Where can I download authentic HPSetCfg and AMT Tool programs, and how can I use them when AMT is descriptor-locked?
HPSetCfg and AMT Tool were attached in the thread, and the post also points to instructions plus other bootable-USB tools at `http://www.compit.se/?p=206` [#10962760] If your HP notebook shows `Descriptor Locked`, `VPro Enabled`, and you cannot toggle AMT in BIOS, `CPQAMT.exe write off` will only return a locked-descriptor message [#10965535] For a blocked descriptor, one workaround reported here is to boot the laptop while holding `WinkKey` + `left arrow` + `right arrow`, then run `BRAND.BAT` [#11995096] That procedure was later confirmed to work on HP 8540w and HP 8530w [#12170053][#12604033]
Thank you for the links. Unfortunately, I can't turn off AMT on my HP 8530w. Descriptor is Locked and should be Unlocked. In bios, I do not have the option to turn off AMT.
Unfortunately not, I have burned this ISO image file. I run a botable CD and it displays what I wrote above. He types the command "CPQAMT.exe write off" and gets a message that Descriptor Locked> I can only read but not write changes.
The discussion revolves around finding reliable sources for the AMT Tool and HPSetCfg programs, which are essential for managing Intel Active Management Technology (AMT) on HP laptops. Users report difficulties in disabling AMT due to a locked descriptor, preventing changes in BIOS settings. Several users share their experiences with different HP models, including the HP 8530w, HP 8540w, HP 6540B, and HP ProBook 4510s, and suggest using specific key combinations (Windows Key + left/right arrows) to unlock the descriptor. Despite attempts to modify settings, some users remain unable to save changes, indicating a common issue across various models after BIOS updates. AI summary based on the discussion. May contain errors.
