Philips HX6511/50 Sonic Toothbrush Repair: Battery Replacement & Coil Sediment Issues
dodger2018 36285 18
Can replacing the battery fix my Philips HX6511/50 sonic toothbrush, or is the sediment near the coil causing the failure?
Replace the battery first, but if the brush still only runs briefly or only the LED stays on, the problem is likely in the electronics or firmware/protection logic, not just the cell [#17749822][#17763605][#17765684] If the JP1 service jumper was not handled correctly during battery replacement, the stored program may have been erased or corrupted, and recovery would require a programmer and a firmware dump [#17763672][#17765684] The sediment/rust near the coil suggests moisture ingress, so clean the board thoroughly with isopropanol and then check the tracks for continuity because corrosion can eat them through [#17766178]
  • Battery charges briefly but brush still shuts down
    #1 17749790
    dodger2018
    I have a PHILIPS sonic toothbrush for repair, which has stopped working. After unscrewing, the first battery that I soldered se us14500vr2 680 mAh, the measured voltage was zero.
    For tests with the TP4056 chip, I charged it to a voltage of about 4.1V, then connected back to the main plate of the brush, it activated it for nearly 3 seconds of vibration, and then the power LEDs were still on for 5-10 seconds. By pressing the button it made no difference.
    Will just replacing the battery help? I can still see some sediment near the coil.
    I am asking for advice.
    Philips HX6511/50 Sonic Toothbrush Repair: Battery Replacement & Coil Sediment Issues51195318_1...2560_n.jpg (341.58 kB)You must be logged in to download this attachment. Philips HX6511/50 Sonic Toothbrush Repair: Battery Replacement & Coil Sediment Issues51699172_2...1232_n.jpg (64.47 kB)You must be logged in to download this attachment. Philips HX6511/50 Sonic Toothbrush Repair: Battery Replacement & Coil Sediment Issues51410349_3...4576_n.jpg (57.24 kB)You must be logged in to download this attachment. Philips HX6511/50 Sonic Toothbrush Repair: Battery Replacement & Coil Sediment Issues51237864_2...5520_n.jpg (258.83 kB)You must be logged in to download this attachment. Philips HX6511/50 Sonic Toothbrush Repair: Battery Replacement & Coil Sediment Issues51293369_9...1792_n.jpg (59.48 kB)You must be logged in to download this attachment. Philips HX6511/50 Sonic Toothbrush Repair: Battery Replacement & Coil Sediment Issues51064564_3...8448_n.jpg (247.21 kB)You must be logged in to download this attachment. Philips HX6511/50 Sonic Toothbrush Repair: Battery Replacement & Coil Sediment Issues51168284_2...6768_n.jpg (149.32 kB)You must be logged in to download this attachment.
  • #2 17749822
    Witold5
    Level 32  
    Help: 178
    Rate: 728
    You are looking for problems. Replace the battery, then you will know if it is enough, and it will be enough.
  • #3 17763532
    dodger2018
    The battery has been replaced but the problem is still the same
  • #4 17763605
    E8600
    Help: 529
    Rate: 2520
    It was to be expected. In the first photo you have posted you can clearly see the Rx, TX, etc. service fields. After that, it can be concluded that any chip (probably Q1) is programmable. It probably has a protection for the number of inclusions or it locks when the battery is excessively discharged / used.
    This is a kind of protection for the manufacturer not to repair, but to buy new ones.
  • #5 17763625
    dodger2018
    What can you do then?
  • #6 17763672
    E8600
    Help: 529
    Rate: 2520
    Maybe a colleague try to unsolder the JP1 service jumper. Here you have instructions in which order to replace the battery. However, I'm afraid that now it may be too late and the memory dump may be erased. Still, it's worth a try.
  • #7 17763821
    dodger2018
    It had no effect. Is the case pending or something else that can be done?
  • #8 17763887
    E8600
    Help: 529
    Rate: 2520
    Have you desoldered and soldered? The toothbrush shows any signs of life?
    Probably to fix it you would have to look for the batch and try to program it again.
  • #9 17763948
    klamocik
    Level 36  
    Help: 334
    Rate: 727
    And so we moved from the teeth to the electronics, wash the entire plate very thoroughly with an ordinary toothbrush and dishwashing liquid. Of course, diluted later with a few blows, there would be nothing left and drying on the radiator for 12 hours. I do not give a guarantee, but I know that when washing, something will always pass.
