Parkside PHD 150 A1 – not drawing detergent with lance, what to check?
zieliniak96 59198 2
  • #1 10983242
    zieliniak96
    Rate: 29
    Hello. I have the above-mentioned washer, which has a built-in detergent tank. After pouring active foam into it, it does not take up detergent. I have the minimum water intake set on the lance and foam should flow, but it does not. If I remove the tip and leave the gun alone when you press it, it draws foam, then I put the lance in and literally foam comes out for 3 seconds and that's it.
    Does anyone know what this is about?
  • #2 10985141
    zieliniak96
    Rate: 29
    I will also add that when I use a brush instead of a lance, foam comes out all the time, but when I use this lance, it doesn't foam. This means that the lance is broken.
    Nobody knows what this could be about?
    Nobody will help???
  • #3 12285702
    trębacz
    Rate: 85
    Read the instructions, it says like a bull that it takes chemicals only at low pressure, when the tab in the lance is pulled out.
