Oclean SE - how to disassemble a sonic toothbrush that has stopped charging?
marcin____ 15846 4
  • #1 19802780
    marcin____
    I have a problem with the Oclean SE sonic toothbrush - charging stopped working after about 2 years. Does anyone have experience with this model and know how to disassemble it?
  • #2 19804192
    raks0
    Help: 258
    Rate: 450
    This is the case with Oclean Air, but it may be similar in Oclean SE. You need to remove the middle disk, there is a screw underneath it.
  • #3 19810662
    marcin____
    In oclean se, this element at the bottom does not look like it could be removed.
    But thank you for the tip. Anyone else have info on how to get inside?
  • #4 19810719
    raks0
    Help: 258
    Rate: 450
    I damaged mine when opening it and only then I saw that there was a screw there. If the middle disc cannot be removed, it must be drilled in the middle. The manufacturer probably did not provide a disassembly option.
    Here`s another opening technique Link
  • #5 21603219
    Anfalsh
    Hello, start button of mine don't work well due of limestone. Anyone know how to disassemble this toothbrush ?