    :arrow: I have corrected TONI_2003
  • #10 17765643
    dodger2018
    I did according to the video. However, now only the green LED is on. No vibration.
  • #11 17765684
    E8600
    Help: 529
    Rate: 2520
    Apparently, during the first replacement of the battery itself without unsoldering the jumper, the program stored in the system was deleted / damaged. Without a programmer and a batch, you won't do anything about it now. Such jumpers are a protection, sometimes they need to be soldered before they can be replaced, another time they need to be desoldered.
    If you have a programmer, the batch can be obtained on Russian websites.
  • #12 17766178
    misiek1111
    Level 37  
    Help: 325
    Rate: 1097
    Yes for posterity. On the HX6932, the battery can be replaced normally.
    As for the brush itself, it is a German dud with a deliberate design that makes the product anti-aging, although the functionality itself can be assessed as one of the best on the market.
    If there is sediment and rust, it means that the brush was not tight. Wash the plate with isopropanol, then check the paths with a meter for continuity. Some can be eaten by the moisture.
  • #13 18100000
    iza_k
    I also have a brush, which of course broke after the warranty expired: /
    I already thought the toothbrush should be thrown away, but here I can see that it may be repairable :)
    Can you recommend someone to take care of it, preferably from Warsaw?
  • #14 18100256
    Piotr2608
    Help: 851
    Rate: 4487
    It did not broke after the warranty expired only it ran out or exhausted, the battery charge amount limit. These france don't like to be brought to death. As we can already see the drastic decrease in working time, we should already replace the battery. Second, such brushes are only charged when the charge level is close to zero. My Philips has been working on the original battery for 4 years, if not 5 years. The charger is disconnected from the socket.
    ZimTech Piotr Zimny
  • #15 18100266
    iza_k
    Thanks for the answer. Can such a battery be replaced then? They say on the website that there are no spare parts and therefore the brush can be thrown away (mine was charged only when it started to "rain", and I connected the charger to the power supply, only for charging)
  • #16 18100285
    Piotr2608
    Help: 851
    Rate: 4487
    The battery can always be replaced, the question is whether the electronics will allow the battery to be replaced and whether it will not be like in the post by the author of the topic.
    ZimTech Piotr Zimny
  • #17 18111634
    crux
    Rate: 20
    As I can see, the problem does not only concern my and my wife's toothbrush. Both brushes bought about 3.5 years ago. The first one broke down after about 14 months, the second one after 22 months. The symptoms are: Cannot be turned on, after prolonged charging, it vibrates regularly for up to 10 minutes without the possibility of turning off (it turns off the vibration again reconnecting to the charger), etc. Sent under warranty, both returned replaced with a new one. One of the brushes, after more than a year, broke again, the symptoms as above. Well, this time I ordered another one from the store with an extended warranty. The product itself is amazing, I did not notice any deterioration of the battery's durability, I charged it myself, I do not know how often, every few weeks, and I use it twice a day.
    crux
  • #18 18111723
    misiek1111
    Level 37  
    Help: 325
    Rate: 1097
    crux wrote:
    The symptoms are: Cannot be turned on, after long-term charging, it vibrates regularly for up to 10 minutes without being able to turn off (it turns off the vibration when reconnecting to the charger), etc.
    Typical symptoms of flooding electronics:
  • #19 18113343
    crux
    Rate: 20
    Ok I will try. Currently, the brush turns on every few minutes and spins for 2 minutes.
The discussion revolves around the repair of a Philips HX6511/50 sonic toothbrush that has ceased functioning. The initial troubleshooting involved replacing the battery with a US14500VR2 680 mAh, but the issue persisted despite charging attempts. Participants suggested that the problem might be related to a programmable chip (possibly Q1) that could lock out functionality if the battery was excessively discharged. Recommendations included unsoldering a service jumper (JP1) and thoroughly cleaning the circuit board to address sediment and rust issues. However, it was noted that if the program was damaged during the battery replacement, a programmer would be necessary to restore functionality. Users shared experiences of similar issues with their Philips toothbrushes, indicating a potential design flaw leading to premature failures.
