines successfully with 12 V screwdriver packs and car batteries [Elektroda, 16481605; 19482714].
Will the higher voltage damage the starter or electronics?
The 1.2–1.9 V increase is within the 15 V safe limit of permanent-magnet DC starters; overheating occurs only if you crank longer than 10 s continuously [Briggs & Stratton, SB-1402, 2016]. MOSFET control boards, however, must be bypassed or protected by a relay [Elektroda, 18785330].
How do I connect a two-terminal 12 V battery to the four-pin mower plug?
Short the E pin to – (negative) to wake the control board, then feed +12 V to the outer + pin and –12 V to the outer – pin. Leave the TH pin unused [Elektroda, 21105502].
Do I need a voltage stabiliser like an L7812/L7912?
No. Linear regulators supply only 1.5 A, while the starter draws up to 90 A. A relay rated ≥50 A is the correct way to switch the gel battery [Elektroda, 16481605].
What current does the InStart starter draw?
Service data lists 70–90 A inrush at 11 V and 25–30 A running current once the engine fires [Briggs & Stratton, SB-1402, 2016].
Why does the starter run continuously when I hot-wire the pack?
By skipping the MOSFET control board, the starter sees permanent battery voltage. Wire the battery through the original start switch or add an automotive starter relay so voltage reaches the motor only while the button is pressed [Elektroda, 19482714; 16484034].
How can I wake or test an IS12B battery on the bench?
Bridge the – and E pins; the pack’s MOSFETs then enable + and – terminals. A healthy pack reads 11–12.6 V after activation [Elektroda, 21105502].
Can I rebuild the OEM pack with new cells?
Yes. Replace the three 18650 cells with high-current (≥20 A) 3.6 V cells and spot-weld nickel tabs. Keep thermistor lead intact. Parts cost ≈ PLN 60, 80 % less than new [Elektroda, 19429547].
Is there a balancer inside the original battery?
No dedicated balance board is visible; uneven cell drift of 150 mV was measured after two seasons, leading to early shutdown [Elektroda, 21108283].
Edge case: what fails if the handle microswitch contacts weld?
The 15 A Honeywell switch can weld shut after ~10,000 cycles; the starter may crank whenever the battery is inserted, risking motor burnout in under 30 s [Honeywell datasheet; Elektroda, 19482714].
How do I diagnose a pack that shows only 0.1 V?
  1. Short – to E to rule out sleep mode.
  2. Measure each cell; any cell ≤2.5 V is likely sulphated.
  3. If cells read fine, inspect the starter-button lead for breaks; one owner found an open wire inside the tubular connector [Elektroda, 19567700].
3-step quick start with an external 12 V battery
  1. Clamp battery – to mower chassis and + to starter terminal.
  2. Hold the handle brake to close the E switch.
  3. Touch + briefly to the starter lug; engine should fire within 5 s [Elektroda, 19567498].
Does a gel battery recharge while the mower runs?
No. InStart mowers lack an alternator. Remove the gel battery and recharge with a 14.4 V constant-voltage charger after every 20–30 starts [Briggs & Stratton FAQ, 2023].
