Disassembling Braun Oral-B Vitality D12.013 Toothbrush: Step-by-Step Guide
zubryk111 78997 14
How can I safely disassemble a Braun Oral-B Vitality D12.013 toothbrush without damaging it?
To disassemble it, remove the brush head, then carefully open the bottom plug or drive out the small retaining pin so the inner mechanism can come out [#10923995][#10924031][#10924468] One method from the manual is to insert the edge of the charger into the cut in the bottom cork and twist very gently, because the wires from the coil in the plug can break [#10923995] Another method is to turn the brush upside down and tap the protruding tip-attachment end against a hard surface so the body stays in your hand and the mechanism slides out [#10924031] If your unit has a visible pin about 1 cm from the base and about 1.5 mm wide, knock that pin out from above, but do not push too deep [#10924468][#10928164]
  • #1 10923194
    zubryk111
    Rate: 15
    Hello. I have a Braun oral-b vitality D12.013 toothbrush and I would like to disassemble it so as not to damage it. And how to do it, because I have absolutely no idea how to do it.
    Please answer fast because I need to fix it. Thanks in advance.
  • #2 10923995
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    There is a cork at the bottom. The manufacturer provides in the instructions how to disassemble a used toothbrush in order to separate the battery - insert the edge of the charger into the cut and twist.
    In this case, often/usually the wires from the coil in the plug break, but if you do it really gently (and twist as little as possible just to pry and pull out this plug) it may work.
  • #3 10924031
    kkknc
    Help: 1915
    Rate: 6709
    You take off the replacement brush, turn it over so that the part with the stopper is at the top and hit it while holding the whole brush to hit something hard with this protruding element for attaching the tips. The body will stay in your hand and the mechanism will come out.
  • #4 10924036
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    In how many pieces?
  • #5 10924134
    kkknc
    Help: 1915
    Rate: 6709
    movzx wrote:
    In how many pieces?
    In one way, from the instructions. This is how I replace the batteries in mine.
  • #6 10924214
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    kkknc wrote:
    In one way, from the manual.
    And isn't this a way (as in my instructions) for the "final" disassembly of the brush?
    Because while turning the cork is still quite delicate, hitting the flimsy frame that is inside seems risky to me.
    But if you're bragging, I'm not arguing.
  • #7 10924357
    zubryk111
    Rate: 15
    So there is no completely safe way?! :cry:
    It's hard, but thanks for the answers.
  • #8 10924468
    kkknc
    Help: 1915
    Rate: 6709
    Look at it from the front at the bottom about a centimeter from the base there should be a visible pin with a diameter of about 1.5 mm. Don't put it in too deep and it will be easier to knock out. I took mine apart like this. I bought the battery at TEM
  • #9 10924720
    zubryk111
    Rate: 15
    I don't need to replace the battery. Once I damaged this pin (I made a small hole with a needle, I don't know why) and water got inside through this small hole because something is splashing there. But a moment ago I saw that the toothbrush works but after pressing the button you have to wait about a minute before it turns on (this is right after removing it from the charger) but if I turn it on and off and immediately after that I turn it on again, it turns on normally. The charger is doing some "reset" or something. :D
  • #10 10924776
    kkknc
    Help: 1915
    Rate: 6709
    Strip, wash, dry. Seal the hole with a glue gun.
  • #11 10924838
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    Check for advanced galvanic corrosion on traces and other components. Moisture will always get in, so in this case you would have to think about protecting such worn places with tile varnish.
  • #12 10928164
    zubryk111
    Rate: 15
    But probably the paths should be protected with varnish at the factory. And there's no place on my cork to hook over the edge of the charger. These wires from the coil, if they break, you can solder them somehow :?:
    They couldn't do it with screws :|
  • #13 10928279
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    So this is the version as written kknc and must be pushed out through the pin from above.
    That's right, but water (with various contaminants) plus voltage = very aggressive environment.
    Well, no kidding.
  • #14 10928292
    zubryk111
    Rate: 15
    movzx wrote:
    Well, no kidding.
    And why?
The discussion revolves around disassembling the Braun Oral-B Vitality D12.013 toothbrush. Users share various methods for safely opening the device, including using a cork at the bottom and twisting it with a charger edge, or striking the toothbrush against a hard surface to release the mechanism. Concerns about damaging internal components and the risk of galvanic corrosion due to moisture are raised. Suggestions include sealing any holes with a glue gun and protecting exposed traces with varnish. The conversation highlights the challenges of disassembly and the need for caution to avoid damaging the toothbrush further.
