HP EliteBook 2560p BIOS Failure Recovery & Missing Data Update: HPBQ138.exe Alternative
ukladbga 19095 6
  • #1 14645006
    ukladbga
    Help: 7
    Rate: 18
    I had a bios failure in the above-mentioned model. Bios programmed in the programmer. Now, when starting, I get messages like in the photo. What program should I supplement the missing data with? I tried HPBQ138.exe but this utility can NOT be executed on this platform is displayed. Please check other version utility again
    • HP EliteBook 2560p BIOS Failure Recovery & Missing Data Update: HPBQ138.exe Alternative WP_20150425_002.jpg (914.45 KB) You must be logged in to download this attachment.
    • HP EliteBook 2560p BIOS Failure Recovery & Missing Data Update: HPBQ138.exe Alternative WP_20150425_004.jpg (1.27 MB) You must be logged in to download this attachment.
  • #2 14645337
    maliusss
    Help: 10
    Rate: 24
    Do you have an old (ripped) batch?
  • #3 14646844
    ukladbga
    Help: 7
    Rate: 18
    Unfortunately not
  • #4 14653391
    bartsam
    Help: 7
    You must program the serial number of the board and the product number ..
    Manufacturing mode should disappear after these 10 restarts (then programming s / n will not be possible).
    Do you program? hm, there used to be ..hpset1xx.exe .. and now it needs a uefi bootable pendrive.
  • #5 14655184
    ukladbga
    Help: 7
    Rate: 18
    The laptop was orig. win 7. Do you have any idea how to program it?
  • #6 14655352
    martiv
    Help: 22
    Rate: 41
    Buddy, at the beginning programming the bios, make a copy of the old batch, such a golden rule for the future. Attached are the program and any links to programs that should help you. HP DMI Tools
    • HP_DMI_TOOLKIT.zip (1000.73 KB) You must be logged in to download this attachment.
    ABCLAP
    Trockiego 43, Kraków, 30-394 | Tel.: 510XXXXXX (Show) | Company Website: https://www.abclap.pl
  • #7 14667385
    ukladbga
    Help: 7
    Rate: 18
    Problem solved hpset152.
The discussion revolves around a BIOS failure recovery issue for the HP EliteBook 2560p. The user reports that after programming the BIOS, they encounter error messages and are unable to execute the HPBQ138.exe utility. Responses suggest that the user needs to program the serial number and product number of the motherboard, and that the manufacturing mode should disappear after ten restarts. Recommendations include using the hpset1xx.exe utility and creating a UEFI bootable USB drive. Ultimately, the user resolves the issue using the hpset152 utility.