TL;DR: Philips HX6511/50 fixes often need more than a battery. “My Philips has been working on the original battery for 4 years,” and users advise charging only near-empty. Start with safe swap steps and moisture cleaning; firmware can lock. [Elektroda, Piotr2608, post #18100256]
Why it matters: This FAQ helps Philips Sonicare HX6511/50 owners diagnose no‑start, random vibration, and battery‑swap issues without bricking the brush.
Will simply replacing the battery fix my HX6511/50?
Not always. In this thread, replacing the battery did not change the symptoms. If a fresh cell doesn’t restore operation, the fault is elsewhere. Consider firmware state or prior moisture damage as next suspects. [Elektroda, dodger2018, post #17763532]
What battery fits the HX6511/50?
Users observed a US14500VR2 680 mAh cell (14500 format) inside. One failed cell measured 0 V. Pre‑charging it to about 4.1 V briefly revived vibration for ~3 seconds, then it stopped. Treat that as a diagnostic only, not a fix. [Elektroda, dodger2018, post #17749790]
What are the RX/TX pads and JP1 on the PCB?
They are service fields indicating the controller is programmable. Forum members report lockouts tied to usage count or excessive discharge. These pads enable firmware access for recovery or updates. They also signal anti‑repair safeguards. [Elektroda, E8600, post #17763605]
Whats the safe order to replace the battery to avoid a lock?
Follow this sequence:
  1. Desolder the JP1 service jumper before disconnecting the old cell.
  2. Replace the battery and verify polarity and joints.
  3. Resolder JP1, then test on the charger. This order reduces the chance of a firmware lockout. [Elektroda, E8600, post #17763672]
Only the green LED lights and theres no vibrationwhat does it mean?
It points to erased or damaged firmware from an earlier swap. Recovery requires a programmer and the correct firmware image. As one expert notes, “Without a programmer and a batch, you won’t do anything.” Plan a reflash via the service pads. [Elektroda, E8600, post #17765684]
Why does my brush turn on by itself or run for 10 minutes?
These are “Typical symptoms of flooding electronics.” Moisture intrusion corrupts signals and control states. Clean the board with isopropanol and inspect traces. Persistent auto‑start or 10‑minute runs strongly implicate water damage, not the battery. [Elektroda, misiek1111, post #18111723]
How should I clean coil sediment or rust safely?
Use isopropanol to wash the PCB and remove deposits. After cleaning, check trace continuity with a meter. Moisture can eat copper tracks and cause erratic behavior. Address sealing issues before reassembly to prevent recurrence. [Elektroda, misiek1111, post #17766178]
How long should I dry the board after washing?
Allow about 12 hours of thorough drying on a warm radiator. Ensure no moisture pockets remain under components. Only reassemble and test after the board is fully dry. This reduces shorts and false triggering. [Elektroda, klamocik, post #17763948]
Can the HX6932 be serviced the same way?
The HX6932 model’s battery can be replaced normally, without special lockout steps. Always confirm the exact model before following a guide. Component layouts and protections differ across variants. [Elektroda, misiek1111, post #17766178]
I pre‑charged a dead cell to 4.1 V and it briefly workedshould I rely on that?
No. Pre‑charging can momentarily wake a protection‑tripped cell, but it’s not a repair. One report saw ~3 seconds of vibration and then nothing. Proceed to a proper cell replacement and firmware‑safe procedure. [Elektroda, dodger2018, post #17749790]
What should I do if it still doesnt work after replacing the battery?
Plan for firmware recovery using the service interface. As advised, “you would have to look for the batch and try to program it again.” If you lack a programmer, seek a shop that offers reflash service. [Elektroda, E8600, post #17763887]
How should I charge to extend the Sonicare batterys life?
Charge only when the level is near empty and avoid parking on the charger. One user reports, “My Philips has been working on the original battery for 4 years.” This pattern reduces stress cycles. [Elektroda, Piotr2608, post #18100256]
Philips says there are no spare partscan an independent shop still help?
Yes, but verify capabilities. The battery is replaceable, yet the electronics may block operation after a swap. “The battery can always be replaced, the question is whether the electronics will allow.” Ask if they handle firmware reprogramming. [Elektroda, Piotr2608, post #18100285]
What signs suggest the seal failed near the coil?
Sediment and rust near the coil indicate a leaky housing. Clean with isopropanol and inspect for corroded traces. Seal the mechanical path before reassembly to prevent repeat faults. [Elektroda, misiek1111, post #17766178]
